What size toppers will fit?
Discussion in '1st Gen. Tacomas (1995-2004)' started by milehighliving, Feb 26, 2012.
  1. Feb 26, 2012 at 10:54 PM
    milehighliving
    milehighliving [OP] Well-Known Member
    Colorado
    03 Silver Xtra Cab 4x4
    2nd Gen SC, Addicted Front Bumper, Allpro rear bumper, OME Full suspension lift, LR UCAs, Extended brake lines, Goodyear Wrangler Duratrac 285/75/r16 with level 8 wheels.
    I have an 03' xtra cab. I'm looking at getting a topper. One problem I'm encountering is how do I know if the topper will fit? Will a topper on a 98 ranger fit? what about frontier toppers?
    Thanks
  2. Feb 27, 2012 at 3:50 AM
    stumpman
    stumpman Well-Known Member
    tn
    2019 Dclb cement
    Buy one for an 1st gen Toyota extra cab, it will fit. The others fit the respective brands.
    Aquatic Tacoma likes this.
  3. Feb 27, 2012 at 5:26 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    At one time all the manufacturer's trucks had the same size boxes or so close as to not matter but now it seems that they can't get together on the size. I looked around for a while for my topper and found one that had been on a S10 that fit pretty good. The ones I looked at from nissan and ford were all too short. All yo can really do is measure your box and measure the topper when you look at it unless you find someone selling one from a 1st gen like yours. The other solution is a brand new one built for your truck but that is pretty pricey.
  4. Feb 27, 2012 at 7:13 AM
    JSFoster75
    JSFoster75 Well-Known Member
    Scott
    Bluff City, TN
    2018 Wrangler JLU Sahara
    Too many to list.
    I have a Double-Cab 1st Generation and I tried 3 toppers before settling for one built for my truck... All were off by mere inches, but those inches meant the difference in the tailgate closing or not closing, or in weatherproof vs. non-weatherproof...
    Drop the extra money and get the right fit, it will serve you better in the long run! :)
    RtacomaN likes this.
  5. Feb 27, 2012 at 8:09 AM
    Hillingdoner
    Hillingdoner Well-Known Member
    Rio Rancho, NM
    95 LX xtracab 3.4L 4x4 5spd
    140 amp Cadillac alternator, Audio system in progress, 4Runner map light mirror conversion, foot well lamp addition, buckets and console from 99 Tacoma regular cab, big three, tint
    Give a scan of Craigslist as (apart from the sea of wheels and tyres for sale at least here) toppers/camper shells seem to come up pretty often at good prices.
    You can also try calling around some of the local dealers. Some have second hand shells in stock and might have one to fit. Probably cost you more for one this direction though.
    Be sure to check close for any cracks or damage on used ones and make sure all windows work correctly etc. Anything can be replaced or repaired, but then in the used market it really depends on what you are willing to spend to repair one compared to just waiting for another to come up. I've seen them here listed for "free pick it up" up to around $600 or so depending on what they fit etc. Seems though generally for this area they average around $200 to $350 or so.
    As far as fit could not confirm for sure, but you should find them popping up off of Tacomas pretty regular. Just get one to match the gen and you should be over.
    Cheers
  6. Feb 27, 2012 at 8:56 AM
    derekp
    derekp giddy up!
    Derek
    Grand Forks, ND
    2001 X-Cab 4x4 TRD V6 5Spd
    Deck plate, Flowmaster Delta-Flow 40 series, 265/75-16 Wrangler TDs, more to come...
    Also something to consider:
    The cab on the xtra-cab and regular cab are a bit different. The rear of the xtra-cab has a slight angle forward and the regular cab is more straight up/down. If you get a regular cab shell/topper you will have a larger gap at the top, where the shell and cab meet.
    Good info on searching Craigslist. If you aren't in a big hurry, you will be able to find one in your area (or close to it). I found mine about 50 miles away for $200. It was in great condition.
  7. Feb 27, 2012 at 9:25 AM
    BVCOTaco
    BVCOTaco Well-Known Member
    BV, CO
    02 Xtra Cab SR5 TRD
    ARB Bullbar
  8. Feb 27, 2012 at 12:17 PM
    milehighliving
    Colorado
    Seen both of those on CL. I've been looking for a solid 3+ months. Just waiting on one thats color matched (I'm silver). Thanks guys I'm just going to keep waiting until the perfect one pops up!
  9. Feb 27, 2012 at 1:51 PM
    haddix
    haddix Well-Known Member
    KY
    07 FJ Cruiser
    OME,315 k02, custom bumpers
    Good choice. You will be happier in the end.
  10. Jan 27, 2019 at 7:57 PM
    hoyden
    hoyden Active Member
    Dawn
    southern Illinois
    '14 DCSB Taco Blue
    a bunch
    Will an ARB topper for a 2010 Toyota Tacoma extended cab pickup 6' fit on a 2014 Tacoma double cab 6'? TIA!
  11. Jan 28, 2019 at 8:08 AM
    DW85
    DW85 Dude.....
    Daniel
    Kentucky
    2001 XtraCab Tacoma TRD 4x4/2004 SR5 V6 4Runner
    Tacoma: Badlands basher front bumper Trail gear rear bumper Trail gear sliders OME Dakar’s OME 883 Coils Bilstein 5100s front Bilstein 5125s rear SPC Upper Control Arms Wheeler’s Extended brake lines ProComp 51 Series 15x8 3.5” BS 32x11.50x15 BFG KO2’s Honda CR-V windshield washer nozzles Hella 500FF fog lights Energy Suspension power steering rack bushings 4Runner: Hankook DynaPro ATM RF10 265/70r17’s TPMS Bypass mod RCI Skid Plate CBI Ditch light brackets 1.25” Wheel Spacers 2” Front Leveling Kit
  12. Jan 28, 2019 at 8:19 AM
    hoyden
    Dawn
    southern Illinois
    '14 DCSB Taco Blue
    a bunch
    Thanks! But looks like that only goes to 2011.
  13. Jan 28, 2019 at 8:21 AM
    DW85
    DW85 Dude.....
    Daniel
    Kentucky
    Well :censored: I’ve never payed attention to that.
    hoyden likes this.
  14. Jan 28, 2019 at 8:39 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Even if you find a topper from another truck that happens to fit the box dimensions, it's likely going to look stupid because the body lines are different for every truck and won't line up.
    Unless you you want your truck to look like this:
    Just get one made for your specific model.
    cornbread_wy likes this.
  15. Aug 18, 2020 at 5:49 AM
    JakesTacoTRD
    JakesTacoTRD "Winona the Tacoma"
    Jacob
    Gainesville, FL
    2001 White Tacoma SR5 TRD 4x4 5 speed
    Old forum but second get softtoppers fit first gens. Just putting this here for future viewers (this is my truck with a second gen topper). I have seen this is universal for extended and double cabs.
    6C39E84A-F763-4BAC-BC69-8589E9AFE860.jpg 31687CE6-84C5-4623-83E6-57CB545F0D5C.jpg
  16. Aug 20, 2020 at 5:44 PM
    JakesTacoTRD
    Jacob
    Gainesville, FL
    <3
