What to do? (Tire pressure)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Xewkija631, Nov 7, 2012.
  1. Nov 7, 2012 at 2:01 PM
    Xewkija631
    Xewkija631 [OP] Well-Known Member
    LI,NY
    2011 BLACK DC TRD OFF ROAD
    My tire pressure light has came on; what does this usually mean? is their a leak in my tire or have I just lost a bit of air? What should I do first? out air in? and if that does not work what should I do after?
    Also, once I fill it up with air would the light automatically go off?
  2. Nov 7, 2012 at 2:04 PM
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    yes just check your pressures. Set them back to what the tag says inside the door jam. The light is set to go on when one or more goes under 25% off the normal value i think. Just air back up and the light will go off. You may have to drive down the street and back for it to recognize the change.
  3. Nov 7, 2012 at 2:15 PM
    Ray
    Ray Well-Known Member
    San Diego
    09 Pre-Runner
    Don't forget to check the spare as well.
    Ray
  4. Nov 8, 2012 at 4:58 AM
    Xewkija631
    LI,NY
    What do you mean by this? I have never touched my spare...:confused:
  5. Nov 8, 2012 at 5:17 AM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    2011 spare doesnt have a sensor
  6. Nov 8, 2012 at 5:27 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    From 2005 thru 2008 or 2009, the Tacoma had a sensor in the spare and a lot of people would have their tire pressure light come on, check the 4 drive tires and forget to check the spare. It's a good idea to check the pressure in your spare periodically anyways, but that's not causing your light to come on.
    As the weather turns colder, the air inside your tires shrinks and can sometimes trip the pressure sensors to read low. Check the pressure in all 4 tires, adjust if necessary, then reset the sensors. There is a reset button below the steering wheel, press and hold it for 5 seconds, until it flashes and it will reset.
  7. Nov 8, 2012 at 5:47 AM
    aaronbuell
    aaronbuell Well-Known Member
    aaron
    windsor NY
    09 TRD/OR Access Cab V6 debadged
    Fog-light anytime mod, ,black grill,URD short throw,TRD decals removed ,debadged,black rear bumper, homemade tire carrier,TreadWright tires,Evo mod,removed rear headrests and seats,ABS kill switch mod,black center caps,Clarion CX501 head unit,Relentless hood brackets with floodlights.
    27 out yesterday caused my light to come. Checked the pressure later after they warmed up and had to add about 2lbs to each tire.
  8. Nov 8, 2012 at 12:26 PM
    chipnoreo
    chipnoreo Ready for snow!
    Anna
    Alaska
    Ram Eco Diesel
    Getting 30 mpg on the highway
    My light stays on all winter :/ Even after air pressure adjustments. I just ignore it and get concerned if it doesn't turn off come summer
  9. Nov 8, 2012 at 12:28 PM
    Pugga
    Massachusetts
    Your winters are a little colder than most of ours though :D
  10. Nov 8, 2012 at 12:36 PM
    chipnoreo
    Anna
    Alaska
    Ram Eco Diesel
    It's kind of funny. EVERY car I get in all winter has the tire pressure light on. Work trucks, friends trucks, my truck, moms car....
    thank you car for trying to be smarter than me and just putting another annoying light on the dash that I am going to ignore.
  11. Nov 8, 2012 at 12:48 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    first thing to do is to read the owner's manual. it is perfectly clear.
    then check your tire pressures.
  12. Nov 8, 2012 at 1:40 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    If you're running around with underpressure tires, you're wasting money. Uneven tire wear, and lower gas mileage is where it starts.
    ^RTFM and all will become clear. That's what it's there for.
  13. Nov 8, 2012 at 2:49 PM
    jbrenn
    jbrenn Well-Known Member
    allen texas
    10 sr5
    Check the tires. They are probably a few pounds low. Add air if necessary and the reset switch is below the steering wheel press and hold until it flashes then release. you will not have a sensor in the spare tire. But it is a good idea to check it as well. For some stupid reason toyota put the valve stem on the spare up from the factory.
