What the Tacoma can actually tow.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rsuths, Aug 29, 2024.
  1. Aug 29, 2024 at 10:59 AM
    rsuths
    rsuths [OP] New Member
    Hi All,
    I'm brand new to this forum. I have questions about what the Tacoma can safely tow. I'm looking at a used 2023 Toyota Tacoma 4WD TRD Off-Road Automatic Crew Cab. It has the V-6 3.5 L/211engine. According to my research, the vehicle has a GVWR of 5,600 lbs. I'd like to tow a 2023 Forest River Rockwood GEO Pro G19FDS. This campers GVWR is 4,500 lbs. If I add those together (which would represent the maximum combined weight the vehicle could safely tow, right?), I get 10,100 lbs. Again, according to the Interweb, the GCVWR of the Tacoma 1s 11,360 lbs. Subtracting those, I calculate I'm 1,260 lbs under the Tacoma's GCVWR. Am I figuring this correctly? If so, and I keep the GCVW under the rating by that amount (or, likely more), will the Tacoma handle reasonably well and be comfortable driving in the mountains on occasion? Thanks in advance for your expert advise!
  2. Aug 29, 2024 at 11:12 AM
    Dorf510
    Dorf510 Well-Known Member
    Tyler
    Vista, CA
    18 TRD 4x4
    Dayton wires, flux-capacitor, port-a-potty
    Tow capacity is 6500(depends on trim), but i wouldn’t recommend towing anything over 4k with these trucks, reasons being: soft rear suspension, not-the-best transmission and shift points, and brake upgrades needed. Buy a Tundra for that trailer, your whole towing experience will be night and day difference. Tacomas “Can” tow that trailer, just expect a crappy experience with a few “pucker factor” experiences. Tacoma towing that trailer will likely see single digit MPG(on flat ground, worse in any inclines), go for a Tundra(my $0.02).
    I tow a camp trailer(1K), a waverunner(1.2k) and a boat(2.5k) quite often, I upgraded brakes/gearing/suspension/airbags/tune to compensate for the lack of power/shiftpoints from the factory. Towing is improved if you spend the $ to upgrade the tow vehicle, but id save $ and grab a Tundra to start with. I live in SoCal though, so I’m biased due to the constant altitude gain/loss when traveling.
  3. Aug 29, 2024 at 11:16 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    I would go full size to tow that camper.
    BillF1564 likes this.
  4. Aug 29, 2024 at 11:19 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Generally speaking, for any kind of travel, I want to be 50% or less of advertised capacity. Your threshold may be different. Another couple large factors:
    - wind resistance. This is just as much of factor as weight
    - terrain. Mountains, high altitude, etc
    - time? A retiree’s expectations are much different from a parent that wants to leave Friday, and burn back home Sunday for the work/school week.
  5. Aug 29, 2024 at 11:21 AM
    yota924x4
    yota924x4 Well-Known Member
    Pgh
    23 pro 6mt
    You aren't going to have a great time. You have a cargo capacity of around 900-1000lbs. That is your people, whatever gear you put in your truck plus... the tongue weight of the trailer. Assuming 10-15% of your trailer weight on your tongue you have less than 500lbs between you and your gear in your truck.
    Your tow capacity should be 6400lbs. That trailer looks to be around 3500lb dry with a 485lb hitch weight. Loaded properly it tops out at 4500lbs. If you keep it light, don't go over the cargo capacity of the truck, and have your safety equipment like a brake controller in place... you'll live. Check out the towing section
    PTSDTherapy, BillF1564 and Chew like this.
  6. Aug 29, 2024 at 11:25 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It will tow it.
    It will handle it “reasonably” well for what it is, a mid-size truck.
    It WILL NOT be comfortable to tow.
    PTSDTherapy and Chew like this.
  7. Aug 29, 2024 at 11:27 AM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    As long as you stay within the ratings (including the weight of you, passengers, and all gear), I'd still recommend a full-size truck for towing.. I'm an internet stranger so my opinion is meaningless, but I wouldn't tow anything over 3k lbs regularly with a Tacoma. It'll do it, usually without complaint too, but it still sucks at it. Kinda like the last kid to get picked on the basketball team; he'll play his heart out and won't give up, complain, or talk back. But he's way better at Chess, and thrives in that environment much more.
