What to do about tpms?
Discussion in 'Wheels & Tires' started by thewhiteknight, May 17, 2012.
  1. May 17, 2012 at 10:28 AM
    thewhiteknight
    thewhiteknight [OP] Well-Known Member
    Colby
    SW Alabama
    06 PreRunner TRD SR5 Dbl Cab
    foglight anytime, HIDs, lift, bilstein 5100s, AAL, LED interior, LEDs, BHLM, extended rear diff vent mod, upgraded audio system,
    I'm selling my stock TRD sport rims and tires tomorrow and I was wondering do I need to break them down and get the tpms out or just let it go with it? I'm getting aftermarket rims so I don't know if it's compatible. I would like to keep it but if it's more trouble than it's worth I'll let it go
  2. May 17, 2012 at 10:31 AM
    iRepLONGBEACH
    iRepLONGBEACH SoCal Reppin
    SoCal
    10 MgM dcsb TRD Sport
    Keep em just in case. Mine were able to fit my aftermarket rims.
  3. May 17, 2012 at 3:38 PM
    Discount Tire Direct
    Discount Tire Direct Wheel and Tire Guys Vendor
    They should fit your aftermarket wheels. TPMS sensors aren't cheap.
  4. May 17, 2012 at 3:48 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    X2.
  5. May 17, 2012 at 3:50 PM
    korslite
    korslite Well-Known Member
    Justin
    Bellingham, WA
    DCLB Sport
    FOX 2.5 RR's, TC UCAs, TC Spindle Gussets, Allpro Expedition leaf pack, Fox 2.O RR w/ Comp adjusters, 17" ATX Artillery, BFG AT 285's, de-scooped, custom sliders, custom bedrack, Brute Force Fab bumpers, Smittybilt XRC8 winch, ARB locked Rear diff
    Sell them separate from the wheels and tires, then ignore the light on the dash. You will probably get more money splitting them. Who needs their vehicle to tell them they have a low tire anyway?... :) just my $.02
  6. May 18, 2012 at 6:49 AM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    Let them go and disable the TPMS. When I got my Tacoma it had aftermarket wheels without TPMS sensors. There is a thread on here about how to disable the TPMS. It involved cutting one wire and grounding it. Took me less than 5 minutes to do.
  7. May 19, 2012 at 9:58 AM
    thewhiteknight
    Colby
    SW Alabama
    If I decide to keep the tpms how do I take it out. Will I have to break it down and go from the inside or does it unscrew like the inside of the valve stem?
  8. May 19, 2012 at 10:28 AM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Later models ('08+) grounding doesn't work, you need to apply a voltage to it. The actual logic level is 5v, but people have used 12 without a problem.
    Personally, I'd use 12v but run it through a 2k resistor.
    Have to break the bead. The stem sticks through the rim but the sensor is a couple of inches long and inside the tire.
  9. May 26, 2012 at 9:42 AM
    thewhiteknight
    Colby
    SW Alabama
    Well I took the tires to a shop to get the tpms out the other day.. They only charged 20 bucks to do it so not to bad..
