What the hell ''flexy frame'' means????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dimitrik, Dec 14, 2009.
  1. May 27, 2010 at 1:06 PM
    #101
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    TACOMAWORLD.COM
    Free Kool-Aide, served 7 days a week.
    Because we all know what would be said if the Tacoma had the beefier boxed frame, and the Frontier had the un-boxed, flexy C-channel.
    AFZ likes this.
  2. Jun 14, 2010 at 2:38 PM
    #102
    ywen
    ywen Well-Known Member
  3. Jun 14, 2010 at 8:48 PM
    #103
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
  4. Jun 14, 2010 at 8:58 PM
    #104
    KalamaKid
    KalamaKid Well-Known Member
    Oregon
    same shit as everyone else
    My taco flex's every time it sees its self in a window ;)
  5. Jun 14, 2010 at 9:00 PM
    #105
    ywen
    1st & 2nd gen both have the weak-ass c channel
  6. Jun 14, 2010 at 9:09 PM
    #106
    BlueT
    NorthEast
    My 99 had C channel only at the tail under the bed so when that got changed ?? :confused:
  7. Jun 14, 2010 at 9:25 PM
    #107
    ywen
    right.. starting from the rear axle, it's all c-channel..
  8. Jun 15, 2010 at 7:29 AM
    #108
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    wrong. It's boxed at the third cross member... Look:
  9. Jun 15, 2010 at 7:40 AM
    #109
    BlueT
    NorthEast
    Ok so I am little confused as to why you posted picture and comments :confused:
    1 Gen is boxed with exception the tail (like a 2 feet section)
    Picture looks like frame got cracked and bend under the cab, in exact spot that rust issue on 1 gens had been a problem.
    So again what was the point ... ??
  10. Jun 19, 2012 at 12:38 PM
    #110
    xheader
    xheader Member
    Connecticut
    04 Xtra Taco
    This is an old thread, but I just couldn't resist.
    I wanted a Unimog until I read this thread...considering that the newest 'mogs are designed to have torsional flexibility and make heavy use of C-Channel in the frame...
  11. Jun 19, 2012 at 1:35 PM
    #111
    AFZ
    AFZ Well-Known Member
    IN
    4x4 AC 4.0 TRD OR
    But where are your facts?
  12. Jun 19, 2012 at 1:40 PM
    #112
    AFZ
    IN
    4x4 AC 4.0 TRD OR
    You realize load capacity does not equate to frame-strength, right? Load capacity has more to do with brake and spring rating.
  13. Jun 19, 2012 at 1:57 PM
    #113
    Crom
    Nick
    San Diego, CA
    Millions
    NECRO THREAD ALERT!
  14. May 29, 2016 at 7:39 AM
    #114
    PRRGY
    PRRGY Chino
    Florida & Guyana
    2011 Tacoma TRD 4WD upgrading to IFS Tacoma.
    ARB Bull Bar, Warn M8000 w/ 1/2" Synthetic Rope, Fox Coilovers with 650# Coils, Bilstein 5160's, OME Rear Springs, Front & Rear Timbrens, All-Pro Apex Rock Sliders & Spindle Gussets, Total Chaos Tower & Cam Tab Gussets, JBA Upper Control Arms, Bud Built 5 Piece Skid Plates, URD Spec U Exhaust, Doug Thorley Long Tube Headers, Fab Fours Rear Bumper w/ Tire Carrier, Airflow America Snorkel, BFG 255/85-16's on TRD 16 x 7-1/2" Rims, Custom Mudflaps, Shackle Mount Cross Member, Tech Custom Sway Bar Drops, to be continued.........
    Milowillie
    Crom[QUOTED] likes this.
  15. May 29, 2016 at 11:25 AM
    #115
    Crom
    Nick
    San Diego, CA
    Millions
  16. May 30, 2016 at 9:15 AM
    #116
    PRRGY
    PRRGY Chino
    Florida & Guyana
    Thanks bud. I'm new to this.
  17. Jun 3, 2016 at 1:14 PM
    #117
    Grand Moff Silver
    Grand Moff Silver New Member
    Kyle
    Iowa
    2008 Tacoma Single Cab, 4-cyl, 2-wheel drive.
    Bone Stock
    Hi everyone,
    I'm a new owner of a 2008 Tacoma single cab w/standard bed. Anyone else hear 'pops' coming from the bed when your frame twists a little? I was told it was the combination of plastic and metal in these beds. Anyone know how to stop it? It's kind of annoying. I saw the tread topic and thought ........
  18. Jun 3, 2016 at 2:00 PM
    #118
    McTeague
    McTeague Well-Known Member
    Alan
    2012 MGM Tacoma DCSB TRD Off Road
    Stock
    Sounds like your bed bolts might be loose?
  19. Jun 3, 2016 at 8:28 PM
    #119
    Crom
    Nick
    San Diego, CA
    Millions
    Not normal.
  20. Jun 3, 2016 at 9:24 PM
    #120
    Pigpen
    Dan
    Northwest Montana
    Miles has a thread somewhere about a supporting part of the plastic bed that wears down, allowing the bed to bounce because the bolts are no longer tight on it. The solution is to support the part that is worn with something abrasion resistant like a chunk of sidewall from an old tire.
