what to do about rear diff. fluid???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRDfarmerTN, Apr 24, 2010.
  1. Apr 24, 2010 at 8:55 AM
    TRDfarmerTN
    TRDfarmerTN [OP] Well-Known Member
    20% tint, painted handles,painted grill, wet okole seatcovers,sockmonkey decals
    i have a 2008 4x4 SR5 truck non-trd...and ive not been able to find out forsure by the VIN or a rear diff tag if its got a LSD or not.....no tag on the rear diff, and the dealer couldnt find out anything for me by the VIN...so what fluid would u use??? theres no locker or diff buttons inside. thanks
  2. Apr 24, 2010 at 8:57 AM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    Sr5 is open diff I think so just use whatever gear oil weights without the additive, I think its 75w-90 or something like that
  3. Apr 24, 2010 at 10:28 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Keep in mind that all Double cab long bed 2005-2008 have LSD by default ... even if they are not TRD sport.
  4. Apr 24, 2010 at 10:47 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    15 Lariat Sport 5.0L
    3rd gen forum caused me to get a Ford
    some 05-08 non-sports in sr5 had the LSD option. if there is no sticker on the rear diff stating to use LSD oil, then I would say you have an open.
  5. Apr 24, 2010 at 10:50 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Correct.
  6. Apr 24, 2010 at 11:38 AM
    TRDfarmerTN
    ok thanks guys...yeah there is no sticker on the diff saying LSD so i figure its a open diff.
  7. Apr 24, 2010 at 4:39 PM
    docbrown
    docbrown Well-Known Member
    Tampa, FL
    05 Tacoma SR5 4X4
    Doug Thorley Long Tube Headers, Eclipse 6620 AVN GPS/DVD, K&N Drop-in Air Filter, Hose clamp mod, Redline Quick Lift Elites, Bilstein 5100's at .85, Firestone Ride Rite Air Bags, Weather Techs front and back, Bug Guard, and Factory Bull Bar, Wet Okole's up front, Bed Mat, LED interior lights, Fumoto Oil Valve
    Use Royal Purple or Mobil1 synthetic and you should be fine either way.
