what to ask when buying a 3.4 taco?
Discussion in '1st Gen. Tacomas (1995-2004)' started by tskr11, Apr 17, 2011.
  1. Apr 17, 2011 at 11:48 PM
    tskr11
    tskr11 [OP] soon to have a 3.4 tacoma
    Tashone
    Redding/Hoopa,CA
    91 pickup lifted 4 inches on 33s
    Knn intake, 4 inch suspension lift
    Alright I posted something like this in the "new member" forum but got no replies lol...
    I'm planning on getting a 01-04 3.4 xcab trd taco sumtime in the late summer...
    I was wondering what things shall I be looking out for as in the CONs and recalls and such...I know about the frame rust recall...I have a 3.0 and ther hell for blowin a head gasket so what issues if any do 3.4s have? I would like to hear as much as possible on personal experences, especially from original owners and long time owners...id like to hear small problems from dash light goin out to a blown motor...everything will be thot of, when I'm looking at a truck to buy...thanks
  2. Apr 18, 2011 at 12:07 AM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Besides the frame rust problem in northren states, weak rear suspension and well thats about it lol. There isnt really any major problems with these trucks. Mine has just about 146k and the only things that I know the previous owner has replaced was a fuel pump, all I had to replace was a alternator. Runs like a champ! And I dont really "baby" it all the time. ;)
  3. Apr 18, 2011 at 12:15 AM
    tskr11
    Tashone
    Redding/Hoopa,CA
    Yea its crazy how these trucks are just so reliable lol my build is going to be somewhat slow like urs no offense lol as in ill be doing things when I have money, so 1st the truck then lift then tires then start on some armour lol...I can't wait til I get the truck, really lookin forward to it
  4. Apr 18, 2011 at 12:21 AM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    Haha none taken. Im broke so it will take alil but I have some big plans for it. Just take your time finding one and pick the one that picks you and you will love it! Good luck. :cool:
  5. Apr 18, 2011 at 12:25 AM
    tskr11
    Tashone
    Redding/Hoopa,CA
    I have the same problem, being broke that is lol....but thanks man
  6. Apr 18, 2011 at 12:29 AM
    SlimDigg
    SlimDigg Resident MMA Fanatic
    Calgary, AB
    2001 TRD Double Cab Limited 4x4
    OME 881, Bilstein 5100, Icon AAL, Wheelers Anti-Sway kit, aFe Pro Dry-S Air Filter, Deck Plate Mod, Rear Diff Breather Mod, GE Nighthawk Platinum headlights, Wet Okole Seat Covers, Husky Liners. LED Tail Lights
    If the timing belt/water pump have been replaced.
  7. Apr 18, 2011 at 12:32 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    X2 on timing belt and water pump. Ask about maintenance papers. Other than that the 3.4 is a solid motor. My cousin has about 300xxx miles on his.
  8. Apr 18, 2011 at 12:33 AM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    Yea check with that. But if not, no worries. Its a non-interference engine. Meaning if the belt brakes the pistons WILL NOT hit the valves so no engine damge if it breaks. ;) but the pump is known for slight leakage, nothing major.
  9. Apr 18, 2011 at 6:48 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    The 01-4 Tacomas are notorious for these small qwerks. Obviously not every Tacoma has these. These are just the more common ones.
    1. Frame rust
    2. Premature ball joint wear
    3. Leaking rear axle seal
    4. Leaking oil pan seal
    5. A/C blown motor
    6. Leaking CV boot
    7. Transmission "Thunk"
    Those are the most common.
  10. Apr 18, 2011 at 6:52 AM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    There was a recall on the ball joins I believe, but it was not a large one.
  11. Apr 20, 2011 at 2:50 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    Correct.
  12. Apr 20, 2011 at 2:52 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    I have seen a few with the axle problems but not many at all. And the CV boot isnt that usually with the lifted Taco's? And just to add to the list some have a slight dashboard rattle, (mine doesnt so I dont know much bout it)
  13. Apr 20, 2011 at 2:56 PM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    Yes. You can check by VIN on toyotaownersonline.com for the recall and whether a truck you are considering has had the recall performed. Mostly certain 01s and 02s, I believe (it was a bad batch of scratched BJs, not a universal design issue). Any dealer will replace it no questions asked and align it, too. At least, that was my experience. Don't let it stop you from buying a truck, but do get it done immediately if you do buy a truck that needs it.
  14. Apr 20, 2011 at 9:20 PM
    04LTtacoma
    04LTtacoma Well-Known Member
    Morty
    Outer Space
    Is it fast???
  15. Apr 20, 2011 at 9:36 PM
    tskr11
    Tashone
    Redding/Hoopa,CA
    Alrite man that's some good info THANKS lol
