What speed do you shift your 5-speed M/T at?
Discussion in '4 Cylinder' started by Greg617, Jan 28, 2016.
  1. Mar 29, 2016 at 11:46 AM
    Gasturbine
    Gasturbine Well-Known Member
    Central Ohio
    2011 Regular Cab 2.7l 5-speed 4WD
    32" BFG KO tires on MT rims, Front lifted 2", N-Fab 12,000lb front pull point w/10,000lb red clevis, mud flap delete, tail pipe delete, 20" LED light bar, 2 Hella 500s, N-Fab light bar mount, tinted windows.
    You can really shift by speed all the time. If your going up a grade, or nerging on a short ramp, it will be different every time.
    I do know that I rarely, if ever, go over 3k rpm.
  2. Mar 29, 2016 at 11:51 AM
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    I shift at 3k rpm usually. If I'm particularly feeling the need to save gas I'll shift at 2.5k
    5th depends on so many variables. If I'm on the road going down hill or on a flat road and I could get away with 5th I'll use it. Otherwise if I'm on the high way I go with the same rule as above. If rpm is lower than 2k in 5th I won't be able to maintain the speed
  3. Apr 25, 2016 at 8:23 PM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    I have a 2004 4X4 2.7. The owners manual states the speeds and every one of them amounts to 2500 RPM except for 5 where they say to shift to fifth at 60mph. At the elevation I live at (6500+) that just doesn't work when merging onto an interstate when the on ramp is a hill. I'll take it to 3000 rpm or more before I shift to 5th. Other than that the 2500 rpm shift speed works just fine. I can't remember the speed for 1st (I think 15 mph) but second is 25 mph, 3rd is 40 mph and they say 4th is 60 mph. I basically drive around at 2000-2500 rpm around town and 2500-3000 out on the interstate but we have 75-80 mph speed limits here. I'm a firm nbeliever that lugging an engine is just as bad as revving it all the time so since my truck has almost no power below 2000 rpm I keep it there or above except in 1st or 2nd gear.
  4. Dec 22, 2016 at 5:24 PM
    beanulous128
    beanulous128 Well-Known Member
    zach
    Yellville
    2012 TRD Sport DCSB
    With where i live its so hilly i cant hardly ever use 5th gear. Theres a hill everywhere you go
    Mazdadan likes this.
  5. Mar 1, 2017 at 4:23 PM
    JAMES399
    JAMES399 EL CAPO
    JAMES
    Alejandria Antioquia Colombia S.A.
    White 2003 Hilux DCSB 4x4 HI-RIDER +. 2.4L I-4, 5 spd.
    275/70R16 tires, gasolina or CNG fuel, Konig shox, Energy Suspension poly bushings,
    We drove from Medellin Colombia to Quito Ecuador and to Esmeraldas on the Pacific a couple of weeks ago. My 2003 Hilux DCSB 4x4 has a 2.4 2RZ-FE (that's how they sell them in Colombia) that runs on Gasoline or LNG. First time in the truck on a long trip. In the mountains from Medellin south to the frontier I learned to shift at 3500 so the rpms would not drop below 2000. Under that the motor had zero torque. When passing, sometimes hit 5000 rpm. Truck accelerated a little better in the hills on gasoline. In Ecuador, the highways were world class ... built to US interstate standards. Gasoline was $1.48 USD/gallon !! Everything there was so inexpensive due to the strong dollar (USD is the currency there.) Someone with a $2000/month pension could retire there and live like a king. But it's still Ecuador, and not much else good to say about it. I'll take Colombia anyday.
    - JAMES
  6. Jan 2, 2022 at 2:21 PM
    002yota
    002yota New Member
    Manual 97 Tacoma regular cab
    Im looking at this forum cause im new to manual and I I listen to the tranny but the problem is some of use don't have a tac so we're shifting by sound and gauging by speed as well pike for me I generally shift into 2nd around 15-20mph 3rd at around 25-30 mph 4th around 35-40 mph depending on how the transmission sounds but when I go above fourth it sounds fine like I don't need to shift till about 55
    Greg617[QUOTED][OP] likes this.
  7. Jan 2, 2022 at 2:24 PM
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    Shift when the truck tells you to, not an arbitrary number on the speedo or tach. All depends what and where. In no hurry and flat land, I shift a lot sooner. In the hills, in a hurry, under a load, etc. I shift a lot higher. Shift points anywhere from 2000-3600rpm for most driving.
  8. Jan 2, 2022 at 6:48 PM
    002yota
    002yota New Member
    This actually helps a lot for my situation thank you my truck do sent have the owners manual anymore so Im like freaking out when I should shift to 5th cause im new to manual so thank you
  9. Jan 15, 2022 at 9:22 PM
    Saintjoeqb
    Saintjoeqb Member
    Joe
    2006 Toyota Tacoma Regular Cab 2.7L I-4 RWD 5 Lug
    In the owners male the recommended shift speeds are as following:
    1st to 2nd: 15mph
    2nd to 3rd: 25mph
    3rd to 4th: 40mph
    4th to 5th: 45mph
    I find this is pretty accurate for most occasions, however I do feel shifting from 3rd to 4th at 35mph feels much smoother and better. Your shifts should be based off FEEL and conditions.
