what suspension for my needs
Discussion in 'Suspension' started by roccowolf, Nov 2, 2014.
  1. Nov 2, 2014 at 4:49 PM
    roccowolf
    roccowolf [OP] Member
    st. louis
    2015 TRD 4x4
    2015 TRD 4x4, Automatic, 6 cylinder. Hello all, just joined the group due to buying a new Taco. I could use some advice. The truck will be driven on road only. I would like to lift the truck around 3" and fit it with 33" tires. I need the rear suspension to be stiffer for hauling and towing once in a while. The rear suspension is too soft. I loaded the bed with luggage and rear was already sagging. I do want to keep the suspension as comfortable as possible. Thank you in advance for any advice offered.
    3" lift and 33" tires is only a guess or average. I am not familiar with these trucks and can use all the help you can offer.
    Lou
  2. Nov 2, 2014 at 6:04 PM
    Ihatetacomas
    Ihatetacomas Because tacomas hate me
    Dylan
    Elko NV
    '12 White LB TRD Sport
    Used @ 23,283 Volant Intake (w/ scoop)(removed August 2016), BAKFlip G2 Tonneau Cover, (drain tube mod), Pop & Lock Tailgate Lock, Stampede Vigilante Premium VP Series Hood Protector, 5lb Extinguisher, Shovel & Axe mounted in bed, Shok Industries Sound Deadener, Mercury: (K62, MGR-1200, MGR-495) Triton 8" Subs, Custom-Made: Sub Box, Speaker Templates, Vapor Barrier, All-Pro Bumper w/Kickouts, hidden trailer hitch, wooden cup-holder Misc: Knukonceptz RCA, speaker, and power wires, Big 3 Upgrade, a very full Husky technician tool box
    What are you going to be using your lift for? Off road or in town mostly?
  3. Nov 2, 2014 at 6:10 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    It states on the road only.
  4. Nov 2, 2014 at 6:16 PM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    For on road only you can always use the 5100's with either stock coils or eibechs and an AAL for the rear.
  5. Nov 2, 2014 at 6:34 PM
    zboy
    zboy Well-Known Member
    Oahu808
    12 TRD OR
    welcome...What is your Budget ?
  6. Nov 3, 2014 at 10:21 AM
    roccowolf
    st. louis
    2015 TRD 4x4
    He was right. All on road use. Lift is for looks only, the wife actually wants it lifted, I can care less. But I didn't want to lift it and still have a soft rear suspension. I wanted the rear suspension a little stiffer for towing and hauling once in a while. So just adding blocks won't work. I need to alter the suspension. I do not want to put a lot of money into this. I was thinking AAL, but I have never done that. Usually change the entire suspension. But that was in muscle cars. I never altered truck suspension for lifts.
    AAL doesn't sound bad, just wanted other opinions. If I add AAL in rear do I go with coil over in front? Then what else is needed, extend break lines, change pinion angle, etc.?
  7. Nov 6, 2014 at 8:24 AM
    Str8Flexin
    Str8Flexin Well-Known Member
    SoCal
    1998 Taco SAS linked Crawler
    Lots of stuff
    Check out our (All-Pro Off Road) rear Expedition Leafs More heavy duty for bigger loads and give you the lift that you are looking for. You can also match it in the front with a set of new coil overs from us!:goingcrazy::goingcrazy:
  8. Nov 6, 2014 at 8:28 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    You'll want a new pack in the rear as it is the best option. Yota leafs suck. I had an AAL in there when I did my suspension and it rode like crap. It only lasted 3k miles. I now have the Dakar leaf pack plus the D29XL leaf in there. Love it.
  9. Nov 6, 2014 at 8:29 AM
    geekhouse23
    Keeper! rare breed :cheers:
