What the hell's wrong with my shock??
Discussion in 'Suspension' started by Tacomanator, Sep 7, 2010.
  1. Sep 7, 2010 at 6:59 PM
    Tacomanator
    Tacomanator [OP] Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    does this look right? i noticed a little clank while driving today and the washer that goes under the top nut was loose. tried tightening the nut but it just turned the entire shock shaft, so i held the shaft inplace with some vice-grips and tightend the nut as tight as i could, but the washer was still a little loose. what could be wrong? should i just keep trying to tighten the nut? did i run out of thread? HELP please!... this is the driver side. passenger side is fine.
    Uploaded with ImageShack.us
  2. Sep 7, 2010 at 7:00 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    theres no pic?
  3. Sep 7, 2010 at 7:03 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    ^ its up there. i can see it on my computer...
  4. Sep 7, 2010 at 7:05 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
    bump for some help
  5. Sep 7, 2010 at 7:05 PM
    08pretaco
    az
    it should be threaded down on top of it..idk maybe your other 3 screws are too long which is why you can ttighten the thread on the middle one. or maybe you forgot a washer...
    How long have you used this setup? Was there a 1/2" top plate spacer on it recently?
    mine shows simsilar amount of thread on to pin middle screw but is all the way tightened
  6. Sep 7, 2010 at 7:05 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    can you see it now? i used a different image code.
  7. Sep 7, 2010 at 7:07 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    had it for about 3 weeks. i did have a top spacer but took them off when i got the 5100's
  8. Sep 7, 2010 at 7:07 PM
    08pretaco
    az
    does it look like the threads are stripped? is there a washed underneath the bushing?
  9. Sep 7, 2010 at 7:08 PM
    08pretaco
    az
    Are the other 3 nuts floating as well on the screws? which top plate spacer the 1/4" or 1/2"?
  10. Sep 7, 2010 at 7:10 PM
    autobodyx
    autobodyx Member
    Yadkin co NC
    09 SWB TRD Super charged
    TRD super charger, Coupe modded TRD ss, DT long tubes, URD competition Y pipe,Magnaflow Exhaust,AFE intake XII performance springs and sways,QA1's TRD oil cooler E-Fan,DJM 3/4 drop with bags
    under the frame there is another rubber and washer. The rubber has come apart and or off, or the washer that holds it is missing. the same thing happened to mine and it was a missing washer.
  11. Sep 7, 2010 at 7:18 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    no. and i dont know if there was a washer underneath because i had a shop do the coils for me. thats proly what it is tho.
    no. and i had a 1/4" spacer.
    thats probably what it is. where did you get your washer and rubber from? mine are proly long gone since i had a shop do the work...
  12. Sep 7, 2010 at 7:24 PM
    08pretaco
    az
    take it back and tell the to F***ing do it again and do it right
  13. Sep 7, 2010 at 7:25 PM
    08pretaco
    az
    Great minds think alike :)
  14. Sep 7, 2010 at 7:26 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    that top washer looks upside down to me.... but not sure
  15. Sep 7, 2010 at 7:29 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    the washer looks flat, how can it be upside down?
  16. Sep 7, 2010 at 7:32 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    are there any seriouse dangers in running it like this for a while? i dont want the entire shock assembly comming off while driving on the freeway :eek:
  17. Sep 7, 2010 at 7:34 PM
    johnw
    john
    orlando florida
    let me look at a couple threads i will get back to you
  18. Sep 7, 2010 at 7:37 PM
    johnw
    john
    orlando florida
  19. Sep 7, 2010 at 7:45 PM
    Tacomanator
    Clam Slammer
    Southern Cali
  20. Sep 7, 2010 at 8:05 PM
    08pretaco
    az
    WHAT! maybe I have recieved too much today...idk lol :p
    you have probably given your alotment for the day haha
