What Size Wheels?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lukas24027, Nov 28, 2020.
  1. Nov 28, 2020 at 10:21 AM
    lukas24027
    lukas24027 [OP] New Member
    Lukas
    2015 Gunmetal Taco
    I'm a brand new 2nd gen Tacoma owner and im planning on putting a little 3in lift on it. Any suggestions what rim/tire size would look good? Planning on taking it off-roading and camping but i've done any car mods before.
  2. Nov 28, 2020 at 12:09 PM
    Pigpen
    Dan
    Northwest Montana
    I prefer more tire, less wheel. 16" is the smallest wheel that fits on gen 2. 265/75 is the easiest, most versatile choice - and looks damn good. 255/85 is next. Go to 285 if you don't mind rubbing, or cutting parts off your truck.
  3. Nov 28, 2020 at 12:10 PM
    Pigpen
    Dan
    Northwest Montana
    Also, welcome to TW!!
  4. Nov 28, 2020 at 12:19 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I'd keep the wheels that came on the truck. If the wheels are 16", then 265/75/16 tires. If the wheels are 17" then 265/70/17. Both of those sizes are virtually the same overall width and height and are as big as you can go without other more expensive modifications. In fact they will fit without the lift. Buy the tires first, you may decide you don't need the lift. Spend that money for gas.
  5. Nov 28, 2020 at 12:37 PM
    Clearwater Bill
    Billy
    Largo Florida
    And rethink the 3" lift if it's 4wd.
    Over 2-2.5" you start increasing the risk of introducing secondary wear issues.
    If it's a pre runner, call Marie @HeadStrong Off-Road and ask for the @ChadsPride special.
    If it's 4wd, call her anyway, with how you are using the truck, your goals for ride/behavior and a budget. Then install what she ships you.
    If your budget is low, save up more and do it correctly the first time.
    lukas24027[OP] likes this.
