What size wheel spacer with 285/70/17
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Wickeddtuna, Apr 6, 2023.
  1. Apr 6, 2023 at 9:27 PM
    Wickeddtuna
    Wickeddtuna [OP] Active Member
    R
    2020 tacoma trd
    What size wheel spacer is everyone using with there 285/70/17 tires
    I have a 3.5 suspension rough country lift with ucas. Rims have a 0 offset
  2. Apr 6, 2023 at 10:07 PM
    SoonToBeOn39s
    SoonToBeOn39s Well-Known Member
    I finally got bigger tires 2020 Long Travel Tacoma 1997 MAGNUM
    0 offset is fine. You'll run into rubbing issues on the cab mount if you have more negative offset wheels
  3. Apr 6, 2023 at 10:18 PM
    Wickeddtuna
    R
    2020 tacoma trd
    whats a good wheel spacer to make the tires poke out a bit from the fenders? 1.25 or 1.5
  4. Apr 6, 2023 at 10:30 PM
    MGMDesertTaco