  10. Jan 25, 2022 at 6:24 PM
    Luke-Maine
    Luke-Maine Well-Known Member
    Luke
    15' White 2wd Access cab, 5 lugger
    Led Reverse Lights, Hitch, Foglights, K&N Air Filter.
    I drive the shit out of mine, nearly redline for 1/3 of shifts, well into 3-5k rpm 80% of the time. freeway is 75-90 mph and i do 20 mpg. one of the good things about an NA 4 cylinder is that your driving doesnt affect MPG as much. Im only losing 2-3, in a v8 you can lose 5-8 mpg driving like that
    Saintjoeqb likes this.
  11. Jan 31, 2022 at 9:04 AM
    Saintjoeqb
    Saintjoeqb Member
    Joe
    Really? I hate the feeling of being in high rpms in my Tacoma, I like to keep the rpms low besides when accelerating fast. Usually when I get in high rpms I can smell like a burnt rubber smell. Nothing is wrong with my truck though.
  12. Feb 13, 2022 at 9:15 PM
    Mazdadan
    Mazdadan Well-Known Member
    Dan
    BONES JONES
    I hardly use 5th outside of flat interstate traveling. I used to more but after messing around for awhile I get the same 20-21mpg even when cruising at 3k
  13. Jul 30, 2022 at 5:25 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I down shift when slowing down instead of using brake - I think the motor doesn't use fuel during this - Is this correct ? Thanks for any reply.
  14. Jul 30, 2022 at 5:30 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I always went by sound, feel, and driving conditions.
    mistermanny and Bishop84 like this.
  15. Jul 30, 2022 at 5:38 PM
    #35
    Bishop84
    Bishop84 Well-Known Member
    I read the manual for my 90s Toyotas and disagreed with all the suggestions haha
    Shift by feel. All day every day.
    the idea is to get to top gear as efficiently as possible.
    the 4 banger likes revs and doesn’t like to lug. I’d probably shift it 3000 ish or higher.
    TnShooter[QUOTED] likes this.
  16. Jul 30, 2022 at 5:43 PM
    #36
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    1st- 15 mph
    2nd- 30 mph
    3rd- 50 mph
    4th- 60 mph
    5th- 75mph
    this is assuming getting on highway/preparing to. Around town I'll short shift every 10 mph or so.
    Edit: My truck is 2wd and we think the rear end ratio is roughly 3.12 or whatever that longest geared option was. It'll do 70 in 2nd.
  17. Jul 30, 2022 at 5:55 PM
    #37
    TnShooter
    Deogee
    STOCK
    I owned a Porsche 944 once.
    The only thing they told you were maximums. :rofl:
    But I agree the 2.7 doesn’t like to lug.
    I’d say my shift point were closer to 3k than 2k. My Uncle ran a cattle farm, he used Toyota Puckups and Tacomas. He always said, these trucks aren’t tractors. Don’t lug them. All of his had well over 200k one them one was at 310k+ Plus when he sold it.
    Obviously he had large diesel trucks for hauling. But 90% of the time, we were in a Toyota.
    Stelcom66 likes this.
  18. Aug 7, 2022 at 4:05 AM
    #38
    bringenufgun
    bringenufgun Well-Known Member
    Bill
    OFallon Mo.
    14 Tacoma regular cab 4X4
    none
    2K on the tach. 55 mph on the interstate occasionally 60 mph. my mpg went from 19 to 24-25 mpg. till gas goes down more than it is now.
  19. Aug 7, 2022 at 4:39 AM
    #39
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    If I had a 5spd.
    Start off in 2nd unless loaded
    Shift to 3rd at 4200rpm
    3rd to 5th at 4200rpm
    5th to 4th at 3500rpm for passing
  20. Aug 12, 2022 at 10:09 AM
    #40
    Stelcom66
    Stelcom66 Well-Known Member
    2007 2.7L 5MT 4WD
    Join the club. I tend to shift a couple miles per hour above what the manual says. It states I believe 37 mph from 3rd to 4th, I typically shift around 40 mph. From 4th to 5th I'll typically closer to 50 mph, I think the manual recommends 45.
    Not good to over-rev of course, but probably lugging is worse. Because your uncle didn't lug his Toyotas could be a factor why they got up to those high miles. I do like how the Tacoma 4 cylinder and 5 speed manual are geared tall, at least for a 4 cylinder. Years ago I had a 2.5L Subaru Outback with the 5 speed manual. At 65 mph in 5th it ran at 3200 rpms which was kind of annoying. I don't know why in the world that kind of gearing was chosen.
