What size tires with 3” rough country lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mach140, Aug 26, 2019.
  1. Aug 26, 2019 at 5:10 PM
    mach140
    mach140 [OP] Member
    Lake Monticello, Va.
    2017 Tacoma TRD PRO
    Nfab steps,Bakflip tonneau cover,Interior LEDs
    All
    I need help my son has a 2015 trd off road and just purchased a rough country 3” lift. He wants to stay with the 17” rims that are on the truck now what size tire can he go up to without any mods for rubbing?
    He has 17” rim and 265/70r17 tires on truck now..
    Thanks
    New to the Yotas
    Son
    2015 trd off road
    Me
    2017 trd pro
  2. Aug 26, 2019 at 5:22 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    265/70/17 unless you want to chop the cab mount. The lift doesn't change the size of the wheel well which is the limiting factor...the wheel follows the same path when the suspension cycles.
  3. Aug 26, 2019 at 8:33 PM
    Duckmaster
    Duckmaster New Member
    QUINN
    Sandpoint ID
    2014 Gray DCLB
    3in lift,mesh grill, and 285/70/17
    I have a 2014 with a 3 in lift and run 285/70/17 with no rubbing. I would avoid going bigger than that if you don't want to do any further modifications.
    mach140[OP], Rod Ferro and Thuguon2.7 like this.
  4. Aug 26, 2019 at 9:03 PM
    Michaelo
    Michaelo Well-Known Member
    Michael
    PNW
    2014 Regular Cab 4x4 5 Speed
    I bought mine with a 3” spacer lift and 285/70r17. Minor rubbing only in reverse or when tire is stuffed and wheel turned. No cmc or anything. I’m on a set of fuel 17” rims though so maybe different.
    Rod Ferro likes this.
  5. Aug 27, 2019 at 7:05 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    I’m running 285/70/17 also.
  6. Aug 27, 2019 at 7:10 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    You guys with 285s must not go off pavement.
  7. Aug 27, 2019 at 7:41 AM
    Michaelo
    Michael
    PNW
    I do. Offroading and reverse while turning are the only times I rub.
  8. Aug 27, 2019 at 9:13 AM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    What?
    Don’t be silly. Plenty of people run 285’s with a 3” lift.
  9. Aug 27, 2019 at 9:18 AM
    geekhouse23
    Including yours truly
    I have a CMC, beaten flat pinch weld, mudflaps removed, no fender liners, aftermarket UCAs, trimmed fender flares and I still rub off pavement.
    Mully likes this.
  10. Aug 27, 2019 at 9:22 AM
    Naveronski
    Fort Worth
    Really odd that you had to do all that.
    I did a CMC and was fine.
  11. Aug 27, 2019 at 9:22 AM
    Blue Truck
    Blue Truck Well-Known Member
    I dont even have 3" and have never had issues but i also try not to stuff the tires at full lock in 4wd
  12. Aug 27, 2019 at 11:27 AM
    gotoman1969
    Those look bigger than 285s
  13. Aug 27, 2019 at 11:38 AM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Me too.
    geekhouse23[QUOTED] likes this.
  14. Aug 27, 2019 at 11:43 AM
    geekhouse23
    I promise they're not.
  15. Aug 27, 2019 at 12:19 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    255/80/17
  16. Aug 31, 2019 at 8:33 AM
    mach140
    mach140 [OP] Member
    2017 Tacoma TRD PRO
    What off set and what rim width are you guys running with the 285/70r17 tires?
  17. Aug 31, 2019 at 8:51 AM
    mach140
    mach140 [OP] Member
    2017 Tacoma TRD PRO
    What off set and what rim width ?
  18. Aug 31, 2019 at 9:03 AM
    gotoman1969
    17x8.5 -10
  19. Aug 31, 2019 at 5:39 PM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    I'm there with yah... I am super hesitant to believe people when they say they don't rub after 285's etc... On pavement and normal conditions it is completely fine. When off road and you start stuffing it all bets are off. My back end clears pretty good, I actually still have my flaps in the rear but they are not the oem flaps so they have give to them. But my front starts to rub when flexing and going to full lock. Just how it is... as long as the tires aren't getting chunked or flares ripped off I am good. :cool:
    stickyTaco likes this.
  20. Sep 3, 2019 at 10:16 PM
    TRDRob77
    TRDRob77 New Member
    2006 toyota tacoma crew cab trd prerunner
    Lift,33" wheels
    Im on 285/70/17 and i had to lift 3" cab mount chop 1.25" spacers and cut plastic now full flex absolutely no rubbing 285's on 17" equals 33" if your thinking of going bigger just take the proper steps dont damage your truck or tires my opinion if ur unsure take mesurements
