what size would this be?
Discussion in '1st Gen. Tacomas (1995-2004)' started by t.hornstra, Feb 4, 2009.
  1. Feb 4, 2009 at 8:52 PM
    t.hornstra
    t.hornstra [OP] Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    IF i had 265/75 Tires right now.. what size should i get if i want wider? i can go maybe an inch taller, but i want an 1-1.5 wider
    anyone have pics of 31x12 or 31x11.5 on their 95-04 Tacoma? i want to see what it looks like.
  2. Feb 4, 2009 at 8:57 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    wider would be the middle number...Just think that the guys running "rubber bands" on those huge wheels, are in the 30-40 series
    i had 32 11.5 15's on 15x10 wheels on my 4runner, and they stuck out at least 1/4-1/2 the tire past the body.
    if you want metric, you would have to move up to a 275(which is about a 33" tall tire) Probably somethign like 275-70-15
  3. Feb 4, 2009 at 9:00 PM
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
    ok so say i wanted to put it on a 16 rim, is this available in the BFG all terrains? or the General AT2 series? ive looked at places like tire rack but havnt found anything.. where do u guys recommend i go..?
  4. Feb 4, 2009 at 9:23 PM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    yup..bfg offers them in 16"
    bfg website says 265-70-16 in load range D
    275-70-16
    285-75-16
  5. Feb 4, 2009 at 9:58 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    first number is width in millimeters, so a 275 tire is 10.8 in wide.
    second number is aspect ratio. if the middle number is 70, that means that the sidewall is 70% as high as the tire is wide.
    so a 275/70/16 is:
    10.8 in wide
    ~7.6 inch high sidewall.
    so, 7.6 *2 + 16 = 31 inch diameter.
    an easier way is to just use the tire size calculator that Bob has on the site.
    http://www.tacomaworld.com/forum/tirecalc.php
    Enter current tire size, tire size you want, and it will give you dimensions of each.
