What tires do you use on your Tacoma for RV towing?
Discussion in 'Towing' started by Nordichawk, Apr 7, 2022.
  1. Apr 7, 2022 at 5:47 PM
    Nordichawk
    Nordichawk [OP] Nordichawk
    WPB, FL
    2008 4Runner SR5 / 2021 Silver Sky Tacoma SR5 DCSB
    I want to upgrade from the OEM tires (Toyo Open Country A31, P245/75R16) on my 2021 SR5 DCSB 2X4 Tacoma with tow package. I am not impressed with the performance of the Toyo and would like something with better wet/dry traction and higher standard load rating. Currently the Tacoma has been towing a 2021 Winnebago Micro Minnie 2108 (22’, 4,500 dry wt., 5,500 GVWR) with ease utilizing the Equal-i-zer WDH, Sumo springs and Redarc brake controller.
    I have researched various tire models and specs and the more I delved into it the more flustered I am on the selection of a suitable tire for towing. There are three tires size options I’m trying to select from: 245/75R16, 265/70R16 and 265/75R16. The truck is my DD and mostly highway travel and the same for towing. Which tire size and brand/model for towing would you recommend for my truck and why?
  2. Apr 7, 2022 at 5:52 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Michelins
    mac84 likes this.
  3. Apr 9, 2022 at 10:58 PM
    Jay-son
    Jay-son New Member
    2019 Tacoma TRD OR
    I carry my pop up slide in camper which is around 1400lbs and use the Goodyear Duratrac 265 75 16 LT. It has 3400 lb load capacity I believe at 80psi. I usually run it around 65 psi when loaded and feels great. When I used stock tires at 45psi , it was so bouncy. I also run firestone bags though but tires make such a big difference.
    LT265/75R16
    123/120Q E None 3,415 lbs 80 psi
  4. Apr 10, 2022 at 12:37 AM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    Stock size and Michelin. Once you run them, you probably won’t go back to anything else for a pavement pounder. Defender LTX M&S or AT2.
    Ride quality, traction, longevity
    mac84 likes this.
