What to blame for harsh freeway ride?
Discussion in 'Suspension' started by Styx586, Jan 7, 2016.
  1. Jan 7, 2016 at 1:23 PM
    Styx586
    Styx586 [OP] Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    Here's my issue, the truck rides ok around town. Obviously firm because of my setup, but not unexpectedly harsh. However, on concrete paved freeways (with the stupid seams every 10 feet) at 70ish mph the truck bounces horribly. It's extremely uncomfortable and becomes unbearable on long trips. I've got Icon coilovers (set to factory setting about 2" of lift), Icon progressive AAL, Icon VS 2.0 rear shocks (non-resi), and LT285/75r16 BFG ATs (normally in the 33-35 psi range). So my question is, what is causing the crazy bouncing? I'm considering downsizing to a P metric tire 265/75r16 or maybe my rear setup is to blame? I feel like maybe my rear shocks aren't valved properly for the stiffness of the 3 leaf AAL, though my whole setup is from Icon so I assumed they were designed to work together. Another reason I suspect my rear end isn't working together properly is while towing the boat (16' bayliner) the rear end and trailer bounces a lot. Any input would be greatly appreciated!
  2. Jan 7, 2016 at 1:25 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    The 3 leaf AAL isn't stiff.
    I'm going with your tires are too stiff, by design (I assume they're E rated).
  3. Jan 7, 2016 at 4:56 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    +1 for tires. I have that same exact setup with c rated 265/70/17 and I don't have those issues, although I don't like the way the rear shocks are valved. I'd hate to say it, but I think the 5100's on my old truck handled better in the rear with the Icon AAL. I'll never repeat that though :spy:
  4. Jan 7, 2016 at 9:39 PM
    Styx586
    Terrance
    Lake Elsinore, Ca
    Yea I figured most would condemn the tires, and i'm seriously considering downsizing back to a P tire. I'd like to hear from @icon_rep about the valving though of the non-resevoir rear shocks for 1st gens. I've noticed in the "stage" kits, a stage 1 comes with the non-resi shocks and no AAL, and the stage 2 comes with the AAL and shocks with resevoirs. Are the resi vs non-resi shocks valved differently to run with or without the AAL, or are they both basically the same? I bought my parts individually, not as a kit. Should I have gone with the resi type rear shocks?
  5. Jan 7, 2016 at 9:45 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Its not the aal..... its waaaaay plush imho, thats the whole point.
  6. Jan 7, 2016 at 9:52 PM
    techride
    techride Weekend Warrior
    Stuart
    British Columbia
    2014 DCLB v6 4x4
    Bilstein/Icon 2" suspension lift with wheelers 5 leaf springs, 7-pin relocate through bumper, bfg KO2s, redline hood struts, immryo mirror relocation, stubby antenna, dipped emblem, heated mirrors, Jason trek cap, led fogs, debadged
    I would also check the condition of the seals on your suspension... I have e rated tires at the same pressure, the exact same rear shocks AND a wheelers HD leaf pack (stiff) and I haven't been too bothered by anything at high speed. Perhaps it's time for a suspension service? Do you carry any weight regularly?
  7. Jan 7, 2016 at 10:00 PM
    Styx586
    Terrance
    Lake Elsinore, Ca
    It's pretty rare that I carry a lot of weight, occasionally I'll load up a couple motorcycles or tow the boat, but thats pretty much it nothing serious. The coilovers only have 25k miles on them and my rear setup has only 15k... cant imagine needing a rebuild already.
  8. Jan 7, 2016 at 10:02 PM
    techride
    Stuart
    British Columbia
    2014 DCLB v6 4x4
    Is the bouncing more noticeable in the front or the rear?
  9. Jan 7, 2016 at 10:04 PM
    techride
    Stuart
    British Columbia
    2014 DCLB v6 4x4
    Sometimes product sits on the shelf for an extended period of time before its purchased and put to use. Seals dry up and become dysfunctional. I'm not car mechanic but that's something I used to see in mountain bike suspension all the time! It's worth having a look, anyhow!
    robertjohnsonjr likes this.
  10. Jan 8, 2016 at 7:38 AM
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    This is well outside my range of experience, so be warned I'm probably talking out of my ass, but I'd expect a stiffer tire to produce bumps and thuds rather than "bounce".
    Can you describe in a little more detail what you are feeling? Is it a sharp thud as you go over the slab seams on the highway without much larger body motion? Or are you actually "bouncing" in the sense of larger body motion like rocking as the suspension gets hit with bumps from the slab seams?
    If it is the former it sounds like tires and an easy way to investigate that would be to run *briefly* along a section of road that causes the problem at significantly lower tire pressure. If it is the later then it sure sounds like the suspension is under damped and a failed suspension component, especially a shock, could be the cause. Sure your shocks *should* be fine given you don't have that many miles on them, but certainly they could leak or have been charged to the wrong pressure or who knows what else.
    Good luck!
  11. Oct 7, 2016 at 4:58 PM
    insocova
    insocova Well-Known Member
