what size winter tires to get?
Discussion in 'Wheels & Tires' started by TacomaPrime, Aug 16, 2011.
  1. Oct 1, 2011 at 1:06 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    if i were you i would seriously look into getting a spare set of rims for them. its much easier to swap them around, less risk of damaging the rims. you should be able to get some cheap, cheap enough to make up for paying for mount balance 2 times a year
    check tire places for steel wheels or even a junk yard, or right here on TW.com for someone selling some
  2. Oct 1, 2011 at 1:21 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    That's a good tire with modern winter tire compound. Modern winter compound typically has a porous outer layer that sucks away the top layer of water on ice (the opposite principle of ice skates). Would've gotten these instead of Winterforce UV last winter except they weren't in stock.
    In deep snow, no. However, if you live in the city and have to drive in a mix of snow, ice, slush and bare pavement throughout the season, the winter tires will perform better.
  3. Oct 1, 2011 at 1:22 PM
    TacomaPrime
    TacomaPrime [OP] Cybertronian Tacoma
    Gregory
    Illinois
    14 TRD sport 4x4 Barcelona Red
    Weathertech front floor liners, window vent visors. Custom bedside decals. OEM bed mat, tonneau covrew. Added D rings to bed.
    The winter tires are going on the factory rims and I'm getting some other rims and tires for summer.
  4. Oct 1, 2011 at 1:23 PM
    pudge151
    Sean
    Connecticut
    ah i see. that will work out pretty good then
  5. Oct 1, 2011 at 4:11 PM
    TacomaPrime
    Gregory
    Illinois
    I can't use chains around here. Or studs. Boo.
  6. Oct 1, 2011 at 4:29 PM
    monte1985
    monte1985 Well-Known Member
    Stan
    Lancaster NY
    09 Tacoma Dbl Cab 4.0 S/C
    Supercharger, Magnaflow Exhaust. Audio System . Gauges TRD CAI
    I got the Goodyear Ultra Grip Ice WRT SUV 265/70/16 for the winter . Love them . And i work for goodyear so got a really good price with my discount . Even have them on spare alloy stock wheels with tpms sensors in them .
  7. Oct 1, 2011 at 4:30 PM
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    I went with Bridgestone 265/70-17s for the truck. Excellent tire that does better than any regular tire, but it probably would have been better to go with a skinnier tire than I did. Gets you where you want to go safely but easy to spin the tires if you get aggressive. Not enough contact patch pressure.
  8. Dec 20, 2011 at 4:13 PM
    Thundjet
    Thundjet Well-Known Member
    2012, V6, Sport TRD, Auto, 4 wd
    If you purchase an aftermarket set of rims to mount the snow tires on and do not want to spend the cash for extra TPMS sensors what happens?
    Does the light come on in the dash and just stay on till you remount the stock rims?
    Any way to get rid of the light coming on?
  9. Dec 20, 2011 at 4:27 PM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    Yes, the light stays on if there are no sensors on your tires. Don't know how to get it off without installing the sensors Perhaps there is a fuse you can pull.
  10. Dec 20, 2011 at 4:51 PM
    186000mps
    186000mps ..Slingin' up mud and we're scarying off bunnies..
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Bilstein 5100's, Toytec front adjustable coilover kit, Exporear leafs, Fox resi rears, Slotted & Drilled front rotors, 33x12.50 BFG ATs on Outlaw II 15 x 10s, Bushwacker cutout flares, K&N cold air intake with aluminum sheathing water baffles, ARB bumper with XD9000 winch with wireless remote, IPF 900XS lights, Flowmaster cat-back exhaust, Rhino bed liner, UWS gullwing toolbox with tools and recovery gear. 48" Hi-Lift Jack secured under toolbox.
    If you were going up Steven's Pass, or the like, chains are required, regardless of snow tires or not. In Vermont I wouldn't drive daily with chains in the winter. On our 4Runner, I use studded Nokian Hakka 5s. However in the Tacoma/Seattle area, there is not really that much snow in the low lands and the need for dedicated snows is pretty low, so carrying some chains for those times when needed is not a bad idea. I used to live outside of Seattle and drove a little rear wheel drive sports car and had no problems, I just threw some weight in the back when needed.
