What tire upgrades have others done?
Discussion in 'Wheels & Tires' started by TeaMan, May 5, 2012.
  1. May 5, 2012 at 10:45 AM
    TeaMan
    TeaMan [OP] Member
    I have a 2010 Tacoma access cab and would like to go at least a couple inches bigger with the tires. I'd like to keep the stock wheels if possible and don't mind adding a lift kit. Would like to avoid cutting the truck up. Anyone like to let me know what sizes of tires they may have put on stock rims on a truck like mine and had success. I have 265/65-17's right now. Maybe what lift kit you used too would help.
    I'm also looking for a recommendation for a good all around summer / winter tire. I live in North Dakota, so it does have to handle snow and ice for a good part of the year.
    The truck has a 6 speed manual, no locking differential, and yes is a 4x4 if any of that matters.
    This will at least give me a place to start.
    Thanks
    TeaMan.
  2. May 9, 2012 at 10:35 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    if you don't want to do any cutting, you'll have to stick with a 265/70/17. going to 33s will require the CMC and cutting part of the wheel well liner.
  3. May 11, 2012 at 5:38 PM
    TeaMan
    TeaMan [OP] Member
    Thanks, I hate to sound stupid, but what is CMC?
  4. May 11, 2012 at 5:41 PM
    YotaMatt
    YotaMatt Livin Low, Ridin High
    West Point VA
    12 PreRunner DC TRD Sport
    Spidertraxx 1.25" spacers in front and rear, 4" Maxtrac Spindles,Billy 5100s at 0", OME 885 Springs, 1/4" top spacer on both sides, 1.5" AAL, 3" Block, 1.5" 4crawler driveshaft spacer, 17x9 XD Spys with 35x12.50 Nitto Mud Grapplers, Magnaflow offroad Stainless Exhaust, Volant Intake with scoop,Camo emblems, BHLM, Tinted tailights, Anytime fog mod,Alpine Type R 12, Kicker 1000 watt amp,600 watt 4 channel memphis and all memphis components, 35%tint front all the rest at 5%, Hella 500s with sylvania zxe bulbs, sylvania zxe headlights, sylvania zxe fogs, Weathertech digi fits, flyzeye blue/white, LED map dome license plate lights, Redline hood struts, Tailgate EZ Down, Custom TRD Camo Browning Edition Bedsides, Camo wet okoles, Ridgid Dually bed lights, SOS Concepts Tire Carrier
    cab mount chop....im running a 3" toytec lift and 285/70/17 nitto trail grapplers....had them on my stock wheels at first but had to use 1.25" wheel spacers to prevent the tires from rubbing upper control arm....other than that havent cut anything and no rub
  5. May 11, 2012 at 7:25 PM
    Large
    Large Red
    Stock wheels & lift will rub the UCAs, you could run 265/70 on the sport 17s ( I did this for a month or so and loved the looks and performance ) without any lift on your stock suspension, this is what I'd recommend to you good sir. :)
