What the hell ''flexy frame'' means????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dimitrik, Dec 14, 2009.
  1. Dec 14, 2009 at 1:24 AM
    dimitrik
    dimitrik [OP] Well-Known Member
    Dimitri
    Quebec
    09 Access Cab TRD-Offroad
    AllPro Skidplate
    I checked the car and driver buyer's guide, and one of the lows for the tacoma was that is had flexy frame. Is it good? Bad?
  2. Dec 14, 2009 at 4:00 AM
    Old Soul
    Old Soul Well-Known Member
    NC
    09 AC V6 SR5 2WD SWB
    not to many, love it the way it is
    It meant to say " Sexy Frame" they got it wrong. no, seriously, it is probably talking about wheel hop.. nothing an add a leaf can't take care of
    RJ_MacReady likes this.
  3. Dec 14, 2009 at 4:08 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    :rolleyes:
    Did they even show any test results to prove that? What tests did they perform? Did they even talk to Toyota about WHY it's that way? Maybe it's better for crashes/crumple zones?
  4. Dec 14, 2009 at 5:02 AM
    jcayce
    jcayce Well-Known Member
    Texas
    17 DCSBTRDOR4X4
    It is good (to me). The buyer's guide idiot writers found out that the Tacoma does not use a fully boxed frame and immediately wrote 'flexy'. It's not bad for offroad, quite often a stiffer, fully boxed frame will be too rough and not as nimble offroad, where trucks should be.
  5. Dec 14, 2009 at 10:34 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    It is flexy compared to a fully boxed frame. Nissan has us on this one.
    Some bumps at speed you get a hop going...sorta sucks.
  6. Dec 14, 2009 at 10:44 AM
    freeze
    freeze Well-Known Member
    These frames are open C-Channel frames similar to the ones used on the 40 Series Landcruiser which enables the frame to twist over obstacles giving a little more flex.
    Unfortunately with the length of these frames, there's also lots of up and down flexing of the frame which translates into wheel hop, or bounce.
    Topper companies for these trucks have left more than an inch of room between the cab and the topper specifically for this reason. The rear flexes up and down that much.
    The only weakness off-road with this type of set up is when you're doing a steep hill-climb and the rear end will buck. You can actually see how much it bends from a distance!
  7. Dec 14, 2009 at 11:35 AM
    thinkingman
    thinkingman Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    Let's tell the truth...it's a lame design
    AFZ likes this.
  8. Dec 14, 2009 at 11:41 AM
    rutherk1
    rutherk1 ElPhantasmo&TheChickenRunBlastarama
    09 Silver TRD 4door
    Maybe they are making them out of rubber now to help with the rust.
    SandyTaco4x4 likes this.
  9. Dec 14, 2009 at 12:01 PM
    dimitrik
    Dimitri
    Quebec
    AllPro Skidplate
    I would of liked a boxed frame. O well. Nissan still sucks. Not even a true 4x4.
  10. Dec 14, 2009 at 2:47 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    My dad has an '06 Frontier and his truck bounces/hops around a lot more than mine, according to him "the Nissan has too much power". :D
  11. Dec 14, 2009 at 2:53 PM
    Asgard
    With a boxed frame, debris and mud can get trapped inside the frame and cause it to rust. With the rust problems the 1st generations were having, I kinda feel better with my c-frame.
  12. Dec 14, 2009 at 4:26 PM
    dimitrik
    Dimitri
    Quebec
    AllPro Skidplate
    If that is the case, then i don't care anymore.
    I don't feel anything out of the ordinary on bumps anyways.
  13. Dec 14, 2009 at 4:49 PM
    el_smurfo
    el_smurfo Well-Known Member
    Can't find it at work today, but anyone see that comparison of full size trucks on a washboard track? The Tundra was tweaking all over the place while the other trucks kept their beds pretty straight. Bet the Tacoma would do the same...
  14. Dec 14, 2009 at 5:00 PM
    jcayce
    Texas
    17 DCSBTRDOR4X4
    How is it not a true 4x4? My 05 4X4 Nismo King Cab was leaps and bounds above my 1986 full size Bronco (what I conisder a true 4x4). I have yet to test the full prowness of my Toyota but would never once believe that it was more/less capable off road than my Nissan was.
  15. Dec 14, 2009 at 5:02 PM
    jcayce
    Texas
    17 DCSBTRDOR4X4
    And MY (not THE) best 4x4 was an Isuzu Rodeo Sport. That thing was a goat, the 3.2 was bullet proof, and I do not miss any vehicle off road more than that one.
  16. Dec 14, 2009 at 5:06 PM
    Asgard
    Isn't a washboard track a stretch of bumpy road ? I think that has more to do with the suspension set up than frame design. Also you ever wonder why the bed is separated from the cab ?
  17. Dec 14, 2009 at 5:09 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    so true, i have score marks on the back of the cab from the front bed of the bed touching. flexing that much from the trails :eek::p
  18. Dec 14, 2009 at 5:10 PM
    Zizo
    Zizo Engineer Extraordinaire
    Anthony
    Greenville, SC
    '06 DoubleCab 4x4 TRD Sport
    TRD Supercharger, 3" lift w/ Fox Shox, Pioneer Sound System, Remote Start, Avid Off Road Bumpers, All Pro Sliders, LED light bar, HID headlights, much more...
    My 1990 4Runner had a fully boxed frame. To this day, there is not rust on that frame. I undercoated it well. It does kind of tick me off that my brand new Tacoma has a C-channel frame. I definitely can tell when it flexes, if I'm on the throttle mid-corner. You can feel the LSD kick in, but even the posi can't hide the fact that the rear end bucks. I'd rather have a stiffer ride w/ a boxed frame than this. Oh well...
  19. Dec 14, 2009 at 5:22 PM
    dimitrik
    Dimitri
    Quebec
    AllPro Skidplate
    Ahhh ok i googled C-channel frame and i know what they mean. I don't think it's that big a deal. I won't buy a Dakota just for a god damn box frame.
    I wouldn't mind the Frontier, i was talking out of my ass that time, but i prefer Tacoma. As for why i think it's not a real 4x4; From what i heard is that it is FWD until you get mud, then the 4WD comes in. I don't like fancy stuff on my trucks. Least you got electronic wheel hubs, honda CRV has a similar system but no E. wheel hubs.
    Maybe i got somethings wrong, i read about those things long time ago. If i am completely wrong, i am sorry :p Forgive my ignorance.
    If Nissan Frontier would offer that tasty 3.0L Diesel from Renault, i would probably be riding one :p Same thing goes for the Hilux diesel i guess.
  20. Dec 14, 2009 at 5:38 PM
    jcayce
    Texas
    17 DCSBTRDOR4X4
    No offense taken but my Nissan was not a FWD truck. Someone please post a picture of a VW Rabbit pickup and let this guy know what a real FWD truck looks like...
