What to do about the rear being to soft!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by prerunner32, Aug 14, 2011.
  1. Aug 14, 2011 at 7:28 AM
    prerunner32
    prerunner32 [OP] TRD
    Alan
    Foothill Ranch
    05 Prerunner TRD Sport Longbed
    285/70/17 BFG A/T's, 17in Method Double Standard Wheels, Camburg 2.5 Coilovers, Alpine Head Unit, Infinity Speakers, 10" JL Audio Sub, 2 Rockford Fosgate Amps, AFe Stage 2 Si (Oiled)
    Ok here is my problem. My truck rides fine with nothing in the back (maybe a little soft in the rear at times but nothing major). Its stock right now. I have about 500lbs in the rear currently (2 dirt bikes, gear ect..) and it has leveled out the truck like I would expect it to. But was very surprised how it drove. It seemed to bottom out a lot especially over speed bumps ect. It almost felt like I was driving my prerunner on the street from the body roll that was created on corners.
    Does anyone have some information about the TSB? And is it to late for me? I am not the first owner and just bought the truck about 3 weeks ago.
    Another option would either be AAL or get some deavers sprung for me. Do you think a simple AAL would fix this problem? Or would it be best just to go all out and get some Deavers made up for me and do it right.
    Thanks in advance!
  2. Aug 14, 2011 at 7:30 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    You are far too late for the tsb. It is covered under the 3yr 36k warranty. Your options are the AAL, airbags, or a new leaf pack. I'd try the AAL first since it is the least expensive.
  3. Aug 14, 2011 at 7:39 AM
    prerunner32
    Alan
    Foothill Ranch
    Yea this is what I have been considering. What AAL would you recomend? Toytec? Or do you think I should do it right and get some Deavers :)))
  4. Aug 14, 2011 at 10:06 AM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    Don't do deavers if you plan on hauling weight. Wonderful product but they are designed to be softer than the factory springs and tend to sag under weight. You need something with a higher spring rate. i.e. an add a leaf, or perhaps a new pack as was mentioned (dakar etc.)
  5. Aug 14, 2011 at 10:09 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Icon and Wheelers both have a 3-leaf progressive AAL that rides very nice and supports weight pretty well. I have them in mine and have been impressed so far. I'd recommend lookint into it if you're going the AAL route. It's more expensive than a single AAL but comes with new centering pins and U-bolts.
