What starter should I get?
Discussion in '1st Gen. Tacomas (1995-2004)' started by yellowdog5, Apr 4, 2021.
  1. Apr 4, 2021 at 2:05 PM
    yellowdog5
    yellowdog5 [OP] Well-Known Member
    2002 Tacoma SR5 4wd 2.7L
    I have a 2002 SR5 4WD 2.7L, I am needing to replace the starter, I want a good one for as inexpensive as possible, what should I get? Is OEM recommended? I have access to NAPA, O'Reilly's and Autozone locally.
  2. Apr 4, 2021 at 2:15 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    OEM. My toyotas seem to reject parts store grade parts. Depending on how many miles you have and if it's original, OEM would be the cheapest long term despite being the most expensive upfront. You could also try rebuilding it yourself, k never did it but heard it's easy.
    Black97v6MT and vettehigh like this.
  3. Apr 4, 2021 at 2:30 PM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    I got one from Napa like 130k ago and it’s still functional
  4. Apr 4, 2021 at 2:44 PM
    yellowdog5
    Okay and does it matter what fuel filter I get? Hard to find OEM locally.
  5. Apr 4, 2021 at 3:04 PM
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    I just replaced my third starter a month ago on my 1996 4x4 2.7 with 414,000 miles on it. My first replacement was a 'lifetime' warranty starter from Advance Auto so my last replacement was no charge for the starter.
    Black97v6MT likes this.
  6. Apr 4, 2021 at 4:15 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Get new brushes and plungers from NAPA to replace ones in your starter.
    Good as new and cheaper too.
    Key-Rei, yellowdog5[OP] and boston23 like this.
  7. Apr 5, 2021 at 1:42 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I bought a reman from Toyota Cost I could live with Core charge cheap enough to eat.
    I now have a Spare Starter
    Black97v6MT and yellowdog5[OP] like this.
  8. Apr 5, 2021 at 2:11 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    As someone else said rebuild your OEM starter. You can get the brushes and such from Toyota for a few bucks, cheaper than you can buy an aftermarket unit and it's pretty easy.
    As for filter OEM if you can I mean the original lasted you how long? I don't remember them being that expensive either.
    If not Napa Gold should be plenty fine I believe that's what URD uses in their upgrade kits recommend for forced induction.
  9. Apr 5, 2021 at 7:55 AM
    yellowdog5
    I'm unable to do the replacement myself, the mechanic is wanting to use autozone parts, I don't want to rebuild it now I am too unsure of how to do it. It doesn't look like a new oem is readily available, only rebuilt ones, any suggestions on where to get one? The other thing I am thinking is using NAPA stuff, their stuff has always done us well. Any opinions on autozone?
  10. Apr 5, 2021 at 7:59 AM
    OpeCity
    Long Beach, CA
    It will be fine with an AZ part
  11. Apr 5, 2021 at 8:10 AM
    yellowdog5
    I just found that NAPA has remanufactured Denso starters, would they be better than a new autozone one?
    phoenix ray and rocknbil like this.
  12. Apr 5, 2021 at 8:12 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    What parts your mechanic wants to use does not matter.
    It is your truck and your money. If you want an OEM starter, then the mechanic needs to install an OEM starter.
    YOU have the final say about what goes on your ride.
  13. Apr 5, 2021 at 8:12 AM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Reman Denso. For my Lexus was $120. Cheap and effective.
    vettehigh likes this.
  14. Apr 5, 2021 at 9:25 AM
    OpeCity
    Long Beach, CA
    Not to be a dick, but it’s just a starter. You’ll be fine with almost any reman.
  15. Apr 5, 2021 at 11:24 AM
    Bluecord
    Bluecord Well-Known Member
    Jeff
    Louisiana
    2003 Tacoma 4x4 TRD Lunar Mist Metallic
  16. Apr 5, 2021 at 12:57 PM
    yellowdog5
    Yes I'm going to go with OEM, it seems to be the most highly recommended.
    Since I need to hire someone to install it I want one that will last another 125k at least.
  17. Apr 5, 2021 at 1:08 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    I think my NAPA starter has 10+ years on it
  18. Apr 5, 2021 at 1:25 PM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    O-reilleys fuel filter and starter (whatever brand they had) with 155K on those parts. No problems yet.
  19. Apr 5, 2021 at 4:10 PM
    yellowdog5
    Sounds like they're all good, I found a Denso at Napa, and a Napa gold filter. Thanks everyone!
  20. Nov 20, 2023 at 6:27 PM
    PandaYota
    PandaYota Well-Known Member
    Isaac
    Layton Utah
    2006 Toyota Tacoma Base
    3in lift with ICON shocks. Warn Winch. Many more mods to come.
    How long your second starter last and was it a Bosch one?
