What Size Tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 7empest, Jan 25, 2022.
  1. Jan 25, 2022 at 1:21 PM
    7empest
    7empest [OP] New Member
    2011 Tacoma
    3 in lift
    Hi i have a 2011 Tacoma and when I bought it I put a 3 in lift on it. However, someone suggested I put on a wider tire than the ones that were at purchase. Currently I have 285/75r16…because the truck had a smaller r16 on it…I think. At any rate, I bought the 285s 16s because I couldn’t afford new rims at the time, to accommodate want I wanted. So my question is what would be the best size tires and rims should I get? Can anyone help?
  2. Jan 25, 2022 at 1:29 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Someone tells you to jump off a cliff you gonna jump too?
    285/75R16 is gonna be the biggest you can go without having to do major modification, and you are likely already rubbing the cab mount and pinch weld.
    wi_taco likes this.
  3. Jan 25, 2022 at 1:45 PM
    76CLE76
    76CLE76 Active Member
    Charles
    Divide, CO
    2011 White Tacoma Off Road and Towing packages
    Aluma coil-overs with 3” lift Toytec 1" body lift Toyota Cat-Back exhaust JBA Standard High Caster Upper A-Arms Spydertrax 1.25" spacers Yokohama Geolander M/T G003, 285/55r16 on stock rims N-Fab Nerf Step Bars
    7empest[OP] likes this.
  4. Jan 25, 2022 at 3:24 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Tire size is good. Rattle-can paint the OEM rims black and save some $$.
  5. Jan 25, 2022 at 4:15 PM
    7empest
    2011 Tacoma
    3 in lift
    Ah cmon man. Go easy. You’re right…it rubs. I’m just wondering can I go wider and lower? Or what would you recommend?
  6. Jan 25, 2022 at 4:20 PM
    7empest
    2011 Tacoma
    3 in lift
    thanks, that’s a good option
  7. Jan 25, 2022 at 4:23 PM
    That1GuyKev
    That1GuyKev Well-Known Member
    Kevin
    2021 TRD OR Army Green
    285/75/16 General Grabbers ATX on pro comp wheels 16x8 0 offset. Bilstein 6112 front and 5160 rear
    Best tire size is 37s because yes
    wi_taco and nd4spdbh like this.
  8. Jan 25, 2022 at 4:24 PM
    nd4spdbh
    SoCal
    wi_taco likes this.
  9. Jan 25, 2022 at 4:34 PM
    7empest
    2011 Tacoma
    3 in lift
    What would you recommend?
  10. Jan 25, 2022 at 6:37 PM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    Leave the 285s and trim what needs to be cut. Good to go.
    wi_taco likes this.
  11. Jan 25, 2022 at 6:59 PM
    10YSON
    10YSON Well-Known Member
    GREG
    2ND GEN 4X4 LT
    TOTAL CHAOS / KING / DEAVER / PRP / DIRTKING
    Id spend the $$$ on bumpers or skids if I was you.
  12. Jan 25, 2022 at 7:04 PM
    saltybum
    saltybum Well-Known Member
    Bob
    Space Coast
    2022 Tacoma Access
