What to do ahhhh?
Discussion in 'Suspension' started by NumNutz, Nov 12, 2009.
  1. Nov 12, 2009 at 9:47 AM
    NumNutz
    NumNutz [OP] One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    I'm stressing a little and need some input. I want to lift the truck a small amount (2.5 at most) and I want to keep a smooth ride.
    This is what I'm looking at:
    Front -
    Bilstein 5100s set at .85" - $190
    Eibach Front Coils - $105 GB Price
    Used Top Plates from Toytec - Unknown
    Toytec will only give me the top plates if I buy their Bilsteins and they do the assembly of my 5100s and Coils. They are going to charge me $100 to assemble them. So I get the assembly and top plates for $100 basically.
    So I have a front lift for - $395 + shipping
    Rear -
    TSB AAL - $80 + shipping
    Toytec suggests that I also purchase -
    Shock Extenders - $15 -- These are suppose to keep me from losing 2" of travel keeping my stock TRD rear shocks.
    Driveshaft Carrier Bearing Drop Kit - $11 -- This is suppose to eliminate vibrations that can occur from the driveshaft due to the lift.
    Sounds like shipping will be around $50. So an entire lift kit for - $550 to my door.
    I want this lift for driving in deep winter snow and looks. I'm not a hardcore wheeler.
    Is this a good deal? Will this meet my needs? I don't want to spend anymore than this.
  2. Nov 12, 2009 at 9:54 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Get some billys in the rear as well.
  3. Nov 12, 2009 at 10:01 AM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    I'd just go with the OME kit if I were you... It has all you'd need and is a great quality kit. I've heard it rides great, and Chris4x4 can give you some input...
    But as for that setup, I think you'd be fine. Good luck!
  4. Nov 12, 2009 at 10:05 AM
    NumNutz
    Virginia Beach, VA
    Lots.
    Don't want to spend any more money :eek:
    Too expensive
  5. Nov 12, 2009 at 10:09 AM
    Incognito
    VA
    Gotcha...
    You could go with kit without the shocks... Or you could order Billy's for the front and back for $300 more from Downsouth Motorsports... That would be around $600, which is $50 more than your original option.
  6. Nov 12, 2009 at 10:10 AM
    1337Taco
    Kevin
    NorCal
    2015 4X4 Manual
    Then yea, you should be good with the setup you listed and you can always upgrade your rear shocks later.
  7. Nov 12, 2009 at 10:12 AM
    rob1
    rob1 Well-Known Member
    Robert
    South Texas
    Indigo Blue DblCab 4X4 Long Bed TRD Sport SR5
    Tail gate mod, locking gas cap, locking spare tire, rear spring tsb,Weathertech Digital fit's
    Just save like I'm doing for the OME kit, what's the rush!!??
  8. Nov 12, 2009 at 10:49 AM
    NumNutz
    Virginia Beach, VA
    Lots.
    My parents are going to be pissed at me spending 500 on a lift. The more I spend the worse it is. It's my money and it's my truck but they still have opinions and such.
  9. Nov 12, 2009 at 11:08 AM
    NumNutz
    Virginia Beach, VA
    Lots.
    Any more opinions on this?
  10. Nov 12, 2009 at 12:29 PM
    09Doright8126
    09Doright8126 Well-Known Member
    Andrew
    Greenwood, SC
    '09 DC TRD Offroad Pyrite Prerunner
    Aires chrome bullbar, Wet Okole seat covers, 6" KC offroad Slimlites w/ covers, upper Grillecraft black w/ TRD emblem, Redline hood struts, URD TCAI w/ black wrap, URD MAF Sensor, NST pulleys, NST intake manifold spacer, Bilstein 5100s, Eibach coils painted red, painted red brake calipers, SST brake lines, debadged tailgate, window tint, bed mat, extra D-rings, Rear TSB, Tranny TSB, swaybar removed, DTLT headers, URD Y-pipe, Vibrant Resonator, MagnaFlow
    This what I did... 4 Bilstein 5100s from downsouthmotorsports $283 + Eibach springs (group buy) $120. I left the front shocks at 0" and got 1.6" of lift on the front. However, you can set the front billys to .85" and get 2.45" of lift on the front. Get the rear TSB done for free and an AAL if you want for about $80. Install yourself (I did) or have a garage do it.
  11. Nov 13, 2009 at 9:23 AM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    I'm surprised someone hasn't said this yet, but when you start getting to the 2.5" lift mark you may run into alignment issues. New UCA's are a minimum of $449...
    If I was you and didn't want to spend so much money get 5100 on all four corners ($300 shipped from Down South Motor Sports), set the front to 1.75" and get the TSB done for the rear and call it a day. What's another 3/4 of an inch really going to do for you?
    In the next year or so save your money up and get new UCA's and some coils (Eibach or OME) and set the bilsteins to stock height and let the springs do the lifting. That way you don't have to shell out a huge chunk of change for the first time lift and you have versatility later on down the road...
  12. Nov 13, 2009 at 10:20 AM
    09Doright8126
    Andrew
    Greenwood, SC
    I agree (2x)
