What thread size is this?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by goufcustom, Oct 29, 2011.
  1. Oct 29, 2011 at 1:51 PM
    goufcustom
    goufcustom [OP] 7.62x63mm
    MD
    2006 4x4 TRD Off Road DC SR5
    Bed Topper, Diff Breather, aFe Cold Air Intake, Satoshi Grill, Moved Horns, Oil Catch Can, Tailgate Lock, Husky Mud Flaps, H4 65/70W Bulbs, Lower Grill Mesh, TRD Skid Plate, LEDs in the bed, LEDs behind the grill for accent lighting, Parking lights as turn signals, LED turn signals and reverse lights, 5100s up front, eibachs up front, SS extended brake lines all around, 1.5" AAL in the rear, Relentless Fab U-Bolt Flip Kit, ICON Progressive AAL, TRD Wheel Center Caps, HomeLink, Heated Driver Seat, Hella 500 FF Driving Lights, BAMF Diff Skid, BAMF LCA Skids, BAMF Rock Sliders w/ KickOut.
    I was changing the front diff oil in my 2006 TRD Off Road Tacoma, and there is a skid plate in the way that needs to be removed before you can get to the front diff. I took that off and changed the oil just fine, but when I went to put the skid plate back on, I messed up the threads a little on one of the bolts, so I backed it back out and put the other three in and now I need to run a die on the bolt and a tap in the hole on the truck. BUT... I have no idea what thread size it is, I assume it is metric, but I am having issues identifying it. Really don't want to end up at the stealership for this one, and since my neighbor has a tap & die set I figure this is an easy fix.
    I think this is the part number: 90080-11373
    Google may have helped me, I think it is a M8x1.25, will be trying this later when my neighbor gets home.
  2. Oct 29, 2011 at 2:00 PM
    ouyin2000
    ouyin2000 Well-Known Member
    Arlington, Virginia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    How hard did you crank it before you realised it was cross threaded? It takes a lot of effort to mess up the threads so badly that you need to re-tap it.
  3. Oct 29, 2011 at 3:54 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    a metric thread file is your friend with stuff like this
  4. Oct 29, 2011 at 4:59 PM
    goufcustom
    MD
    I don't think it is cross threaded, I just want to clean up the threads before I try again. I also have a complex with over tightening... :rolleyes:
  5. Oct 29, 2011 at 5:41 PM
    ouyin2000
    Arlington, Virginia
    '11 DCSB TRD Sport
    Well if you just want to clean it, just use some WD40 and a wire brush.
  6. Oct 29, 2011 at 5:45 PM
    Wally
    Wally Well-Known Member
    Ontario (the metric version)
    07 Access Cab TRD 4x4 6MT 1GR-FE
    M8 X 1.25
    Ran my tap in to double check so that's it for sure ...