  8. Aug 29, 2024 at 11:44 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
  9. Aug 29, 2024 at 12:19 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    4500 GTWR
    3500 Dry weight
    Fresh tank - 31 gal
    Heater+plumbing - there's usually 6-10 gallons hiding in there full time.
    Gray tank - 27 gal
    Black tank - 27 gal
    Realistic water weight: 340-ish pounds.
    Typical cylinder of propane: 38 pounds
    Typical battery: between 40 and 100 pounds depending on lithium or lead.
    Best case - that's 400-500 pounds, which would leave 500-ish pounds for linens, kitchen wares, toys, and any added option/accessory (it seems like a lot, it really isnt.) That means you are going to be riding at GTWR more often than not.
    At 4500, yeah, the truck'll do it, It's just going to hate life. And also, you are going to have to be highly conscious about weight management lest you risk a leaf spring. Leave the blackstone griddle at home.
    RustyGreen, BillF1564 and Chew like this.
  10. Aug 29, 2024 at 1:08 PM
    545 Well-Known Member
    2015 Access Cab
    3500lb trailer, should be fine as long as they aren’t lying
    Read your manual and the towing guide here
    Find a used one at a dealer that they will let you do a test tow
  11. Aug 29, 2024 at 1:25 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    Adding what little I know about this (which is VERY little) ... use S4 and ECT instead of D. You need the revs high to get torque and hunting in the S5-S6 range does not help.
  12. Aug 29, 2024 at 2:06 PM
    Tacosauro
    Tacosauro Well-Known Member
    23 SR5 V6 & 24 TRD OR
    roof rack
    https://www.youtube.com/watch?v=RIbNCARLLZA
    Here, towing starts at 6:05
    There are more IN DEPTH videos but I just like this average Joe real world video.
    It can tow fine. Just don't expect it to feel like F150 or Tundra, its a midsize.
    Its a small family truck, will do fine for trips etc once a month.
  13. Aug 29, 2024 at 2:09 PM
    MrWrestlingII
    MrWrestlingII Well-Known Member
    Like others, I would recommend a full size.
    Hands down the Taco is not a good tow vehicle.
    TnShooter, Chew and BillF1564 like this.
  14. Aug 29, 2024 at 2:21 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    why tow the max it will tow? thats not the idea..... it wont be fun......clogging up the freeway slowing other drivers down
  15. Aug 29, 2024 at 3:08 PM
    Clearwater Bill
    Billy
    Largo Florida
    If you're going to the KOA 100 miles down a mostly flat road you'll be fine.
    If you're actually traveling, a full size truck or a smaller trailer are in order
  16. Aug 29, 2024 at 5:11 PM
    mfalbojr
    mfalbojr Well-Known Member
    Kansas City, MO
    2024 TRD Sport Silver
    Tacoma's can absolutely tow that. But the truth is Tacoma's suck for towing. They are not meant to do it. They don't like doing it. They are not good at it. I have had 1 of every gen made except for the new 4th gen, they all are great trucks. None of them tow worth a shit.
  17. Aug 29, 2024 at 5:26 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Page 25 of this PDF has towing number for the 2023 Tacoma by trim.
    https://www.toyota.com/content/dam/toyota/brochures/pdf/2023/tacoma_ebrochure.pdf
    Chew likes this.
  18. Aug 29, 2024 at 5:36 PM
    abodyjoe
    abodyjoe Well-Known Member
    joe
    2017 Tacoma double cab TRD Offroad. quicksand in color
    next to no payload is the biggest issue with a tacoma. trailer tongue weight, even with a WDH will take most of the payload capacity.
    Chew likes this.
  19. Aug 29, 2024 at 5:55 PM
    Squirt
    Squirt Samsung Aficionado!
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back with a 3in Speedys Snap resonator. J&L catch can. AMP Powersteps
    Yeah thats a lot for the Taco. Id get a used V8 Tundra or F150. I like the 3.5L Ecoboost in my F150 as it has oodles of torque.
    Chew likes this.
  20. Aug 29, 2024 at 6:04 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    The weight is not the only factor. Remember your towing a big old square box. Wind resistance and cross winds play a huge factor. I towed a 6x14 enclosed Aluma weight loaded at 3500k to 4000k wouldn't want to tow anything more with a Tacoma 18 DCLB Sport with OTT tune.
