What tire PSI should I run?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Steves104x4, Jan 20, 2012.
  1. Jan 20, 2012 at 10:31 PM
    Steves104x4
    Steves104x4 [OP] Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    On the COSTCO website it says they ran 80 PSI in the Michelin X Radial LT2. I've heard to run 50 psi in Mastercraft truck tires, too. Is this correct? If someone that knows the truth about this, please chime in. Thanks.
    Michelin - X® Radial LT2Item #: 508295
    • Club-Exclusive, Long-lasting, All-Season Traction for Pick-ups and SUVs
    • Next Generation of Tire Even Better in Wet.*
    • Fuel efficient and long lasting†
    • Three Steel Belt Durability††
    • †Based on Michelin internal wear test results versus MICHELIN® X® LT tires.
    • ††Using four LT265/75R16/E tires inflated at 80 psi.
  2. Jan 20, 2012 at 10:35 PM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    Might I recommend 96 lbs!
    J/K
    On your tiny truck, I'd go with 32lbs. E rated means it'd ride rough at 15psi on your truck but that would be dumb. So ya, 32psi.
  3. Jan 20, 2012 at 11:45 PM
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    look on the drivers door jamb sticker, "cold tire pressure" on mine it says 29 psi
  4. Jan 20, 2012 at 11:48 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    once you go to a size and/or load range that is different than stock, what the door jam and owners manual say may not be correct any more.
    chalk test is always a safe way to figure out what PSI will wear your tires best (assuming your alignment is good)
  5. Jan 21, 2012 at 12:30 AM
    ACE808
    ACE808 Well-Known Member
    DDS
    808 State
    TRD Off Road 4x4
    Toytec 3" lift light racing uca moto metals 17" (958) k&n intake Helix throttle body Borla exhaust Nfab step bar All-pro transfer case shield All-pro spindle gussets All-pro sway bar links All-pro E-locker guard All-pro rear differential armor All-pro U-bolt flip kit L.E.D. White/Blue Dash Gauge lighting Full alpine stereo with TV screens Clifford alarm optima red top battery Full wet okole seats auto meter gauges (oil pressure & volt meter) Ebc slotted & dimpled rotor Goodrich braided brake lines Hawks Lts brake pads Rear diff breather relocation
    I agree look on the door jam. Don't run full psi. It's gonna be super stiff and harsh
  6. Jan 21, 2012 at 1:09 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    The door jam info is for the stock tires (BFG Rugged Trails or whatever)...
    They are a 35 psi max tire, and the Toyota recommended 29 front/ 32 rear is perfect for that tire.
    When I change to both a different tire (and a different size), that door jam suggestion has no more use. The new tires (Hankook Dynapro ATm) have a 44 psi max. rating, so I found 29/32 psi too squishy... 38 psi was perfect (actually 36-40 feels good)... in all cases it is LESS than the tire's recommended MAX. pressure, unless you fully load the truck to the max. weight load of the truck or the 4 tires under it.
  7. Jan 21, 2012 at 5:10 AM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    Toyota wants to give you a compromise between a good ride, traction, hauling capacity, safety, gas mileage and tire life (maybe). At 29 pounds of air you should get a better ride and better traction but tire life will go down.
    On the original Dunlops, with 35-38 pounds, I got 60K miles and could have gone to 65K before buying the Michelin M/S 2's. With these tires (Michelin), at 35 pounds of nitrogen, I get the traction that was missing on the Dunlops and all the other features that 29-30 pounds of air would give me with the Dunlops, but better.
    If you over inflate, you will wear the center of the tires out faster. With a well inflated tire, you may pick up a few MPG but going too far up reduces traction and ride comfort.
  8. Jan 21, 2012 at 5:16 AM
    redezman
    redezman Well-Known Member
    Charles
    Raleigh N.C
    2012 4Runner SR5 4x4
    All Factory for now, LOVE it that way
    i run 34 psi in all 4 michlelin ltx m/s2
    I found that 34 is best ride for me and even wear on tread
  9. Jan 21, 2012 at 6:27 AM
    myth01
    myth01 Well-Known Member
    south sf, ca.
