What the deal with the drum brakes?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MachoTaco10, Mar 17, 2010.
  1. Mar 17, 2010 at 11:15 AM
    MachoTaco10
    MachoTaco10 [OP] Well-Known Member
    Nick
    New Hampshire
    2010 Tacoma TRD Sport
    What is the deal with the taco still having drum brakes? Come on toyota is about one of the last companys still installing drum brakes on their cars. Besides like chevy aveos and ford fukus's not many vehicles manufactured with drum brakes.
    Now dont get me wrong drum brakes arent all that bad, but do have less stopping power than discs and a bitch to change. w/e just my 2C
  2. Mar 17, 2010 at 11:37 AM
    JKD
    JKD Well-Known Member
    No they don't. You can build disc or drum brakes to any specification.
    The one major area that disc brakes do better at is heat dissipation. Have you had problems with rear brake fade? I sure haven't.
    The other area discs do better in is adjustment. Discs adjust continually by the nature of the design. Drums have mechanical adjusters that can get bound up and need cleaning.
  3. Mar 17, 2010 at 11:40 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    Parking brakes - hold better with Drums
  4. Mar 17, 2010 at 11:41 AM
    MachoTaco10
    Nick
    New Hampshire
    I have not had problems with my 2010 tacoma as it is new, but I have had problems with brake fade, adjustment and stopping a 16ft car trailer i use to tow my wheelin rig in my 4x4 ranger. I converted the rear to discs on the ranger and it was at least 2x better at braking.
    Trust me when coming down a sharp hill with 5000lbs + behind you those brakes start to scream, and heat up like a mofo. The drums have little to no way of venting this heat.
    I have not towed my trailer yet with this tacoma, but we shall see my friend.
  5. Mar 17, 2010 at 11:45 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    If it ain't broke...don't fix it.
    Besides.... if they moved to discs in the rear, they'd have to redesign everything else (master caliper, proportioning, ABS, programming, yadda yadda yadda).
    Give 'em time.... Everything will have discs eventually. The brakes are fine (although everyone complains about them anyway :rolleyes:).
    With all the stuff going on right now with Toyota....I think disc brakes are the last concern on their list of things to do.
  6. Mar 17, 2010 at 11:49 AM
    Janster
    Jandy
    Lancaster, PA
    Does your trailer have brakes? Perhaps they need to be adjusted to apply more braking??? If the trailer brakes are setup properly (via brake controller), the vehicle doing the towing shouldn't have any problem with braking.
  7. Mar 17, 2010 at 11:49 AM
    wiscdave
    Northern Wisconsin
    Tundra Rock Warrior
    Don't you have trailer brakes? DO they work?
    You should probably have trailer brakes for that load, every truck is going to struggle given that load.
  8. Mar 17, 2010 at 11:53 AM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
    I know drum brakes work fine, but by 2010, every new car and truck should come with 4 wheel discs. JMO.
  9. Mar 17, 2010 at 11:53 AM
    10silvertaco
    10silvertaco Well-Known Member
    Brent
    no longer own Tacoma, now own 2011 Outback
    I too have same concern in the past. Now my 2010 is almost 15,000 miles. I have tow 4,500 pounds and had no problem with brakes on downhill. As long before going downhill, change your shift to lower gear.
    I was on the street, somehow the taco dog run on the street quick. I slam my brake and it didn't hit the dog. I slam the brakes some other time when stupid driver did not pay attention to other car ahead of them or talking on the damn cell phone.
    Drum brakes on tacoma suit me fine. I would like to have 4 disc brakes but I get used to it.
  10. Mar 17, 2010 at 12:09 PM
    flatlander
    flatlander Well-Known Member
    09 DC-LB 2WD Prerunner V6 Auto
    I think the taco's stop ok. But my reason for discs is the ease of changing out pads vs. shoes.
  11. Mar 17, 2010 at 12:18 PM
    Tillers_Rule
    Tillers_Rule ......................
    Jeff
    San Diego
    4x4 Sport, debadged
    Icon coil overs up front, Total Chaos UCA, Icon remote reservoir in the back with Deaver 11 pack leafs. Sunroof, Hella 500's behind grill.
    Rear disk brakes on Tacoma's are for marketing and looks.
  12. Mar 17, 2010 at 1:13 PM
    MachoTaco10
    Nick
    New Hampshire
    ya my trailer has brakes. idk maybe im just used to my ram 2500.
