what the hell is going on!?!
Discussion in '1st Gen. Tacomas (1995-2004)' started by mixaro, Nov 2, 2011.
  1. Nov 2, 2011 at 7:00 PM
    mixaro
    mixaro [OP] Well-Known Member
    maine
    02 tacoma ext cab, 2011 trail edition 4 runner, 2013 tx baja dcsb
    02 ext cab cat-back exhaust, k&n replacement filter, 5100 billy's, hellcreek 1.5" rear spring packs, 882 OME coils, Toytec 2" AAl, stainless brake lines, Light Racing UCA, 1" diff drop, BPV bracket, 4" deck plate mod, 886 fog light backup light mod, tom woods one piece drive shaft, spider trax 1.25 spacer.
    ok heres the deal i have a 02 2.7 and it won't start unless i press the gas pedal all the way down, and it won't stay running if i let off the gas. But once it gets up to running temp. its fine. what the hell is going on?
  2. Nov 2, 2011 at 7:10 PM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    Sounds like you got a problem
  3. Nov 2, 2011 at 7:14 PM
    mixaro
    maine
    yeah i know, it's weird, it started fine, but then i shut it off right after i started it cause i saw that my tool box was open and my tail gate was down, and when i went to start it, it decided to be a pain in the a$$.
  4. Nov 3, 2011 at 8:08 AM
    wcp0611
    wcp0611 Well-Known Member
    Cliff
    Rockvale, TN
    wcp0611@gmail.com
    Grey wire and keyless entry. I like stock.
    Before giving advice to you, does it pop any codes you can check out?
  5. Nov 3, 2011 at 10:13 AM
    XwesleysnipesX
    XwesleysnipesX Well-Known Member
    Eric
    Batesville, Indiana
    1996 2.4L 2x4 (sold). 2002 2.7L sr5 4x4 (sold)
    Id have to say a coolant temp sensor. Im not sure what toyota calls it. On my vw thats what is was called. Its dead on the same problem i was having with my corrado. I know its a different make and model. But im pretty sure all cars 96 and newer use them. Just my 2 cents.
  6. Nov 3, 2011 at 10:28 AM
    Taco John
    Taco John Well-Known Member
    Illinois
    4X4
    So it started fine first thing, you shut if off shortly after starting it, and then it hwas hard starting or you always have to floor it to start it?
  7. Nov 7, 2011 at 5:41 PM
    mixaro
    maine
    ok it has only happened that one time but yeah i was and still a little concerned about it. It would only start back up when i pressed the gas to the floor and as soon as say i came to a stop sign and would stop and have the clutch pressed in it would stall out, then would not start back up unless i floored the gas pedal. But then after it warmed up it stopped doing it and has not done it again, and it has not thrown any codes.
  8. Nov 7, 2011 at 5:44 PM
    Scummy
    Scummy SCUMBAG CUSTOMS
    Phelan, CA
    hopped up 96 single cab 5 lug 4 banger
    Fabtech uppers and spindles, extended shackles in rear, k&n intake, flowmaster exhaust, and much more to come
    sounds like a fuel pump, filter, or injector problem
  9. Nov 7, 2011 at 5:45 PM
    rcbs204
    rcbs204 Well-Known Member Vendor
    This, is your best bet.
  10. Nov 7, 2011 at 6:01 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Try cycling the gas pedal 100 times with the truck off.
  11. Nov 7, 2011 at 6:07 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    to me it sounds like an idle air control valve that may be sticking...try cleaning your throttle body and maf sensor
  12. Nov 7, 2011 at 6:08 PM
    mixaro
    maine
    i was hoping it wasn't the pump, injectors, or filter, but it's weird it only did it that one time and it hasn't happened again.
  13. Nov 7, 2011 at 6:17 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    when mine was sticking i let off the gas coming to a stop sign and it just cut off, the truck wouldnt stay running unless i had my feet on the gas at all times, cleaned the tb iac and maf and its been running to this day
  14. Nov 7, 2011 at 6:18 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    Pedal to the floor makes a clear flood condition, shutting off the injectors. It all sounds like a flooding situation possibly caused by the coolant temp sender, a MAP sensor, a TPS, a cold start injector problem, a fuel pressure problem, or any combination of the previous conditions. The fact that it runs better when it warms up makes me think about the temp sender direction but I have seen ECM's fail in similar fashion. You need to get a scanner on it and maybe a scope to see what is really happening.
  15. Nov 7, 2011 at 6:22 PM
    Leggo
    Newton,Ma.
    sorry, I didn't know it has cleared up on it's own.. Good deal! ever find the problem?
  16. Nov 7, 2011 at 6:31 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    x2
    it can be a giant number of things, over the internet we can only suggest causes and take guesses, take it to a trusted shop that has a scanner that can scan every systems function
    (ie with my diesel i had an issue of it defueling under boost, took it to the local diesel shop and ran the scan tool, within 10 minutes it had checked all the electrical systems and found the secondary fuel pump tripping the circuit breaker every few minutes)
  17. Nov 7, 2011 at 6:38 PM
    mixaro
    maine
    yeah one of my friends is a hell of a mechanic, and we hooked it up to his scanner, and the only code it threw was my o2 sensor (which i knew was bad) and thats it. so we did cleaned the map sensor and the throttle body. then we sea foamed it and ran some injector cleaner through it. he figures i probably just got some crap gas (only had a little under a quarter of tank of gas), or maybe my fuel filter. it's just odd that it's running like a champ since that day.
