What tire size can I run?
Discussion in 'Wheels & Tires' started by Hdurham, Feb 20, 2019.
  1. Feb 20, 2019 at 9:58 AM
    Hdurham
    Hdurham [OP] New Member
    2009 Toyota Tacoma TRD 4WD
    1.5" leveling kit, 2" rear blocks & 1.25" wheel spacers
    Hey guys, new member here. I have a 2009 Toyota Tacoma TRD 4WD 4-door. It was stock up until about 2 weeks ago. I put a 1-1/2" leveling kit on the front and 2" rear block on the back. I'm now looking around for new tires, but I'm wondering what size I can run without rubbing. I also would like a little wider stance and thought that wheel spacers may be for me as well. Does anyone have a similar setup or have any knowledge about a setup like this? What's the largest tire I can run and what if I had 1.5" wheel spacers what would be the difference without rubbing.
    Thanks
  2. Feb 20, 2019 at 10:04 AM
    literallynothing
    literallynothing I tow my new truck around with my old truck
    Noah
    2017 DCSB
    Steel and 37s
    Welcome to TW. Please use the search function, or browse the website. There are countless threads on exactly what you’re asking. Good luck with your search, and be sure to post pics when it’s done!
  3. Feb 20, 2019 at 10:06 AM
    Wixo
    Wixo Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    Also look up the wheel spacer thing. A lot of people say they're bad.
  4. Feb 20, 2019 at 10:08 AM
    devidstaco
    devidstaco You look like a mothsfuckin uhhhhh
    David
    Tempe, AZ
    ‘18 QS DCSB TRD OR
    Nothing major
    Just get 255/85r16s or 255/80r17s.
  5. Feb 20, 2019 at 10:43 AM
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    too many factors go into tire fitment (backspacing, tire size, alignment specs). There are a couple stickied threads about this you should read though that will give you more knowledge. Biggest thing to remember is lift does NOT give you the ability to stuff larger tires. The best way to fit tires is to let your truck sit on its bump stops and turn hard left and and hard right. If you don't have any rubbing your golden, if you do rub, time to get out that angle grinder.
  6. Feb 20, 2019 at 12:21 PM
    jerryb1984
    jerryb1984 Well-Known Member
    Jerry
    2018 DCLB TRD OFF ROAD
    16x8 FUEL BEAST 265 75 16 FALKEN WILDPEAK AT3 Tyger step sides 20% tint front to match factory tint bilstein 5100s on third notch PRO grill
    265 70 17 or 265 75 16 would be the safe bet.
