What soap do you use?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by saltybum, Feb 12, 2022.
  1. Feb 13, 2022 at 5:43 AM
    #41
    Tacospike
    Two Trucks
    X2
  2. Feb 13, 2022 at 5:50 AM
    #42
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    Pressure washing with the 40 degree nozzle is fine. Just keep it on a angle and keep it moving. I wouldn't be too aggressive near the front calipers. You will blow out the pad grease and pin grease on the caliper. Pick any name brand suds. Don't use Dawn unless you are about to polish your Taco. Dawn cleans too good. You will have no wax on your sheet metal. If that matters any.
    Squirt, tstack22 and JJ Diablo like this.
  3. Feb 13, 2022 at 5:56 AM
    #43
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Ivory is better...leaves no residue.
    JJ Diablo likes this.
  4. Feb 13, 2022 at 5:58 AM
    #44
    SoCal_Erik
    SoCal_Erik Tiki Taka, Tika Taka
    ‘23 Tundra SR5 Sport, ‘16 SR5 DCSB (sold), ‘15 SR5 DCSB (sold), ‘16 4Runner SR5, ‘15 OR DCSB (sold), ‘05 SC (sold)
    303. Don’t need much and smells great. It’s a little pricey. Someone in here recommended it. I’ve recently used Chemical guys in a foam gun. Washed my wife’s 4Runner. It was okay. I’llbe trying it again next weekend in the taco to see if I get better results.
    908tacoma likes this.
  5. Feb 13, 2022 at 6:00 AM
    #45
    zoo truck
    None
    I've found less issues if you never use a pressure washer...they tend to push water where you don't want to be. Never use a dish wash, or a laundry detergent for a car wash....even a dumb ass like me knows that.
    CusterFan likes this.
  6. Feb 13, 2022 at 6:01 AM
    #46
    gcuthber
    gcuthber Well-Known Member
    2017 White SR5 DBL Cab
    I am not a big fan of using foam cannons. However, I am a big fan of a particular wash - Sonax.
  7. Feb 13, 2022 at 6:07 AM
    #47
    AM6217
    Whatever you do, try it on the wifes ride first.:eek:
    Tallgrass05, Squirt and 908tacoma like this.
  8. Feb 13, 2022 at 6:36 AM
    #48
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    I haven't seen Dove dish soap since the 80s...
    You all using bar soap?
  9. Feb 13, 2022 at 6:38 AM
    #49
    gcuthber
    Always heard that a dish soap will remove any waxes. Not sure what is important to look for to preserve any waxes or protectants that have been previously applied but, I think maybe it is the pH of the soap solution??
    MGMDesertTaco and clip like this.
  10. Feb 13, 2022 at 6:54 AM
    #50
    zoo truck
    None
    Ivory body wash, bar soap, and dish soap. Got some dove bar soap to.
  11. Feb 13, 2022 at 7:04 AM
    #51
    flbldr
    flbldr New Member
    Craig
    SWFL
    2017 TRD Sport 4x4 double cab long bed
    Rubber bed liner, Kicker speakers, Tyger folding bed cover, Tyger slide bars,
  12. Feb 13, 2022 at 7:26 AM
    #52
    splitbolt
    NW Arkansas
    For your truck?
    Yeah, I didn't think of liquid body wash when people said "Dove".
    This is the shit I was thinking of.
  13. Feb 13, 2022 at 7:40 AM
    #53
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Basic chemistry, eh?
    Dunk a piece of metal into a bottle of bleach. Let us know what happens.
    Although in your case and others dealing with salt contamination a higher pH soap will help neutralize the acidity created by the hydrolysis of the salts, there are effective acidic and neutral pH soaps on the market, including those sold by Adam's and Chemical Guys. pH depends on intended application.
  14. Feb 13, 2022 at 8:09 AM
    #54
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    Just about any over the counter car shampoo will do the job. Some have wax mixed in some don't. None are as harsh as dish soap that is formulated to emulsify oil, grease and waxes. I'd only use dish soap (Blue Dawn) if I wanted to strip all of the old wax prior to clay bar and start a new wax layer. I have however used it on my wheels and tires. Tires followed by two coats of 303. No wheel shine for me. I like my tires dark black with no shine. 303 does that.
  15. Feb 13, 2022 at 8:51 AM
    #55
    tonykarter
    tonykarter Crappie Savant
    Snuff Gully, Texas
    2018 DCSB 4x4 Sport 1993 4Runner SR5 4x4, 411,000 miles
    Pine tree air freshener
    I used Adam's products for about a decade, still use their polishes on the boat. Then I went to Zaino stuff. I like Zaino better than Adam's now, use their Z7 Car Show Shampoo on all but my ceramic-coated Taco. I use CarPro Reset on the ceramic coated Taco. I did three coats of CarPro UK2.0 on it April 2019. I have only had to wash it once in almost two years. Listen: Ceramic coating is beyond anything you or I have ever experienced in the past. It will be a long time after coating before ANYTHING sticks to it, before you have to wash it the first time. A rain is your friend: it washes it! Washing you truck is what makes it look old prematurely. The action of rubbing any wash mitt or sponge over it produces micro-abrasions which refract light differently than a new un-abraded finish refracts light. You wash the new lustre off of it! You only learn this after the exuberance of youth causes you to wash a hole through the paint on the hood of your brand new 1981 Chevy 1/2 ton in roughly six years. Ask me how I know. I have a Honda-powered 4GPM, 3500psi power washer that I blew part of a body decal off of my 1993 4Runner. Lesson learned. So I purpose-built a Powerhorse Tool 1300/1600/1800/2200psi, 1.3 GPM pressure washer specifically for washing my vehicles. Water passes through a water-conditioning charcoal media infused with water-softening agents, then a micron filter so that it is as car finish friendly as possible. No water spots. Rinse with pressure washer, then massive foam applied with a foam cannon, let the foam sheet-off most of the grime, then rinse again with pressure washer. Then more foam, then gently wash with mitt without pressure, final rinse. Then blow-dry with a backpack leaf blower. All before the sun gets up above the treeline and before the wind comes up. No water spots. No abraided clear coat. Then pull it in the shop and recoat/feed the ceramic coating with CarPro Reload. (The only regret I have is not putting a wash bay in the shop.)
    As Monty Python use to say, now for something completely different. Your wheels and wheel wells. Poor Boys Wheel Sealant. Two coats on the wheels, one on the wheel wells. Brake dust hardly sticks to the wheels, and that which does easily rinses off with water. NOTHING will stick to your wheel wells. Did it when I did the ceramic coating. Driving in rain rinses both! Bought my Sport DC in October 2018. It has only been washed five times.
    20190701 - Driver's side quartering rearward, charcoal's on sale at HEB for $3.98, big bag.jpg
    BrokeKayaker likes this.
  16. Feb 13, 2022 at 9:08 AM
    #56
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    :rofl::rofl::rofl:
    Bring that nozzle a little too close......paint peel. :facepalm: :smack::anonymous:
  17. Feb 13, 2022 at 9:10 AM
    #57
    mastro1
    mastro1 Well-Known Member
    2017 MGM DCSB TRD Sport
    When its real dirty, I use baby shampoo.. if its good for babies... in the summer I just use water (cold)
  18. Feb 13, 2022 at 9:28 AM
    #58
    saltybum
    saltybum [OP] Well-Known Member
    Bob
    Space Coast
    2022 Tacoma Access
    A whole shopping cart full? Man that filter takes a lot of charcoal.
  19. Feb 13, 2022 at 9:28 AM
    #59
    MGMDesertTaco
    My favorites are the Adam's purple ultra foam, Adam's blue shampoo, and Jay Leno's pink wash and wax, but I use all of these...
    1. Adams blue shampoo (hands down the best regular wash soap, adds gloss, smells berry, cleans very well)
    2. Adam's purple ultra foam (awesome foam, adds gloss, smells grape, cleans very well)
    3. Adam's red mega foam (too much foam, no gloss added, stinks)
    4. Adam's wash and wax (it's alright, I like Leno's better)
    5. Jay Leno's Garage pink wash and wax (extra, extra waxy, smells tropical, favorite scent)
    6. Jay Leno's Garage red car wash soap (smells like red snow cones, smell is over powering and doesn't clean that well)
    7. Mother's polishes gold class carnauba wash and wax (good cheap wash and wax, slightly better than meguiars, use on wheels, inside fenders)
    8. Meguiars pink wash and wax from Costco (also good cheap wash and wax for wheels and inside fenders
  20. Feb 13, 2022 at 9:35 AM
    #60
    MGMDesertTaco
    I'll add I have DI Rinse Pro 100 Deionized tank that I use with a Honda gas pressure washer and MTM PF22.2 foam cannon. Also using a blue kobrajet hose from obsessed garage, standard 40 degree tip, and a sgs28 gun with swivel connected to the foam cannon.
    Planning on picking up an MTM aqualine nozzle guard 40 degree tip from MTM and upgrading the pressure washer to a Kranzle 1322TS from obsessed garage as soon as they're back in stock.
    The gas pressure washer is too loud and I like to watch tv in my garage when I'm washing/detailing. :rofl:
