What speed do you shift your 5-speed M/T at?
Discussion in '4 Cylinder' started by Greg617, Jan 28, 2016.
  1. Jan 28, 2016 at 10:02 AM
    Greg617
    Greg617 [OP] Well-Known Member
    Greg
    New England
    2010 5-speed 4x4
    Dents and scratches... Fox 2.5 Factory
    So, i'm just curious when/at what speeds other people are shifting at.
    What i've been doing for the last 5k miles:
    1-2 : about 8-10 mph
    2-3 : 20 mph
    3-4 : 30-35 mph
    4-5 : 55-60 mph (as advised by 1st owner)
    I've got an ultragauge, and my driving habits are getting me 22+ mpg combined city and highway driving. Granted, i usually won't go over 70 on the highway. I also coast in neutral as much as possible.
  2. Jan 28, 2016 at 10:17 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    I watch the tach and shift at about 2k. I generally shift down at 1500 rpm.
    I don't coast in neutral, except possibly for a few feet when approaching a stop signal. My top speed is generally 65 (the speed limit most places where I drive). I live in a rural, mountainous area. I generally get 25+ mpg overall.
    anthonyg12136 likes this.
  3. Jan 28, 2016 at 2:26 PM
    Greg617
    Greg
    New England
    2010 5-speed 4x4
    whats the earliest/slowest speed that you'll use 5th gear?
  4. Jan 28, 2016 at 3:25 PM
    tgear.shead
    tgear.shead Well-Known Member
    If you're using your speed to determine your shifts, you're doing it wrong. It depend on required rate of acceleration, road conditions, all kinds of other things.
    You shift by *FEEL*, not by speed. When it FEELS like its right to shift, THAT is when you shift. In some driving conditions, I'm at 50 kph in 5th gear. In other conditions, I could be 85 kph in second.
  5. Jan 28, 2016 at 11:02 PM
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    2500 to 3k rpm is generally where I shift, I throw it in 5th as early as 60kmph and as late as 90kmph, I get 21 mpg :)
    GarrettTacoma and Mazdadan like this.
  6. Jan 28, 2016 at 11:17 PM
    hr206
    hr206 Well-Known Member
    Western Washington
    '16 DCSB TRD OR, '98 regular cab 4x4
    /\ This. I usually end up shifting up between 2000 and 3500 rpms.
  7. Jan 29, 2016 at 9:52 AM
    azreb
    azreb Geezer
    TN
    45 mph is about the slowest speed that feels comfortable in 5th for me.
    Markcal and Greg617[QUOTED][OP] like this.
  8. Jan 29, 2016 at 11:59 AM
    Greg617
    Greg
    New England
    2010 5-speed 4x4
    WELL, the question I posed was regarding speed. Obviously thats not all that I am considering when shifting. But that is what I was curious about. I use my ultra gauge which tells me my exact RPM far more accurately than the tachometer is capable of. For obvious reasons I didn't pose the question of how do you shift correctly? OR, What rpm do most people shift at? ...because those are stupid questions, with quite obvious answers... Those speeds I listed are simply where i'm typically reaching 2000 RPMs (accurate to within a hundred give or take). I more or less just wanted to know how other people are using 5th gear.
  9. Jan 30, 2016 at 10:46 AM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    I honestly had no idea so I watched when I shifted yesterday. 15-30-40-50 on open roads, a little lower in town, 90% engine load either way.
    If the road is flat and I'm not accelerating, I'll use 5th at 40 mph, but if any more throttle is needed I'll shift to 4th. At 35 mph it can maintain speed on the flat in 5th but according to the ultragauge 4th gear gets identical mpg with much less vibration.
    Honestly it's 25 mph zones that bug me. The truck shakes in 4th gear so I use 3rd but that's revving near 2000 rpm.
  10. Feb 5, 2016 at 9:58 PM
    Taco Pete626
    Taco Pete626 Well-Known Member
    Peter
    Southern California
    2013 Regular Cab 5-spd (Sold )
    - Undercover Flex tonneau cover - Pop N Lock tailgate lock - Weathertech DigitalFit floor liner - Sick Speed Ol' Skool white shift knob - Bench seat mod - Wiper mod - Cruise control mod
    I try to keep my cruising and shifting speeds simple:
    1) 1-10 MPH
    2) 10-20 MPH
    3) 20-30 MPH
    4) 30-40 MPH
    5) 40+ MPH
  11. Feb 7, 2016 at 9:18 AM
    Indy
    Indy Master of all I survey.
    3rd untIl 60ish, 4th until whenever, 5th if i feel like it. I won't bog my engine down, they work better for longer working as designed. Using the gear needed for the job at hand instead of worrying about speed imo.
  12. Feb 7, 2016 at 10:24 AM
    Taco Pete626
    Peter
    Southern California
    I agree, shifting by feel is probably the best way.
    It's nice to know what speeds each gear is good for, especially for down shifting.
  13. Feb 7, 2016 at 10:53 AM
    Taco302
    Taco302 Well-Known Member
    Greenbow, Alabama
    2003 2.7L 5 spd 4x4 xtracab
    This is pretty much how I shift as well..there are exceptions but in most scenarios this is it (flat roads, rural area here). I also hate 25 mph zones, 3rd is too low and 4th is too high.
  14. Feb 8, 2016 at 7:53 PM
    Hartford
    Hartford Well-Known Member
    Maine
    2011 Acc Cab 5spd
    That's how I used to drive mine when it was stock. Best tank ever was 26mpg. Went just over 45o miles before the low fuel light came on.
  15. Feb 8, 2016 at 8:00 PM
    Mobtown Offroad
    Mobtown Offroad Boss
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Right around 5500rpm always becuase racecar!
    When I had it:
    Without pulling the trailer I shift around 2000-2500 all gears. Pulling the trailer loaded I shift around 4500 because it's a pig and loses a lot of momentum between gears.
  16. Feb 9, 2016 at 10:12 PM
    TRDCal
    TRDCal Well-Known Member
    Canada
    2018 DCSB Sport MT
    Still getting use to mine but 2500ish seems to be what the truck likes. Started out shifting at 2000 rpms but I found it struggling a bit so the higher rpms make for a smoother go and it doesn't seem to effect mpg.
  17. Feb 11, 2016 at 2:14 PM
    Tom2506
    Tom2506 Member
    Tom
    Rhode Island
    2014 std cab 4x4, 4cyl, 5 spd
    None
    1st-2nd : 10mph
    2nd-3rd : 20mph
    3rd-4th : 30mph
    4th-5th : 40mph
    all of thes are averages for me. They net me 25mpg highway/22mpg in town.
    I agree with it's a "feel" thing.
    Thanks, Tom
  18. Mar 26, 2016 at 8:42 AM
    clickws
    clickws Well-Known Member
    South Carolina
    1999 Toyota Tacoma Xtra Cab 4x4 2.7L 5-Speed All Manual
    Stock Alloys w/ 31.5x10.5x15 (Previously Black Pacers w/ BFG KM2 32xx11.5)
    It should give recommendations in the owners manual. My '99 Tacoma 3rz:
    1st (0-15)
    2nd (15-25)
    3rd (25-40)
    4th (40-65)
    5th (45 +)
    002yota likes this.
  19. Mar 27, 2016 at 5:32 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I try to shift around 1500 rpm. Granny shift as much as possible. I don't see the point in revving the shit out of it. It gets me there.... eventually.
  20. Mar 27, 2016 at 5:34 PM
    silverpataco1968
    silverpataco1968 Tomorrow isn't Promised!
    Eric
    Eastern PA
    2007 DCSB and 2016 DCSB TRD Off-Road
    Plenty of great products so far !
