What tires should I get ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bear-hunter1014, Dec 16, 2023.
  1. Dec 16, 2023 at 8:13 PM
    Bear-hunter1014
    Bear-hunter1014 [OP] Member
    2014 Toyota Tacoma TRD Sport
    I have a 2014 Toyota Tacoma TRD sport 4x4. I am currently running kenda klevers RT Lt 265/70r/17 120/117R E
    I like the tires but I’ve noticed my truck has trouble staying aligned and my tires eventually get choppy. Not sure if my tires are effecting everything or what ? I’ve ran Toyo’s open country , BF k02 , discover at3 and now my kenda klevers.
    My truck is also stock height. Any advice would be greatly appreciated!
  2. Dec 16, 2023 at 8:14 PM
    MR. ED
    MR. ED Member
    SW Colorado
    Cooper st maxx or mickey thomson baja boss at
    Been running the coopers for years. Awesome tires. Decided to switch it up and went with the boss’s. So far so good
  3. Dec 16, 2023 at 8:15 PM
    Cal671
    Cal671 Well-Known Member
    calvin
    AZ
    08 Taco smurf, 10 fj, 16 runner
    Check your alignment tabs see if it's flatten out by whoever did your last alignment
  4. Dec 16, 2023 at 8:17 PM
    23MGM
    23MGM Well-Known Member
    2023 TRD Off Road
    upload_2023-12-16_20-16-45.jpgSuper Swampers are always the answer.
    winkel, Squirt, Sprig and 3 others like this.
  5. Dec 16, 2023 at 8:32 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Don't go cheap on tires, I have been buying tires since the 70s.
    Just get a good quality tire and you'll be glad you spent the extra money.
    Good luck with your truck.
    Blockhead likes this.
  6. Dec 16, 2023 at 8:39 PM
    TheFactor
    TheFactor Well-Known Member
    So Cal
    2023 Tacoma TRD Off road
    Mickey Thompson Baja Boss for me and very happy.
  7. Dec 16, 2023 at 8:52 PM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    Have you worn out all those tires over many miles, or just like to change tires? That's a lot of different brands. I like my Geolandars. They are quiet, light, have decent road characteristics and snow/rain grip and wear very well. But I don't abuse them.
    https://www.amazon.com/Yokohama-Geo...fos.17d9e15d-4e43-4581-b373-0e5c1a776d5d&th=1
    Squirt likes this.
  8. Dec 16, 2023 at 9:02 PM
    Bear-hunter1014
    Are the Mickey Thompson Baja boss your running A/T or R/T by chance ?
  9. Dec 16, 2023 at 9:45 PM
    TheFactor
    So Cal
    LT285 75r 16 A/T :cheers:
  10. Dec 16, 2023 at 9:50 PM
    TacoTuesday1
    FL
  11. Dec 16, 2023 at 10:13 PM
    TheFactor
    So Cal
    Think the OP was looking for a
    Recommended tire brand to .
    What ya running and how do
    you like them ?
  12. Dec 16, 2023 at 10:38 PM
    TacoTuesday1
    FL
    Running 35x10.5r17 Kenda Klever RT
    they work
    cheaper than competitors
    seems quieter and better grip than my old WildPeaks, at least in normal conditions
    might be more oriented towards off road. Haven't compared in snow/ice
    TheFactor[QUOTED] likes this.
  13. Dec 16, 2023 at 10:47 PM
    Argann
    Argann Well-Known Member
    Rich
    4Runner, Tacoma, Defender 90
    I got 255/80/17 wild peaks. Light. E load rated. Good price from amz. No noise. Good so far. Need some snow time.
  14. Dec 17, 2023 at 12:55 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    I only run Michelin Defenders, the best all around tire on the market…
    spitdog and TedG like this.
  15. Dec 17, 2023 at 1:09 AM
    TacoTuesday1
    FL
    doesn't come in 35
  16. Dec 17, 2023 at 1:38 AM
    Blockhead
    Pittsburgh, Pa.
    Ahh …my bad
  17. Dec 17, 2023 at 3:15 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    The outside edges of the front tires will wear like that. If you rotate them regularly, no more than 5000 miles, that may help prevent them from getting too bad. The more aggressive the tire, the more important this is. On a street tire or an AT that isn't very aggressive you can go longer between rotations.
    It may be time to replace shocks/struts as well.
  18. Dec 17, 2023 at 4:13 AM
    Jonny_09_taco
    Jonny_09_taco Well-Known Member
    Jonathan
    2009 grey Tacoma off-road
    Prinsu roof rack Baja Ditch lights
    I’m running bf Goodrich right now but I’m planing on jumping to 35’s and I have heard a lot of good things about falkens wildpeak I’ll probably try those since I like to make trips to the snow
  19. Dec 17, 2023 at 4:51 AM
    Kiddog78
    Kiddog78 Member
    2012 TRD Crew Cab, long bef
    Lear topper, Rhino springs
    Loving the AT Coopers I put on my 12 Sport last year, by far best tires had on this truck
    Funny just put Kenda Klevers on my SxS & they are great
  20. Dec 17, 2023 at 8:21 AM
    Mully
    CA
    Real nice tire.