  13. Mar 17, 2010 at 2:03 PM
    dog tired
    dog tired Well-Known Member
    NE Ohio
    For those that actually take the Taco off road drums are better at keeping out mud and junk
    I like them
  14. Mar 17, 2010 at 2:04 PM
    dog tired
    NE Ohio
    Sports cars ok off road trucks NO
  15. Mar 17, 2010 at 2:09 PM
    dman597
    dman597 Well-Known Member
    Doug
    maryland
    2012 DC 4X4 SPORT w/Tow
    6" Pro Comp Lift,295-75-R17,access rollup,Tint,front hitch,nfab step bars
    [FONT=Arial, Helvetica, sans-serif]Drum vs. Disc: Today[/FONT]
    [FONT=Arial, Helvetica, sans-serif]In today's automotive pantheon, it's not uncommon to find four-wheel disc brakes as standard equipment on medium-priced, non performance-oriented models. The majority of new vehicles, however, continue to utilize a front-disc/rear-drum brake setup. What does this say about the current state of braking systems? Are these manufacturers sacrificing vehicle safety in order to save a few bucks by installing disc brakes on only the front wheels? [/FONT]
    [FONT=Arial, Helvetica, sans-serif]While a "yes" answer would certainly be great for increasing Town Hall traffic, the truth is that today's disc/drum setups are completely adequate for the majority of new cars. Remember that both disc and drum brake design has been vastly improved in the last 20 years. In fact, the current rear drum brake systems on today's cars would provide better stopping performance then the front disc setups of the '70s. And today's front disc brakes are truly exceptional in terms of stopping power. Combined with the fact that between 60 and 90 percent of a vehicle's stopping power comes from the front wheels, it's clear that a well-designed, modern drum brake is all that's required for most rear wheel brake duty. [/FONT]
    [FONT=Arial, Helvetica, sans-serif]High performance cars like the Viper, 911 and Corvette can justify a four-wheel disc brake system, especially if their owners participate in some form of sanctioned racing activity on the weekends. The rest of us get more of a benefit from the lower cost of drum brakes. Expecting every vehicle built today to come with four-wheel disc brakes would require an across-the-board increase in purchase price, and that could stop new car buyers much quicker than any brake system. [/FONT]
  16. Mar 17, 2010 at 2:12 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
  17. Mar 17, 2010 at 2:12 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Every vehicle I have ever owned with discs in the rear have been more trouble than they were worth. From caliper and parking brake issues to having to replace the pads nearly 3:1 compared to shoes - I'll keep the drums.
  18. Mar 17, 2010 at 2:17 PM
    Sparky4.0
    Sparky4.0 Well-Known Member
    Aaron
    WestTexas
    01 trd beat to hell
    ummm.... trailer brakes bud. :D
  19. Mar 17, 2010 at 2:18 PM
    ccoorreeyy
    ccoorreeyy www.EvolvedFinance.com
    Corey
    Los Angeles (South Bay)
    08 Double Cab 4x4 SR5 Debadged
    BHLM, Revenge Fab Rock-Sliders, BFG TA KO's, N-Fab light bar with 4 Hella 500's, Rear Suspension TSB, TRD Exhaust, CB Radio, 100W Ultra bright headlights, JBL Sound
    I don't mind the drum breaks. I just hate the way they look through my rims. I would like to dupi color them black, but I don't know if that would look good or not.
    I've towed a few times. Once pushing the wieght limits of the hitch. Gone up and down mountains. I've never had any problems.
  20. Mar 17, 2010 at 2:21 PM
    goingcamping
    goingcamping Well-Known Member
    Brett
    Colorado
    2007 Tacoma
    Custom body work...boat trailer came of hitch, hit tailgate and Rammed stick thru lower valance while towing boat....hmmm, Maybe I should get a new boat?!?
    This I disagree...discs have natural cleaning as there is no where for the crap to go but off the disc, on the converse, drum brakes' capacity is dramatically reduced when wet and once thin mud and sand get up in the drum, you can pretty much count on a rear brake job, having done a fair amount of mudding, I can say this is the case, at least for me and homeys!
    I've seen this question poised in the 4x4 magazines directly to Toyota and they say that the drum brakes are adequate for the application (paraphrasing)...that being said, as a previous poster (sorry for not quoting you!) drums can be designed to meet most specifications, within reason.
    There are advantages and disadvantages to both applications! I had a 2000 Jeep Wrangler with mild lift/tire combo and wanted to be sure that stopping when going down hill while wet was possible w/o to much a$$hole puckering..I converted the rear to disc relatively easy, came with a new proportioning valve, new rotors, new calipers and all the associated pieces and the Jeep stopped far superior (I have zero mathematical or statistical data to quote, but by seat-of-the pants testing, it seemed more better)
