What the heck is this squealing noise?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sprede, Jan 9, 2020.
  1. Jan 9, 2020 at 12:48 PM
    sprede
    sprede [OP] Well-Known Member
    2007 Tacoma double cab SR5
    What is this sound? This just started today as I was pulling out of a parking lot. I don't feel any kind of grinding and does not go away if I turn. Initial visual inspection in a parking lot does not uncover anything obvious and this is not the same noise as brake notification. Nothing looks like it is rubbing on anything. I did perform the following maintenance in the last couple months in order with the last one being two weeks ago.
    -Replaced Brake rotors and pads
    -Replaced front and back suspension
    -Replaced left and right sway bar link
    -Replaced left and right tie rod end w/ ball joint
    -Replaced right and left wheel bearings
    -Replaced Needle bearing and seal with one from ECGS
    -Replaced Front Differential seal. Had to do this since I drove the first one in to far.
    https://www.youtube.com/watch?v=0ilp3IkHbzA
    My unprofessional initial thought from hearing it, sounds like it is happening as the wheel turns but doesn't follow the same rotation of the wheel or it would be a faster squealing sound. Could this be CV Axle?
  2. Jan 9, 2020 at 1:20 PM
    bw4706
    bw4706 Well-Known Member
    Illinois
    09 Toyota Tacoma DCSB
    Bilstein 6112's , Eibach Coils,Hankook Dyna Pro MT 265/75/16, SPC UCA's, General Spring HD leaf packs, De-Badged, Ranch Bed Cap, Mag Light Seat Mount driver and passenger, Mini Mag Console Mount,Hard wired GPS, LED's in and out, MB TKO Wheels, After market grill, Heated seats, Diff breather relocation mod, LED Under Hood Lighting, LED Bed Lights, Aux. LED Reverse Lights, 30" L.E.D. Light Bar, Redline Tuning Hood Struts & EZ Down Tailgate. 6 Circuit Aux. Fuse Panel W/Circuit Breaker. Front & Rear Facing DVR cameras, High Lift Jack Bed Rail Mount. Clazio Leather Seat Covers. All Pro Heavy Duty Rock Sliders, 4x4 illuminated switch mod, Ignition converted to Push to Start. Bushwacker fender flares, Cali Raised side projector ditch lights. Cali Raised L.E.D. fog lights. 3 x 3 L.E.D. rear spotlights , Anzo headlights and taillights.
    Dust shields behind rotors rubbing on rotor ?
    I had same sound after new wheel bearing install.
    Just a guess. Hope you get it figured out.
    BillsSR5 and sprede[OP] like this.
  3. Jan 9, 2020 at 1:37 PM
    sprede
    Thanks @bw4706 , It very well could be that. I do remember accidentally bending the shield when putting things back together. I thought I had bent it back correctly, it has been two weeks since I did the work and was not making this noise till just now. I have a feeling that is not it, but it would be awesome if it was.
    bw4706[QUOTED] likes this.
  4. Jan 9, 2020 at 3:20 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Does it change in 4WD? Does it change when you're accelerating, coasting in neutral, or engine braking? U-Joints are capable of making some very weird sounds.
    Edit: As are carrier bearings
    sprede[OP] likes this.
  5. Jan 9, 2020 at 4:00 PM
    andrew61987
    In the mood to drop a driveshaft? I know it's not the easiest thing in the world, but it's not too hard either. You might learn something if you remove it then drive around in 4HI (front wheel drive Taco). If the noise does go away, shaft is already out for the subsequent U joint and carrier bearing job.
  6. Jan 9, 2020 at 4:05 PM
    sprede
    On my way home I tried a few more things. Keep in mind this is a rotational squeak.
    - It makes the noise turning and going straight.
    - Messed with the brake shield a little but no change.
    - When accelerating it continues and the rotational squeak gets faster until it "warms" up and then it stops. Can't reproduce until it cools off.
    - I did put it in 4 low and high but could not hear anything but likely cause it was already warmed up. Did not try nuetral to coast or engine brake but will have to wait till later tonight to try those things.
  7. Jan 9, 2020 at 4:07 PM
    sprede
    Yikes! Wouldn't know the first thing about how to do that. Big undertaking I would think. Crap hope it doesn't come to that.
  8. Jan 9, 2020 at 4:28 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Give us some more details on the one I put in bold. What parts did you use? How did you install them?
  9. Jan 9, 2020 at 4:50 PM
    sprede
    @Too Stroked - Here are my logs for maintenance.
    9/27/19 - 124,710 - Passenger Wheel Bearing only (Took it into Carpenters Auto). Didn't have my tools to do it myself do to recent move.
    10/24/19 - 124,768 - Suspension replaced and leveled (Les Schwab KYB Gas-A-Just Struts)
    >>It was after that I started getting a grinding feeling in the steering wheel and pedals. Thought it was left wheel bearing so did the following.
    11/5/19 - 124,794 - Replaced Drivers Wheel Bearing and Hub Assembly. Dorman 950-001 Front Pre-Pressed Hub Assembly
    >>That didn't fix it. Ended up being the needle bearing which I replaced.
    I have my truck in the garage now. Letting it cool off then gonna jack it up and turn the wheel by hand see if I can get it to make any noise. If not I will then go and do some more driving troubleshooting that was mentioned by @andrew61987 and anyone else that might have other things for me to try.
  10. Jan 9, 2020 at 4:54 PM
    Too Stroked
    Tom
    Personally, I'm not a fan of anything Dorman. Absolute bottom feeder parts. Lots of shops put Dorman parts in though because they can say they put new parts in (and be telling the truth), charge you for premium parts, but put cheap crap in. I'm not saying it's the Dorman bearings, but I'd certainly be listening in that area.
    sprede[QUOTED][OP] likes this.
  11. Jan 9, 2020 at 5:03 PM
    sprede
    You know, I really hope it is something simple like that. I will report back my findings later tonight. Thank you all for your help thus far.
  12. Jan 9, 2020 at 5:46 PM
    sprede
    @Too Stroked
    @andrew
    Ok, I got the truck jacked up and did the normal testing for bad wheel bearing and it comes back good. No movement in either the right or left tires, no unusual grinding noises outside of the pads rubbing on the rotors. Each tire has a good 3.7 seconds of spin before they stop. I don't hear any grinding coming out of the CV Axle rotation points. I took tire off and am able to rotate the wheel by use of the lugs. Unless there is something else to look at, I am going to put the tire back on and see what other configurations the squeal happens on.
  13. Jan 10, 2020 at 4:47 PM
    sprede
    Before I put the tire back on, I bent the shield back a little since I know I had accidentally bent it when I was working on the Needle bearing. I did not hear anything all day when driving so hoping that is what it was.
    UPDATE: It has been three days since I adjusted the brake shield and still no noise. I am thinking that was the issue.
