What suspension / lift is best for 33” wheels ?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jmichaelh7, Nov 21, 2017.
  1. Nov 21, 2017 at 11:17 PM
    Jmichaelh7
    Jmichaelh7 [OP] Well-Known Member
    Joe
    2017 Tacoma TRD Sport
    This sounds redundant but I have yet to find a solid answer. Some say the coil overs but in order to clear you need to max out the settings and then the ride is rough. What about spindle lift? Level kit? I’m not going to off road I want to still lift it and put 33, 285 tires and have a smooth ride. Anyone have any 2 cents to share ?
  2. Nov 21, 2017 at 11:33 PM
    liquidhazelnuts
    liquidhazelnuts Well-Known Member
    2017 Tacoma TRD Off Road Quicksand
    Coilovers. Body Mount Chop. 285/70's. Call it a day.
    HutchJ and inwood customs like this.
  3. Nov 21, 2017 at 11:34 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Does sound familiar lol
    https://www.tacomaworld.com/threads/what-kind-of-lift-and-tire-setup-do-you-have.519995/
    No to spacers
    No to blocks
    2wd or 4wd?
    You have a spindle lift avail for 3rd gens already?
    Yes to coils and progressive aal
    How much cutting ya gotta do to be able to turn with thems tires?
  4. Nov 21, 2017 at 11:35 PM
    inwood customs
    Dave
    Thats a good 2 pennies in my opinion.... my opinion worth remains to be seen tho
  5. Nov 22, 2017 at 9:27 AM
    Jmichaelh7
    Joe
    2WD . It won’t be going off road obviously . But I’d like to put 33s. So coilovers. That would be a rough ride on the maximum setting , in order to fit 33s right
  6. Nov 22, 2017 at 9:29 AM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    I perfer to just cut a 2x4 and use it as spacers and blocks. Better than anything on the market :amen:
  7. Nov 22, 2017 at 9:30 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    People seem to like the 5100's and OME coils option. Don't run the OME coils on the 5100's at anything other than 0. Rear setup depends on it you tow or haul any weight. AAL is a bad idea. Progressive AAL pack is better, but the best option is a new leaf pack. If you are looking for something a little more custom, Deaver would be your best bet.
  8. Nov 22, 2017 at 11:39 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    This is not true, well not completely true.
    Coilovers get cranked up a little bit yes, which is what lifts the vehicle but they aren't maxed out. I could actually crank my coilovers up so much they wouldn't even fit the vehicle anymore. You do lose a bit of downtravel but shouldnt affect everyday driving. With a 2 3/4" lift up front, my ride significantly improved over stock.
    It all depends on budget and what you buy
  9. Nov 22, 2017 at 12:02 PM
    Jmichaelh7
    Joe
    What are you running and your tire size? Do you have a pic
  10. Nov 22, 2017 at 12:05 PM
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    Coilovers with the properly sized and rated coils will give you the lift you want without having to rip down on the preload ring as youre referring to, keeping the shock within its intended travel range instead of having the shock be maxed out in its travel all the time because you cranked it (the shock) up by cranking down the preload adjustment ring. Give Accutune Offroad a call and ask them what setup you should go with to clear 33s if you want a quick, accurate answer would be my .02
  11. Nov 22, 2017 at 12:07 PM
    doorsidedown
    doorsidedown Well-Known Member
    I’m running 285/75/16 with icon coilovers and total chaos UCA. 2.5” of lift and no rubs. Do the cab mount chop or (CMC) to be sure. It’s easy and cheap.
  12. Nov 22, 2017 at 12:07 PM
    JoeCOVA
    Joe
    Colorado Springs
    33's are hit and miss on rubbing. some people rub and some people dont. I think the variable is how much you flex your truck and go offroading. Most daily drivers and mall crawlers have little to no rub.
    That said I am on the stock 265/70/16s. I havent upgraded because the wheels arent in and no point in mounting new tires to the stock rim, ill just sell them whole
    I will upgraded to 285/75/16s with a Stealth Customs SR8 wheels w/ OMF Beadlocks these are a 16x8 -12mm offset and 4.00 backspace.
    These will likely rub the cab mount and I will perform a CMC. Front inner fender I will remold with a heat gun because it will likely rub there.
    Most 285/33's that people upgrade to are E-rated. E rated tires will give you a rough ride.
    stevotivo12 likes this.
  13. Nov 22, 2017 at 12:09 PM
    doorsidedown
    This is true... I opted for a D rated tire and they’re much nicer for a Tacoma than an E rated tire.
    JoeCOVA[QUOTED] likes this.
  14. Nov 22, 2017 at 12:11 PM
    RenoTacoma
    RenoTacoma Petrol head
    Sloan
    Reno, nevada
    09 Base 4x4 Tacoma
    3.5" lift 285/70/17
    285/70/17s on King 2.5s. Some rub offroading but I also have not done the cab mount chop yet.
    Edit: I can't read, this is on a 2nd gen
  15. Nov 22, 2017 at 12:12 PM
    Clearwater Bill
    Billy
    Largo Florida
    255 x 85 x 16 or 255 x 80 x 17, OE TRD 4 runner wheels.
    Full 33, no lift at all. No rub, no cut. Nice full wheel wells. Lots of sidewall for road cushion.
    It's the wheel fitment and tire width that make the difference. There are threads around here you can look up for specifics, as I may have gotten the particular model wheel incorrect.
