What the heck is this?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by luk8272, Dec 16, 2009.
  1. Dec 16, 2009 at 7:18 AM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    On the second gens, or atleast the 07 4.0.
    In the engine compartment on the drivers side near the engine cover there is what looks to me like an inlind fuel filter. What is it? The dealership doesn't know, lol big surprise. I was wondering 1 day while I was there when we are supposed to replace our fuel filters, they said not for a long time. I still don't know what that is but since I only have 31k miles I'll assume around 100k. I'll get a picture loaded in a minute.
  2. Dec 16, 2009 at 7:27 AM
    hashemg
    hashemg Well-Known Member
    Eastern MA
    08 Black Reg Cab 4x4
    3" Lift, Camburg Coil-Overs and UCA, 3" All Pro Leafs and OME rear shock, 33X12.5R17 Mickey Thompson on teflon coated American racing rims, Black headlight mod, Black taillight mod, tourneau cover, cargo divider, door sil protecors.
    I'm not sure what it is...but i can tell you that the fuel filter is in the bed of the truck. you pull out that pocket compartment on the gas tank side and its suppose to be right there. and yea the fuel filter is suppose to last a while.....from what i hear they aren't your typical cheap 10-15 dollar filter
  3. Dec 16, 2009 at 7:28 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    cmon now...thats the blinker fluid filter...it makes sure you dont mix muffler bearing grease and blinker fluid
  4. Dec 16, 2009 at 7:30 AM
    NraFan
    NraFan Join the NRA! Protect your freedom!
    JT
    SoCal
    2011 Sienna LE, rockin the mini van!
    Power sliding doors baby! WooHoo!
    Ill never make that mistake again!
  5. Dec 16, 2009 at 7:30 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Its the fuel vaper feed hose.
  6. Dec 16, 2009 at 7:36 AM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Kaplan, Louisiana
    Dealer said the filter was in the tank. I don't usually go there unless there is warranty work to be done. In this trip they replaced my battery.
  7. Dec 16, 2009 at 7:44 AM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
    +1. That plastic piece that looks like a fuel filter is probably a check valve that prevents the vapor from going back in the direction it came from. It may also be a filter of some kind.
  8. Dec 16, 2009 at 8:26 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The check valve is the VSV mounted to the engine (air purge tank). I havent taken that thing apart yet, but I agree it may be a filter of some sort.
  9. Dec 16, 2009 at 8:27 AM
    NAAC3TACO
    Sparks, NV
    2014 SR5 DCLB 4x4
    After doing some more research I'm tending to agree that it is a filter. GM used to use a filter like that on brake boosters to prevent the vapor from the intake getting into the booster.
  10. Dec 16, 2009 at 8:29 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah. It has to be. Interesting that a filter is used for the fuel vapors....I hate this.....Im trying to right off cutting mine in half.....
  11. Dec 16, 2009 at 8:36 AM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Kaplan, Louisiana
    What I don't get is that it is empty inside. You can see right through it and when you blow there is no resistance. Nor does it smell of fuel, or taste.
  12. Dec 16, 2009 at 8:39 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Hmmm.....Welll......It is for the emissions/fuel system, and it is mounted on the fuel vaper feed hose. So....Who is going to make a call to Tokyo?
  13. Dec 16, 2009 at 8:42 AM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Kaplan, Louisiana
    Its called a Vaccum tank and cost $24.60 I'm willing to bet I could run a hose without it. I can't figure out why there are no guts to this little thing, I am assuming its like the old vaccum canisters from back in the day. They had some black porus material in them and smelled of fuel though. Not to mention they were huge on 70 model vehicles.
  14. Dec 16, 2009 at 8:45 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    An air baffle of some sorts maybe? Like an expansion chamber or something of that manner?
  15. Dec 16, 2009 at 8:45 AM
    Afwrestler1986
    Johnstown, NY
    Well, there you go.
