What to do at ten years old
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WoodyWagon, Mar 24, 2019.
  1. Nov 16, 2019 at 7:57 AM
    WoodyWagon
    WoodyWagon [OP] WoodyWagon
    Langhorne, Pennsylvania
    2009 TRD OffRoad Access Cab
    Okay, you convinced me. I ordered all new coolant hoses, including all of the small molded hoses. I will replace them all next week. I also will replace the SLT solenoid, new strainer, and add Lubeguard to the transmission, (different thread). That should do it for years to come.
    69L46Vert likes this.
  2. Dec 2, 2019 at 3:37 PM
    WoodyWagon
    So far I have replaced almost all of the coolant hoses. There are I think, seven molded hoses, besides the radiator hoses and the heater hoses. There is one molded hose that I can’t reach one clamp. I will take off the thermostat housing, then I think I can reach it. I ordered a new t-stat and O ring, hopefully this does the trick.
    Just changing the radiator hoses is not enough. What about the other hoses? Don’t they count?
    Rick's 2012 likes this.
  3. Dec 6, 2019 at 3:25 PM
    WoodyWagon
    Had to remove the aluminum housing that the thermostat assembly bolts onto in order to get to that one molded hose clamp, but I did it. Now, all of the hoses that coolant flows though are replaced, plus a new thermostat. At least ten more trouble free years in front of me. I can concentrate on just changing the oil, greasing the u joints, etc. Easy Peasy!
    Skyway, Rick's 2012 and DavesTaco68 like this.
  4. Dec 6, 2019 at 7:18 PM
    JAGCanada
    JAGCanada Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    Once you popped the hoses off, how'd they look? Mine approaching 10 years soon.
  5. Dec 7, 2019 at 4:15 AM
    WoodyWagon
    Actually, they did not look all that bad. I changed them because I replaced the fluid, and the serpentine belt, and I figured, the hoses are 10 years old. Better to change them at my convenience then have to change a leaker when it is 10F outside.
    Skyway likes this.
  6. Dec 7, 2019 at 4:45 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Good job WoodyWagon :thumbsup:
    That’s a fine-looking solid truck...all stock it appears. Hope you get another 20 years out of it.
    ilikeike likes this.
  7. Dec 7, 2019 at 5:15 PM
    Tacosail
    Tacosail Well-Known Member
    Jerry
    Hermanville Heights, Ohio
    '13 white ACLB
    '17 wheels,int. Wipers , bed mat , relocate trailer plug , husky floor liners , Lund nerf bars, wet Okole seat covers- heat & lumbar.
    Nice job. How does it feel to get to know your truck better and pocket a couple grand of wrench labor money?
  8. Dec 16, 2019 at 12:20 PM
    WoodyWagon
    I feel a sense of accomplishment.
    And I definitely know my truck better.
    And twenty years sounds good to me!
    nd4spdbh, Tacosail and Skyway like this.
  9. Dec 16, 2019 at 1:49 PM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    I changed my radiator after actually meeting a guy at the parts store who suffered the pink milkshake problem.
    Older rads can leak coolant into the trans fluid, shitty idea and design. I found a new denso rad from rockauto for only $40.
    Cheap insurance
  10. Dec 16, 2019 at 1:54 PM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    In the 60's and early 70's hoses didn't seem to last long. Today, I have seen them go unbelievably far and long.
    TheDevilYouLove likes this.
  11. Dec 16, 2019 at 4:46 PM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    That was a definitely a problem with the Nissan Frontier, don’t think that’s happened to many Tacos?
  12. Dec 16, 2019 at 4:50 PM
    Shawn_of_the_dead
    Shawn_of_the_dead Well-Known Member
    Shawn
    Miami, FL
    2020 Cement SR5 DCSB
  13. Dec 16, 2019 at 4:51 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Happened here and there on 1st gen taco / 3rd gen 4 runner radiators. VERY VERY rarely happens on 2nd gen taco rads.
