What to do before going Long Travel
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cash2u, Jun 22, 2021.
  1. Jun 22, 2021 at 4:50 PM
    Cash2u
    Cash2u [OP] Member
    2017 TRD SPORT
    3 inch Toyotec Lift 33in Ko2 BFG
    Been looking on the forum on and off for a few weeks about suspension and long travel. I just swapped out my OEM suspension for the Boss 2.5 kit. It was an absolute headache of a job but still really fun. Currently looking for mods that I can add to my truck to start moving in the direction from mid travel to long travel. I’ve read the forums about long travel and made phone calls to shops but what I’ve heard is it’s one big jump.
    Some things that come to mind would be:
    35s
    Re gearing
    Fenders
    If anyone has any advice or ideas of what I could do to prepare to make the jump to long travel that would be awesome.
  2. Jun 22, 2021 at 4:51 PM
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    Cash out your GME and Doge
  3. Jun 22, 2021 at 5:00 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    If you're still holding doge you f'ed up.
    OP, long travel looks like plenty of cutting/welding along with above bed bracing. Basically your truck will be a one trick pony, no more hauling plywood or building materials in the bed. It will be really good at that one trick, though.
  4. Jun 22, 2021 at 5:02 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I had no idea what a boss 2.5 kit was, so I had to google it. I saw no evidence that it is mid-travel. The definition of mid travel generally includes extended length coil overs, UCAs, new leaf packs, and extended length rear shocks.
    In any case, I believe the general wisdom is that there is no incremental path from mid travel to long travel. It’s all or nothing
  5. Jun 22, 2021 at 5:34 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Longer brake hoses.
    Cash2u[OP] likes this.
  6. Jun 22, 2021 at 5:34 PM
    Cash2u
    Cash2u [OP] Member
    2017 TRD SPORT
    Awesome thanks!
  7. Jun 22, 2021 at 5:39 PM
    gudujarlson
    Minnesota
    But why would you do that before deciding on how much you are lifting it with the long travel? Just get the max length? Is there a drawback to brake lines that are too long? There seems to be zero benefit to having longer brake lines on a standard 2” lift. I don’t even have those on my 2” mid travel lift. With that logic, you could add limit straps too.
  8. Jun 22, 2021 at 5:50 PM
    eurowner
    eurowner Duke Sky
    Scoty
    4” longer rear and 1” longer front, no big deal with long travel suspension. I am not talking about 2” lift. It would really suck after your got your long travel suspension installed and find out the brake hoses are taught before full droop.
    Serious Off road vehicles with a lot of suspension travel have the brake hoses in springs to pull them away at full compression.
    If they are too long they can drag on stuff, get caught etc.
    Killer deal https://www.tacomaworld.com/threads/front-and-read-hs-stainless-brake-lines.725898/
  9. Jun 22, 2021 at 6:01 PM
    gudujarlson
    Minnesota
    I understand you. My point is that installing longer brake lines long before you need them could be a waste of money.
