What subs/box/amp to get
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Austin4x4taco, Mar 29, 2016.
  1. Mar 29, 2016 at 4:00 PM
    Austin4x4taco
    Austin4x4taco [OP] Member
    2006 tacoma 4x4 sr5
    so i recently bought a 2006 4x4 double cab tacoma. I just had a new deck installed and ran rca's for subs to the area behind the rear seats. I am thinking about buying R/T Dual 10-Inch Toyota Tacoma 2005 - 2011 Dual Cab Sealed Speaker Box https://www.amazon.com/dp/B0057Y8KF6/ref=cm_sw_r_cp_awd_RIW-wbVRNX3Y0 this box and have no idea which subs/amps to buy. I have the factory jl audio and just want something to kick pretty good back there, nothing too crazy that will break the bank. Any ideas/advice would be greatly appreciated.
    Thanks
  2. Mar 29, 2016 at 6:13 PM
    Monster1088
    Monster1088 Active Member
    Arizona
    2019 DCSB OR Tacoma
    I had the same box and it worked pretty good in my 2015 dcsb. I don't have it any more but I had two 10" JL Audio 10WXv2-4 with a cruddy boss amp that worked ok. Sound was good and hit pretty decent. Just make sure your mounting depth is less than 5 1/2" or shallow mount subs. I use this site http://www.sonicelectronix.com/ . They have decent prices and you can pair amps to subs which makes it easy. Crutchfield is another good site to look at.
  3. Mar 29, 2016 at 6:17 PM
    ManBeast
    ManBeast Well Feared Member
    Zach
    Orange Park FL
    2015 DCLB:TOTALED-> 2014 4R TRAIL
    Crutchfeild over charges for everything. Sonics is where its at. Read reveiws on everything you think about purchasing as well. And as far as amps and subs ignore "peak" wattage. And focus on rms. 2 200 watt rms subs match an amp of 400 watts rms .Get it?
  4. Mar 31, 2016 at 10:33 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  5. Mar 31, 2016 at 11:22 AM
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    Where did you guys with the JBL Audio relocate your factory amplifier?
  6. Apr 8, 2016 at 2:18 PM
    Austin4x4taco
    2006 tacoma 4x4 sr5
    Pulled the trigger on that box, 2 alpine 10" shallow subs and a boss 3000 watt amp, hope it turns out well
  7. Apr 8, 2016 at 2:20 PM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    Do yourself a favour and RETURN THAT BOSS POS before it burns your truck down or greatly disappoints you
  8. Apr 8, 2016 at 5:24 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    x2. BOSS is a very mediocre brand. If you're doing a build on a budget, it's great. You're clearly not since you sprung for Alpine. I highly recommend getting a better amp. I'm rocking Rockford Fosgate in mine.
  9. Apr 8, 2016 at 10:26 PM
    Austin4x4taco
    2006 tacoma 4x4 sr5
    Have to return it anyway, no room to fit it anywhere without major modification, and tips on a good amp around 2000-3000 watts for around $120?
