What spindles are compatible?
Discussion in '1st Gen. Tacomas (1995-2004)' started by jmferg, Jan 14, 2020.
  1. Jan 14, 2020 at 2:21 PM
    jmferg
    jmferg [OP] Well-Known Member
    I am looking for a used set of spindles for a 2004 double cab four-wheel-drive with ABS. What other models will fit? I was under the impression that any first GEN Tacoma six lug with ABS will work
    eBay and car part.com show that first GEN sequoias, first GEN tundras and third GEN four runner spindles will fit as well
  2. Jan 14, 2020 at 2:48 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Question; why do you need spindles?
    They come up from time to time so I'd be surprised if you can't find any that are coming directly from another Tacoma.
    You can even get a pair from a Prerunner, but that'd require more work as you'd have to press in the correct wheel hub, etc.
  3. Jan 14, 2020 at 3:36 PM
    jmferg
    severe rust
    Everything was replaced with the exception of the spindles and control arms
    Kwikvette[QUOTED] likes this.
  4. Jan 15, 2020 at 2:15 PM
    jmferg
  5. Jan 15, 2020 at 3:13 PM
    UnderFire
    UnderFire Well-Known Member
    Unsure on the fitment of tundra and sequoia spindles.
    You can definitely use any 1996-02 4Runner 4X4 spindle, basically all of them (with a few exceptions) have ABS. You can also use any first gen tacoma 95-04 spindle with ABS and ADD (not manual hubs). Prerunner/2WD 4Runner spindles do not have splines for the axle.
    jmferg[OP] likes this.
