What size tires?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JNL, Nov 24, 2009.
  1. Nov 24, 2009 at 11:18 AM
    JNL
    JNL [OP] Well-Known Member
    Jamie
    Atlanta
    08 DC Prerunner TRD Sport
    What is the biggest tire I can run with 5100's set at 1.75" and the TSB rear spring?
    Eventually I am going to put on camburg spindles and an AAL but I would like to upgrade my wheels and tires first.
    Thanks
  2. Nov 24, 2009 at 12:29 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    These are 265/75R16.
    I have the TSB and 5100s at .85
    No rubbing or vibrations at all.
  3. Dec 4, 2009 at 10:09 AM
    JNL
    Jamie
    Atlanta
    looks good.
    I have a set of spidertrax spacers on the way and I am going to try running 285/70/17 BFG AT's on my stock rims with the 5100's at 1.75" . If I still rub after trimming I guess I'll just have to bump up the billy's to 2.5.
  4. Dec 4, 2009 at 11:02 AM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    I'm running around the same setup you have. I'll be putting on BFG TA KO 265's on my 16 inch rims.
  5. Dec 4, 2009 at 11:06 AM
    RAD
    RAD RAD Vendor
    THE RAD
    Socal
    2007 | TRD |1ST 2012+ CONVERSION
    2012 CONVERSION | A LOT OF TOTAL CHAOS & ICON DYNAMICS
    ^ Jeff, I thought you were going '35s? That would look sick on your 5100 set up!
  6. Dec 4, 2009 at 11:07 AM
    jefferson
    Sex Panther
    05 PreRunner SR5
    I'm all for getting larger for sure; but wouldn't you have to start choppin up stuff to get it to fit?? You can see i have some room to play with.. those are 245's i think??
  7. Dec 4, 2009 at 11:12 AM
    RAD
    RAD RAD Vendor
    THE RAD
    Socal
    '35s would be awesome and there might be some rubbing but nothing your TACO couldn't handle! :D
    Jeff, just let the tires rub out whats needed.
  8. Dec 4, 2009 at 11:14 AM
    jefferson
    Sex Panther
    05 PreRunner SR5
    That's what she said
  9. Dec 4, 2009 at 11:42 AM
    RAD
    RAD RAD Vendor
    THE RAD
    Socal
    How'd you know, you most likely FLAKED!:D Just messin Jeff. Don't Flake!
  10. Dec 4, 2009 at 11:46 AM
    jefferson
    Sex Panther
    05 PreRunner SR5
    I dont flake - what gave you that idea :rolleyes:
  11. Dec 4, 2009 at 11:56 AM
    RAD
    RAD RAD Vendor
    THE RAD
    Socal
    265's
    If you want to run 285's, you'd need to go up to 2.5
    w/Trimming
  12. Dec 4, 2009 at 12:20 PM
    JNL
    Jamie
    Atlanta
    Thanks....looks like I will be pulling the shocks apart again.
    At least now its gonna be a piece of cake since I know what I'm doing.
    Is it pretty easy to pop off the snap ring on the 5100's? Any particular tools required?
  13. Dec 4, 2009 at 12:24 PM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    dudes are running 285s with that set up
  14. Dec 4, 2009 at 1:32 PM
    flatlander
    flatlander Well-Known Member
    09 DC-LB 2WD Prerunner V6 Auto
    I am pretty sure you can also run the 265x75x16 with the OEM setup also. In case you need to get the tires or something before you can get the 5100s.
  15. Dec 4, 2009 at 1:34 PM
    RAD
    RAD RAD Vendor
    THE RAD
    Socal
    Running 285's @ 1.75 will run into a lot of rubbing.
