What to do about leaking valve cover gasket?
Discussion in 'Technical Chat' started by Yoshio, Feb 25, 2013.
  1. Feb 25, 2013 at 4:34 PM
    Yoshio
    Yoshio [OP] Well-Known Member
    Scott
    Central Coast, CA
    2007 SW 2.7L 4x4 SR5
    Double Cab Step Tubes, 35% Tint Front Windows, Husky Mud Flaps, Illuminated 4x4 Switch, Debadged, DEPO LED tailights, Undercover SE Tonneau Cover, Panavise In-Dash Mount, Plasti-Dipped Front Bumper Lip, OEM Front Fogs, Rear Fog Lamp, LEDs throughout, Door Sill Protectors, Color Matched Satoshi, Rear Window Security Bar, ImMrYo Rear Mirror Bracket, Added factory DTRLs & DTRL kill switch, Rear Diff Breather Mod, 17" FJ Alloy Rims, Sport shocks coils leafs, DEPO black headlights, off-road recovery hook, skid plate, BT-35 TOY Bluetooth kit
    My service tech told me today that my valve cover gasket is leaking and I should replace it and the Pcv valve... A couple questions; can I do this myself? Is this a bad leak? When I searched the forums, someone said it could be covered under the power train warranty, is that true?
    2007 4 cylinder 4x4 with 72,000 miles
  2. Feb 25, 2013 at 4:40 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Looks easy to me. Leak doesn't look horrible but it is getting around so I would fix it. Pull off your intake piping, and coils. Remove valve cover, clean surface, install new gasket with anaerobic gasket maker, install and torque bolts. Bam done.
  3. Feb 25, 2013 at 4:41 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    I just did my 99 Camry yesterday. Search youtube for a video :thumbsup: helps.
  4. Feb 25, 2013 at 4:42 PM
    Yoshio
    Scott
    Central Coast, CA
    Sounds easy... and the pcv valve?
  5. Feb 25, 2013 at 4:48 PM
    ImpulseRed008
    Susan
    SC
    I didn't replace mine
  6. Feb 25, 2013 at 6:25 PM
    Spoonman
    Jamie
    Alberta
    Shake it around, do you hear a ball inside moving around? Can you only bow through it one way? If so, keep it! Or replace it do peace of mind since you have it off. And they're cheap.
  7. Feb 25, 2013 at 6:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I'd tighten the valve bolts first, and see if that doesnt make the leak stop. re torque them to spec, in the propper sequence, clean the oil off, then see what it looks like in a week.
  8. Feb 26, 2013 at 10:57 AM
    BamaToy1997
    Bill
    Navarre, FL
    X2.
    Check for correct tightness, then clean and reinspect. That leak seems pretty minimal.
  9. Feb 26, 2013 at 1:08 PM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    You could just clean it with some type of degreaser (carb cleaner)
  10. Feb 26, 2013 at 4:37 PM
    Yoshio
    Scott
    Central Coast, CA
    What is the torque on the cover bolts? My Haynes manual says 80 in-lbs... That seems really low...
  11. Feb 26, 2013 at 4:41 PM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    Mine started showing some oil around the edges a while ago. I just checked the bolts and they were all loose. I have no idea what the torque spec is, so I just tightened them by "feel", cleaned it real good and now, at least a year later have not seen a drop of oil.
  12. Feb 26, 2013 at 5:03 PM
    Yoshio
    Scott
    Central Coast, CA
    None of mine are loose to the touch... :-(
  13. Feb 27, 2013 at 4:04 AM
    Yoshio
    Scott
    Central Coast, CA
    Guess I need an in-lbs torque wrench... To harbor freight!
  14. Feb 27, 2013 at 4:10 PM
    Yoshio
    Scott
    Central Coast, CA
    Checked my bolts, and they are all good, but I came across a little bulge coming out from between the valve cover and engine block, should I be concerned?
    New seal and new Pcv should be in to the dealer soon.
  15. Feb 27, 2013 at 9:56 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    that is rtv to cover the front cover to the cylinder head seam, Keeps the joint from leaking oil in that area on the valve cover.
  16. Feb 28, 2013 at 6:48 AM
    Yoshio
    Scott
    Central Coast, CA
    Is that using anerobic gasket maker in addition to the new factory seal?
    Is this something I need to re-accomplish, or is it possible the silicone is still good?
    Thanks guys, seal & new valve came into dealer today, should be doing this tonight...
  17. Mar 2, 2013 at 4:37 PM
    Yoshio
    Scott
    Central Coast, CA
    So after getting the cover off, I'm sure it was the seal. Both the cover gasket and spark plug gasket were super brittle and "shorter" than their replacements. The new gaskets actually make contact with both surfaces before the surfaces touch. Buttoning up the cover now, we'll see if it still leaks.
  18. Mar 2, 2013 at 5:20 PM
    BUZZCUT
    Georgia
    put a dab of rtv back on those seam areas before plopping the gasket in place. Also use a torque wrench to tighten the bolts
  19. Mar 2, 2013 at 6:51 PM
    Yoshio
    Scott
    Central Coast, CA
    Done and done! This time the cover rests higher than before, I might guess that the "loose" bolts are really a product of the gasket shrinking...
  20. Oct 26, 2014 at 12:42 PM
    TurboBoss
    TurboBoss Active Member
    Panama Rep. of Panama - Central America
    Guys,
    Can you let me know the torque specs for the valve covers screws and the proper sequence. Is there is a sequence schematic about this.
    I am planing on changing my valve cover gasket and I am glint to take pics for a sticky DYI