    08 taco Trd sport
    eclipse nav.-w/ Bluetooth & iPod 3'' revtech add a leaf lift kit snug top ss truck cap dive tank racks in back Aux fuse box Aux back up lights, w/ interior fj cruiser stock switch Back up cam Turn signal cams Interior inverter -switched Aux audio/video inputs -RCA (including iPhone cable)w/ 4 input switch Mag light mount Tyredog stand alone tpms Spare tire extension hose Avid off road light bar(powder coated)
    When I changed my tires I call bf Goodrich, and they calculated the proper tire pressure for my vehicle . It's actually an option on the phone when you call
  10. Jan 21, 2012 at 6:57 AM
    RainDodger
    RainDodger YGWYPF
    Great Northwest
    '09 Black, TRD Sport
    None yet! It's new!
    The Tire Rack has a guy just for that - call them. He will tell you what to run based on your specific truck, your specific tires/sizes, and the loads you carry. Takes about 1 minute and that's what he's there for.
    I have non-stock tires on my '09 and he told me precisely what pressures to start with.
    Roger
  11. Jan 21, 2012 at 7:44 AM
    xxaarraa
    xxaarraa Well-Known Member
    I run 29 PSI all around in the winter coz we get a lot of snow here. Summer, I run 32 all around. I am not on stock tires.
    What PSI is similar to what oil. No right answer, do what feels right.
  12. Jan 24, 2012 at 4:34 PM
    shackley
    shackley Well-Known Member
    Albuquerque, New Mexico
    2018 TRD Pro MT Super White
    RCI rock sliders, Goodyear Ultraterrains 265/70/R16, BAK X2 tonneau
    I think Dave is about right. I did the chalk test on my 2012 ACC TRD and 35 psi looks right. I believe the ACC is a bit lighter than the DC. I'm running the 265/75 16s same as Dave. In snow with ice below it was perfect. I'll be down in W New Mexico next month on mud and rocks and report back.
    Steve in Albuquerque
  13. Jan 24, 2012 at 4:57 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    The max pressure/max load is just that...the maximum pressure for the tire at maximum load. Our trucks are light and the load they can handle isn't that much compared to a full size truck. With my e rated 265/75/16 bfg a/t k/o's the chalk test shows my psi should be around 36 front/34 back (with the weight of a canopy.)
  14. Jan 24, 2012 at 7:28 PM
    patpatpat
    patpatpat Well-Known Member
    '11 Prerunner SR5 4cyl 2WD DC
    Just came back from the dealership where they roadforce balanced my tires and set my tires and alert indicator at 38psi.
  15. Jan 24, 2012 at 10:25 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I run 32 psi all the way around every season. Never had any problems.
    I had 47,500+ miles on my other tires and they were about 40% then.
  16. Apr 1, 2012 at 10:46 AM
    zeus7625
    zeus7625 Member
    Zeus
    Daphne, AL
    PreRunner TRD SR5
    A.R.E. LSII tonneau cover
    I may sound like a dummy but.........chalk test? Teach me!
  17. Apr 1, 2012 at 10:53 AM
    David K
    The only dumb question is the one not asked...
    Of course, there are some here who love to yell at people to SEARCH for the answer... as if a fresh answer somehow is destructive or will over load the bandwidth of this site!
    How about I take some photos today of the chalk test being done?
    Stay tuned!! :cool:
  18. Apr 1, 2012 at 11:12 AM
    whopper
    whopper 2016 MGM 4x4 double cab
    wayne
    north carolina
    2016 tacoma double cab 4x4 MGM
    On going
    please do the pics on the chalk test not sure the way its done
  19. Apr 1, 2012 at 11:43 AM
    HMA
    HMA Well-Known Member
    Hal
    Bainbridge, Ga
    '10 Taco Surveying Machine '22 Lunar Rock
    I run 245/75/17 BFG AT's @ 60 psi. These are heavy duty 10 ply tires and this is BFG's reccomended pressure for them. I chose these tires because the sidewalls of 2 of the Dunlops got punctured by cotton stalks and they are about the same height as 265/70's. At 60 psi, you feel every little bump in the road, but the better performance and mileage is worth it.
  20. Apr 2, 2012 at 5:22 PM
    David K
    On my phone now. pics of chalk test just done. stay tuned.
