what the heck is this called? (air box/MAF gasket??)
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2004prerunner, Feb 13, 2016.
  1. Feb 13, 2016 at 6:25 PM
    2004prerunner
    2004prerunner [OP] if it ain't broke, maintain it
    2004 prerunner
    this gasket sits between my MAF sensor and my air box.
    it's starting to deteriorate so i'm trying to replace it but i cannot figure out what it's called!
  2. Feb 13, 2016 at 6:28 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    yeah pretty much an air box gasket or maf gasket ill look for it for you
  3. Feb 13, 2016 at 6:31 PM
    2004prerunner
    2004 prerunner
    you would think right! but i've searched both of those things and i'm not finding what i'm looking for
  4. Feb 13, 2016 at 6:33 PM
    CodeSeven
    Serge.
    Coachella Valley
    well. you won't. it's an insignificant gasket. here's the OE number i believe. 222750C010
  5. Feb 13, 2016 at 6:34 PM
    CodeSeven
    Serge.
    Coachella Valley
    just buy some gasketing material and cut one out on your own. you have the original with a good form to it
  6. Feb 13, 2016 at 6:41 PM
    2004prerunner
    2004 prerunner
    good idea. will likely end up doing this. thanks!
  7. Feb 14, 2016 at 6:24 AM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
  8. Feb 14, 2016 at 8:22 AM
    2004prerunner
    2004 prerunner
  9. Feb 14, 2016 at 9:11 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I wouldn't call any intake gasket downstream of the air filter 'insignificant'. You don't want grit and grime getting to the throttle body and piston rings.
  10. Feb 14, 2016 at 9:25 AM
    CodeSeven
    Serge.
    Coachella Valley
    thing is, the MAF is supposed to be so well secured that nothing can get passed a crack except more air, and being before the MAF, its not an intake leak that needs to be worried about.
    If he doesnt want to cut out a paper tracing, he could put a bead of silicone on one of the surfaces, let it dry a bit, then tighten it down to make a perfect seal.
    Besides, i was calling the gasket itself insignificant, not the concept of having one between the filter and sensor :)
    tan4x4[QUOTED] likes this.
  11. Feb 14, 2016 at 9:45 AM
    2004prerunner
    2004 prerunner
    (*she, not he!)
    actually the screw holes have these elevated spacers on them that are about the width of the original gasket, so i might not be able to tighten everything down over gasket maker. though, i didn't check yesterday to see if the spacers were actually attached to the air box or not, don't remember them rattling around. will check later today though
