what springs for my 5100's
Discussion in 'Suspension' started by Leoffensive, Aug 4, 2012.
  1. Aug 4, 2012 at 8:52 PM
    Leoffensive
    Leoffensive [OP] Well-Known Member
    Leo
    San Diego, CA
    2007 prerunner TRD sport
    Icon 2.5 coilovers with resi, Custom OMD rear leaf pack, Pelfreybilt IFS skid, Magnaflow muffler
    i have 5100's with stock sport springs.
    i wanna get different springs to put on so i dont have to have so much preload cause its currently at 2.5
    what do you guys recommend?
  2. Aug 5, 2012 at 12:13 AM
    BillJC
    BillJC Well-Known Member
    Bill
    Novato, CA
    2011 White SR5 DCLB 4x4
    OME 884's work well which is what I run with a top plate spacer for a full 3" lift. They seem to work well with the 5100's,
  3. Aug 5, 2012 at 12:48 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    885's
  4. Aug 5, 2012 at 5:28 AM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    Ya 885s seems to be the choice for the 2.5-3"
  5. Aug 5, 2012 at 7:05 AM
    TRD6Speed
    TRD6Speed senior member
    Bill
    East Hartford, CT
    08 TRD Sport Access Cab
    885x with 5100s and top plate spacer for full 3", RCD extended 5100s in rear, dakars, flip kit, LR UCAs, tint, shorty antenna, in channel rain guards,BHLM, blacked out emblem, OEM side steps, weathertechs, debadged, rear diff breather
    x2.............im gonna run a 1/4" inch spacer on the right and 1/2" on left for the taco lean and get as close to 3" as possible.
  6. Aug 5, 2012 at 7:10 AM
    greenrustic
    greenrustic Well-Known Member
    NY
    2012 DCLB 4x4 TRD SPORT
    Access LTD Tonneau Cover, Weather Tech Digital Fit Mats, Weather Tech Rain Guards, 35% Tint up Front, AFE Dry Power Intake Filter, Debadged, GrilleCraft, OME 884x, OME 9000 NitroChargers, Icon 3 Leaf Progressive AAL
    Eibachs from toytech are designed to work with the 5100's
  7. Aug 5, 2012 at 7:12 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    x2. 884's for just over 2" of lift, 885's for closer to 3" of lift with your prerunner.
    That they are... but they're a stiff coil and have to be preloaded to get 2.5" of lift.
  8. Aug 5, 2012 at 7:33 AM
    Pugga
    Massachusetts
    F-150 Mod
    Preload is compression added to the coils before putting them on the truck. The 5100's have 4 settings, 0, .85, 1.75 and 2.5. At 0, that's no preload. Any of the other settings pre-compress the coil to provide lift but the trade off is you essentially have a stiffer coil.
    For the SR5 and TRD Sport coils, the preload isn't as bad. TRD Off Road coils are progressive so when you preload them, they become much much stiffer than stock and can make for an unpleasant ride. Safety-wise, you can preload any of the coils to 2.5. For ride comfort, I wouldn't preload TRD Off Road coils past the 1.75 setting.
  9. Aug 5, 2012 at 7:41 AM
    Gotcha88
    Gotcha88 Well-Known Member
    CA
    2012 DCSB PreRunner TRD Sport
    Bilstein 5100s all around, Toytec Eibach coils, Toytec 1.5" AAL, Light Racing UCAs, 285/70r17 Nitto Terra Grapplers, 17x9 Eagle 185s, 20% tint all around, Magnaflow 11256, Cobra CB with 2' Firestik, De-Badged, BHLM, UltraGauge, K&N Drop-in, OEM Bed Mat, OEM All-Weather Mats.
    I just requested the shop that's doing my lift get these for me. At first the manager seemed pretty reluctant seeing as Eibach only sells them to Toytec. After calling his buddy over at Eibach though, he wouldn't let me order any other spring.
  10. Aug 5, 2012 at 7:42 AM
    maxpower29
    Jordan
    Nova Scotia, Canada
    .85 with the Eibachs is the most. 0 with the OMEs
  11. Aug 5, 2012 at 7:43 AM
    Pugga
    Massachusetts
    F-150 Mod
    Why wouldn't be let you get any other spring? Did he give a reason? Sounds like he just fell for the sales pitch hook, line and sinker... There are a lot of other options out there as good or better than Eibachs.
  12. Aug 5, 2012 at 7:57 AM
    Gotcha88
    CA
    Well after he said they could only get them from Toytec, I assumed he wouldn't want to so I asked what he'd suggest that he could get from his suppliers. He said something along the lines of, he spoke to Eibach and even though it's more of a pain in the ass getting them from Toytec, "they really have something that works" as the springs are made solely for Toytec. I'm in no way saying others are inferior, I would've gone OME in a heartbeat, just interesting to hear a salesmen support the harder/more spendy option after he did some research.
  13. Aug 5, 2012 at 8:18 AM
    Pugga
    Massachusetts
    F-150 Mod
    Yes, they'll be fine.
    I was just curious of his reasoning. I have Eibachs, they're a decent coil for the money but I wouldn't omit others, I just found a good price on them :D
  14. Aug 5, 2012 at 8:26 AM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    I noticed very little diff. In ride quality from 1.75 with sr5 coils to 0 setting and 885s for what it's worth
