What size tires
Discussion in '1st Gen. Tacomas (1995-2004)' started by dirtbags, Mar 23, 2011.
  1. Mar 23, 2011 at 10:59 AM
    dirtbags
    dirtbags [OP] Member
    2003 Daouble cab Tacoma 4x4
    I am new to TW and I know this question has been asked over and over , but I have a 03' Tacoma double cab 4x4 with a 2 inch leveling kit which raised the front about 3 1/2 inch going to replace the rear leafs with the 5-pack from Wheelers. New Moto Metal 955's can I run 285 75 16 BFG a/t without alot of trouble. What if I run Spidertrax wheel spacers, will that help.
  2. Mar 23, 2011 at 11:03 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    you should be okay as long is you have at least 4.5" back spacing. just a little trimming maybe
  3. Mar 23, 2011 at 11:08 AM
    dirtbags
    when you say trimming are you talking about the pinch weld mod
  4. Mar 23, 2011 at 12:06 PM
    thegame
    thegame WUT?
    Brian
    Bay area
    01 Prerunner -> 4wd IFS -> Dana 60 SAS
    Yes, the pinch weld mod. Wheel spacers will make the tires rub worse.
