What tire pressure for my 265 70R17s?
Discussion in 'Wheels & Tires' started by dtattoli, Apr 10, 2015.
  1. Apr 10, 2015 at 5:01 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    32 psi
    /thread
  2. Apr 10, 2015 at 5:17 PM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    I would think you might be putting unnecessary wear and tear on your suspension components running 80 psi unloaded. You'll be running Flintstone style on rock solid tires.
    We haul tons of glass on full size trucks at work and don't run our tire pressure that high.
  3. Apr 10, 2015 at 5:18 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I run 40
  4. Apr 10, 2015 at 5:27 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    40 unloaded. 45 front 50 rear with my camper mounted.
    E rated requires more air than P, not less.
  5. Jul 11, 2015 at 3:44 PM
    Kysport
    Kysport Well-Known Member
    Louisville, Kentucky
    2020 Silver Sky Metallic Limited
    I didn't see any discussion on Michelin LTX M/S 2's. I'm running my 265/65/17 at 32 all around. Anyone else have different ideas.
  6. Jul 11, 2015 at 4:33 PM
    Dilleytech
    Dilleytech Well-Known Member
    Jakob
    White salmon, Washington
    07 AC SR5 4x4
    Front ARB bumper, LR UCA's, OME 885/90021 struts, Ome shocks rear, general springs HD leaf pack.
    Your not only sacrificing your ride but also Sacrificing your tire life. For best wear and functionality DO NOT Fill your tires to the max psi on the side wall.
  7. Jul 11, 2015 at 5:54 PM
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    I run my MS2's at 36 rear, 34 front, cold. For the most part, it keeps me happy year round here in SD with big ambient temp variation (-30F° to +100°F). Due to ambient temp, it gives or takes a little and matches well with my seasonal use (more highway summer and more ice/snow winter). They seem to lose more in winter than they gain in summer. Ive always maintained that the front is a little lower cold pressure due to the increased heat generated while driving (friction from front end weight causes the front tires to heat and expand more than the rear). Measuring hot pressure they are almost the same.
  8. Jul 11, 2015 at 6:48 PM
    Kysport
    Thanks for your reply.
    NMTrailRider likes this.
  9. Jul 11, 2015 at 6:49 PM
    Dilleytech
    Jakob
    07 AC SR5 4x4
    When you park do your front tire appear more inflated then the back then? I run 34 front 30 back and even after a long drive my back tires are more inflated.. I should probably reduce my rear pressure.
  10. Jul 11, 2015 at 7:48 PM
    NMTrailRider
    New Mexico
    Honestly, they always look about the same to me. Never really notice a visible difference, but ive never really paid attention either. Maybe because the back end is so much lighter, it responds to an increase in pressure differently-- Add two pounds to the back and its gonna rise more than if you add two pounds in the front? That would be my guess. These tires are FAT when uninflated. Have to imagine both upward and outward expansion. And i bet different areas on the tire stretch more than others. Anything more than a 4-5lb difference front/rear sounds loke a lot to me, but i could be wrong.
  11. Jul 11, 2015 at 7:51 PM
    NMTrailRider
    New Mexico
    Just curious- is 34/30 hot or cold?
  12. Jul 12, 2015 at 8:11 AM
    Dilleytech
    Jakob
    07 AC SR5 4x4
    Cold. Such as sitting in the drive way over night and being checked in the morning.
  13. Jul 12, 2015 at 8:16 AM
    Dilleytech
    Jakob
    07 AC SR5 4x4
    I guess any tire I have ran you can always visually get a good idea if a tire is under or over inflated. Being over inflated puts more pressure on the center of the tread which will result in premature tire wear. Since you have much more weight on the front tires they need more pressure to hold the same shape. Anytime I have gone on a drive and checked my pressure the front and back go up about the same in psi. Usually 2-4 psi it seems on both. Just my experience and opinion..
  14. Jul 12, 2015 at 8:35 AM
    Pigpen
    Dan
    Northwest Montana
    I run 40 for DD, that's 50% of the max psi. I air down to 30 on long bumpy drives, and to 20 for situations which require high traction. The numbers get fudged a bit for other factors.
    If I ran 80 psi...
  15. Jul 12, 2015 at 8:43 AM
    #35
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    34 Front and 32 Rear . Original BFGoodrich Rugged Trail T/A Tires.
  16. Jul 13, 2015 at 11:40 PM
    #36
    RKCRUZA
    RKCRUZA Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    Here is a Load Inflation Table from Toyo. Covers most P Metric and LT Tire sizes. Look up your tire and it will give you the recommended pressure for the weight of your vehicle. Set them up and then do a chalk test to make sure they are going to wear right. Only goes down to 35psi for LT tires (most likely because of heat issues with LT's at lower pressures).
  17. Jul 14, 2015 at 12:42 AM
    #37
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    Just to be clear, even though most people know this, tires do NOT have a recommended pressure on the side of them. They DO have a max cold pressure rating. Most people will never need to run a tire at max pressure. Especially on a Tacoma.
    On certain tires, you can exceed the max pressure on the tire, but at the expense of speed. Here is an example from goodyear: http://www.goodyeartrucktires.com/pdf/resources/publications/2010_loadinflation.pdf
    Tire pressure needed is related to actual truck weight, regardless of the tires weight rating. A C rated and E rated tire of the same size and design will be rated for the same weight at the same PSI. As PSI goes up, so does the weight rating. An E rated tire can hold a much higher PSI than a C rated tire, so therefore has a higher weight rating.
    Also, many vehicles have a recommended tire pressure based on the GVWR or GAWR. For a truck like the Tacoma, this might be pretty close for every day driving. For a one ton dually that sees very little real work, it will call for a PSI well above what is needed. If you operate your truck at a weight well below the GVWR, you will probably see your chalk test call for less pressure than the factory recommends, or higher if you are heavier than the GVWR.
