What soap do you use?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by saltybum, Feb 12, 2022.
  1. Feb 12, 2022 at 10:05 AM
    saltybum
    saltybum [OP] Well-Known Member
    Bob
    Space Coast
    2022 Tacoma Access
    Just bought a pressure washer for house hold stuff as well as my Tacoma. Question is...what soap do you use on your vehicles? Manual says ONLY use soaps designed for pressure washers but me thinks others might work as well and not so pricey.
    Thanks
  2. Feb 12, 2022 at 10:08 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    GeorgiaTacoJM and MadKatt like this.
  3. Feb 12, 2022 at 10:09 AM
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
  4. Feb 12, 2022 at 10:10 AM
    GrizzledBastard
    GrizzledBastard OH NO! I've built a Faux Pro!
    Tim
    Central Coast, CA
    '21 TRD OR 4x4 DCLB Super White
    Not enough bandwidth on the internet to list.
    shotgunbilly420 likes this.
  5. Feb 12, 2022 at 10:10 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Optimum no rinse, 2 bucket, only pressure wash the underside and use it for major mud removal with the wide fan tip a high angle and reasonable distance from the paint.
    A pressure washer can do serious damage to your paint.
    Vmax540, oneikr, grogie and 4 others like this.
  6. Feb 12, 2022 at 10:15 AM
    RLMoody
    RLMoody Well-Known Member
    2017 Toyota Tacoma SR
    I dont use soap to wash my cars with. Just clean water, sponges and towells. Ill use my pressure washer for heavy grim or salt before using the sponges. My reason for not using soap is because I hate how it sometimes dries on the surface and streaks. I towell dry my cars and keep them extremly clean including my show car and never use soap. They seldom get dirty anyway. I drive a beater on rainy / snow days.
  7. Feb 12, 2022 at 10:19 AM
    758_Moto
    758_Moto Well-Known Member
    2004 LT Taco, 2019 Taco
    2019: Icon Coilovers/UCA/AAL, 16x8 Methods/285 Duratracs, URD Spec-U Exhaust, Nexus +P Tune 2004: Chaos LT w/Kings/62" Deavers/12" TC Shackles, Glassworks hood/fenders/bedsides, TRD SC, URD fuel mods/lightweight flywheel/10psi Pulley, JBA Headers, TT Supra MAF
    :rofl:
    Every vehicle I've ever owned has been pressure washed every 1-2wks and I have never had a paint issue with any of them
  8. Feb 12, 2022 at 10:20 AM
    Kyebasse
    Kyebasse Jd
    K
    21 Tacoma TRD Off-road
    Any car soap. Most people recommend chemical guys but I heard they are expensive for a car soap. Any Home Depot or auto zone brands will do.
  9. Feb 12, 2022 at 10:27 AM
    Key-Rei
    Key
    Florida
    Depends on how you define "paint issues" I've seen a picture perfect Ferrari with mirror sheen clear coat twelve leagues deep and smooth as glass with less than 100 miles get a paint ultrasonic inspection and have the paint be called "ruined".
    If you're satisfied with the truck being covered in color than it's kinda whatever just don't pressure wash hard around chips or it can quickly remove said color but if you're looking for a show shine free of swirls and embedded particulate, a pressure washer is not your friend.
    Steves104x4 likes this.
  10. Feb 12, 2022 at 10:41 AM
    GrizzledBastard
    Tim
    Central Coast, CA
    OP, I don't bother with the onboard soap dispenser. 1. They only function on a low pressure setting. 2. It's tough to mix the ratio correctly and unless that's all you use the function for, you end up with more product left behind.
    The foam cannons apply at a higher pressure rate and you can coat the entire truck in 30 seconds of application. I exclusively use the spray handle that comes with it for most all my washer use. You can connect it directly to the hose and use it without any wand so in doing so, I have a 25* tip for quick rinse of loose soil, pop it out and plug in the foam bottle, spray it on liberally then shut it down. Use my microfiber mitt to clean the truck, then rinse down with the 25* tip again and done! I have a soft silicone squeegee to clear the vast majority of water, especially off the windows right away, then dry it with very soft and clean towels.
    https://www.amazon.com/gp/product/B085NX4D5Y?ie=UTF8
    https://www.amazon.com/gp/product/B08N47F8DK?ie=UTF8
    Biscuits, tstack22, Squirt and 3 others like this.
  11. Feb 12, 2022 at 10:48 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    i had the truck glass coated. I've never used any soap on the truck yet, just hose it off if really crusty. The rain does the rest. Finish still looks new after 2 years...no swirls, or marks of any kind.
  12. Feb 12, 2022 at 10:49 AM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Any car soap with carnanuba wax if I was to do it. I have an unlimited pass at the car wash and mine goes through almost daily.
  13. Feb 12, 2022 at 11:08 AM
    GrizzledBastard
    Tim
    Central Coast, CA
    Having a good protected surface is indeed paramount to an easy, no abuse wash.
    The Meguiars hybrid ceramic liquid has been amazing in that anything that lands or sticks to the surface comes right off with the rinse. Keeping that up is critical.
    CusterFan likes this.
  14. Feb 12, 2022 at 11:16 AM
    saltybum
    Bob
    Space Coast
    2022 Tacoma Access
    Lots of good info here. I was in the woods hog hunting yesterday and of course splattered some mud around. PW knocked it off fast and easy compared to the bucket of soapy water and a brush. 25* tip worked nicely plus it's getting all the crap off my driveway too. Wife always takes her Subaru to a car wash, maybe no more and at once a week my 2300 Sun Joe will pay for itself in no time.
  15. Feb 12, 2022 at 11:27 AM
    troutarebeautiful
    troutarebeautiful Well-Known Member
    2021 Army Green TRD Sport AC/MT
    Soap, I use Meguiars Gold Class. For waxing I use Meguiars Hybrid Liquid Ceramic Wax. Works well to keep it clean and water beads right off.
  16. Feb 12, 2022 at 6:46 PM
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    GeorgiaTacoJM likes this.
  17. Feb 12, 2022 at 6:55 PM
    908tacoma
    908tacoma Well-Known Member
    New Jersey
    2018 MGM
    OME, SPC, TRD
    Depending on how much you care, their really is a difference in all cleansers, depending on your coating obviously. I really like the Gtechniq G wash, Gyeon Bathe, and Meguiars Hyper wash
    GrizzledBastard likes this.
  18. Feb 12, 2022 at 6:57 PM
    Little Lion
    Little Lion Well-Known Member
    2018 Barcelonian Sport MT
    watered down dove dish soap, works super super super well
  19. Feb 12, 2022 at 6:57 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    I also use Dove.
  20. Feb 12, 2022 at 6:57 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 1999 Corvette 6MT
    Building a Broja
    I’ve been using Chemical Guys Maxi-Suds for years. I need to take a step back and see what else is out there as I have been out of it for awhile now.
