what tire pressure do you run in 265/70/17?
Discussion in 'Wheels & Tires' started by jerretxx, Jun 2, 2010.
  1. Jun 2, 2010 at 7:18 PM
    jerretxx
    jerretxx [OP] Some do, others talk
    Jerret
    North Carolina
    2017 DCSB TRD Sport 4x4
    What tire pressure is everyone running with a 265/70/17?
  2. Jun 2, 2010 at 7:26 PM
    Racer78
    Racer78 Well-Known Member
    05 Tacoma 4X4 Sport
    Billstiens 5100 @1.75, 5125, 1.5 AAL,Leaf Spring TSB,TRD Intake, Roof Rack, Satoshi Grill, BHLM,T-Rex Eyelids, Undercover Cover, Powdercoated Sport Rims, KC Slimline 8" Lights, MTX ReQ5 w/ipod imput, 12" Shallow Pioneer Sub, RF 800.4 amp, JBL Comp, Bed Ext, USB Port, Shorty Antena, Spider Trax Spacers,TRD Skid Plate, Napier Sportz Tent II, Scangauge II, AirBedz
    Do you mean for off roading? The psi is different per make and model and should be listed on the sidewall for daily driving?
  3. Jun 2, 2010 at 7:30 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    check your door jam
    32 front 28 rear mabye
  4. Jun 2, 2010 at 7:32 PM
    Racer78
    05 Tacoma 4X4 Sport
    Wouldnt that be for the stock 265/65's?
  5. Jun 2, 2010 at 8:23 PM
    DueNorth
    DueNorth Well-Known Member
    Southern Ontario, Canada
    2014 BSP TRD Sport DCSB 6sp
    The door jamb info would be for stock tires. With aftermarket tires your best off using the chalk method to find the ideal psi to run.
  6. Jun 2, 2010 at 8:25 PM
    747 function > form
    1st Gen.
    Not running them, but would think no higher/lower than 40/35 hot.
  7. Jun 2, 2010 at 8:27 PM
    fmg029
    fmg029 Member
    32 to 34 on winter time and 30 to 32 on summer...
    for off road with stock Duelar tires at 25...
    BR
  8. Jun 2, 2010 at 8:29 PM
    bakerla
    bakerla Man, Myth, Legend
    Lyndall
    Pearland, TX
    '10 4wd OR
    CBI Moab front and CBI Trailrider rear, Budbuilt skids, Shrockworks sliders, OME Dakars w/ OME Nitros, OME 886x w/ OME Nitros, Light Racing UCAs, stainless steel brakelines F/R, Cobra 75 w/ Firestik antenna, 255/85/16 Cooper ST Maxx on 1st gen alloys, Weathertech liners, Engo 9000S winch, stickars and other shit.
    i'm running 29 psi on rear and 30 psi on fronts. i did the chalk test and found those pressures to be fairly optimal. i was running 35 psi rear and fronts.
  9. Jun 3, 2010 at 4:12 AM
    Racer78
    05 Tacoma 4X4 Sport
    Never heard of the chalk test. What and how do you do it?
    Thanks
  10. Jun 3, 2010 at 3:18 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
  11. Jun 4, 2010 at 7:29 PM
    jerretxx
    Jerret
    North Carolina
    i have them at 35, its what it calls for. I was just wondering if anyone had better luck with any other psi though.
