What size top plate spacer will fit on stock hight studs?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 757yotas, Dec 26, 2016.
  1. Dec 26, 2016 at 7:17 PM
    757yotas
    757yotas [OP] Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    title says it all! I want alittle more lift but dont want to have to rent a compressor if i dont need to. Looking for about 1/2"-3/4" more of lift
  2. Dec 26, 2016 at 8:46 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    1/4" is all your gona get on there safely. That works out to be a little more than 3/8" lift.
  3. Dec 26, 2016 at 11:53 PM
    757yotas
    Virginia
    2007 TRD Sport
    Ok cool ill just get 1/4" then, dont feel like taking the tophat off right now
  4. Dec 27, 2016 at 5:30 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    You'll need longer top cap studs, like these: I have a pair of 1/4 top plate spacers if you're interested.
  5. Dec 27, 2016 at 5:51 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    get a 2.5 inch lift. so long as you don't plan on using the travel of your suspension, you can get a 2 inch spacer up there. the spacer comes with stud extensions so you don't have to worry about stock length.
  6. Dec 27, 2016 at 6:50 PM
    devinzz1
    devin
    2023 aclb trd or mt
    you can get away with stock studs with 1/4 spacer.
  7. Dec 27, 2016 at 8:09 PM
    757yotas
    Virginia
    2007 TRD Sport
    I had 2.5" lift spacers on the old factory shocks and coils, dont think it would be a good idea to put a spacer on top of 881s
  8. Dec 27, 2016 at 9:42 PM
    CodeSeven
    Serge.
    Coachella Valley
    i assumed you were stock since you didn't mention your current setup and reffered to it as stock height. please include more details before expecting a viable answer.
  9. Dec 28, 2016 at 7:55 AM
    757yotas
    Virginia
    2007 TRD Sport
    As of this moment i have 5100s with ome 881 coils on the front. I have Dakar leaf packs on the rear. I want to know what size spacer i can fit on the top plate stock studs (not extened). I would rather not pull the coil apart as i hate doing the job lol but will of i need to. I have seen most people do a 10mm (3/8") spacer on top of the 881s
