What tires size should I get without rubbing??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by andresv, Jun 20, 2011.
  1. Jun 20, 2011 at 6:03 PM
    andresv
    andresv [OP] Member
    05 sr5
    I just got a 2005 Tacoma and want to buy 17x9 wheels ( don't know which ones yet), but I want to know what size tires should I get without any rubbing.
    I have a 3" lift and wasn't sure about the 285/70/17?
    Anyone can give some input??
    Do they rub? or is it better to get 265/70/17? I know that the look is not as cool as the285.
    Also how bout if I get the 285/75/16, of course buying a 16 inch wheel. Will those rub??
    Thanx.
  2. Jun 20, 2011 at 6:12 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    You will have to trim a lil if ya get the 285s
  3. Jun 20, 2011 at 6:13 PM
    Blackshirts
    TX
    Stuff
    And welcome to TW
  4. Jun 20, 2011 at 6:15 PM
    Carson
    Carson Well-Known Member
    Carson
    Modesto, California
    05 TRD Sport 4x4 SR5 V6
    Garage Fabbed +2 LT, FOA 2.5 RR w/ Comp Adj, 35 XMTs on Level 8s, 50T Spring Under w/ 13" Shackles, Elite Front Bumper, AP Rear, Retrofitted, Wicked Flow, Custom Roof Rack, Custom Sliders, Custom Scratches, 12" JL and an Audiopipe amp.
    ^ What he said, go with 285s, you won't regret it.
  5. Jun 20, 2011 at 6:15 PM
    Dibblit
    Dibblit Eh?
    Paul
    Stony Plain
    Truck
    Icon Suspension ARB OBA
    255/85 R16 should not rub
  6. Jun 20, 2011 at 6:15 PM
    DrewH
    DrewH Well-Known Member
    Look in the wheels and tires section.
  7. Jun 20, 2011 at 6:24 PM
    zzchipster
    zzchipster Well-Known Member
    2013 taco 4x4 trd lwb trd sc
    trd s/c and exhaust, 5100's,bud builts
    2657017 wont rub
  8. Jun 20, 2011 at 6:29 PM
    2011TACOMAWHR
    2011TACOMAWHR TACOMA 2011
    aaron
    lancaster SC
    2011 OR dbcb shortie
    big tires and tiny rims
    I have 33 12.50 17 3inch lift no rub
  9. Jun 21, 2011 at 4:51 AM
    andresv
    andresv [OP] Member
    05 sr5
    Thanx for all the help. I guess the 285's is the way to go.
    Question: What does the 33 12.5 17 compare to when it comes to 285/70/17?
  10. Jun 21, 2011 at 4:53 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  11. Jun 21, 2011 at 4:59 AM
    andresv
    andresv [OP] Member
    05 sr5
    Thanx. Now what size of wheels would be better, a 17x8 or 17x9.
    Also what off set should I have?
  12. Jun 21, 2011 at 5:06 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Offset depends on the rim width. You will need 4.5" or less backspacing. And if you opt for the 12.5" tire you will need to step up to a 10" wide rim. The 9" is ok for the 285, but I would avoid the 8" all together.
