What Springs to run with 5100's
Discussion in 'Suspension' started by Scottdl99, Dec 24, 2009.
  1. Dec 24, 2009 at 10:47 AM
    Scottdl99
    Scottdl99 [OP] Well-Known Member
    Indianapolis
    06' DC
    5100's w/884's @0, Sliders, Headlight bake w/eyelids, Rears blacked,5% tint. AFE Pro dry S, All LED interiors, Sridertrax, a few more
    I have a 98 4x4. I just replaced the rear shocks with the 5100's and gettting ready to install a Skyjacker TRC25S 2.5" leaf pack. I have the adjustable 5100's for the front and I know my spring's are shot. I have been looking at the Old man emu springs b/c they are in my budget. I plan on getting a brush guard or bull bar eventually on the front end. Should I get the the 880 881 or 882's? Also once you suggest one please let me know what to set the billy at when I install everything to achieve a level look.
    Thanks in advance!!
  2. Dec 24, 2009 at 10:55 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  3. Dec 24, 2009 at 10:57 AM
    Scottdl99
    Indianapolis
    06' DC
    Can I ask why? and what would I want to set the billy at?
  4. Dec 24, 2009 at 10:58 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You should leave them at the 0" seting, unless they sag. The 882's are designed to give lift, with a heavy bumper.
  5. Dec 24, 2009 at 10:59 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Oops.....You said Bull Bar,...They are not heavy. You could go with the 881's if you wanted
  6. Dec 24, 2009 at 11:22 AM
    Scottdl99
    Indianapolis
    06' DC
    So if I run the 881's where should the billys be set at?
  7. Dec 24, 2009 at 11:25 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i run 881's on my 04 double cab...gave me 2 inches in the front...bilstein 5100's set at stock height(bottom clip)........and i have a brush guard(cheap kind)....now if you are getting a plate bumper..that'll make a difference....get the 882's for the weight of the bumper.
