What to do with 1/2" rear drivers Taco lean?
Discussion in 'Suspension' started by maxpower29, Aug 7, 2012.
  1. Aug 7, 2012 at 4:54 PM
    maxpower29
    maxpower29 [OP] Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    Im running 5100's with tsb in the rear and set at 1.75. I have good measurements all around except the rear drivers is 1/2" lower.
    I ordered the toytech 1.5 AAL and the Eibach coils, so Im wondering what else I should be getting to fix this lean? I know people say the 1/4" spacer in the front but would that help the rear?
  2. Aug 7, 2012 at 4:55 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Don't measure unless your gas tank is empty / problem solved :D
  3. Aug 7, 2012 at 4:57 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Or a chevy fat chick in the passenger seat ;)
  4. Aug 8, 2012 at 8:17 AM
    maxpower29
    Jordan
    Nova Scotia, Canada
    I love you guys.....
  5. Aug 8, 2012 at 8:19 AM
    Gotcha88
    Gotcha88 Well-Known Member
    CA
    2012 DCSB PreRunner TRD Sport
    Bilstein 5100s all around, Toytec Eibach coils, Toytec 1.5" AAL, Light Racing UCAs, 285/70r17 Nitto Terra Grapplers, 17x9 Eagle 185s, 20% tint all around, Magnaflow 11256, Cobra CB with 2' Firestik, De-Badged, BHLM, UltraGauge, K&N Drop-in, OEM Bed Mat, OEM All-Weather Mats.
    Isn't that why you lift in the first place? So they can't get in?
  6. Aug 8, 2012 at 8:19 AM
    k9cop
    k9cop if your not the lead dog, the view never changes
    Farva
    Hogwarts
    10 tacoma dbl cab trd off road prerunner
    CST 3.5" spindles, King 2.5 rr ,All Pro Expo's, Ext. Billy 5100's rear, Ext rear All Pro brake lines, LR UCA's, debadged, Cobra 29,2ft firestick, satoshi by jim, ARB front bumper, Smittybuilt xrc8 winch, wethatecs, bhlm also by jimbob, belgium malinois and German Shepherd in bed
    I put in a 1/4" spacer on front drivers side it pretty much took care of it
  7. Aug 8, 2012 at 8:25 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    I was going to suggest the empty tank but someone beat me to it :cool:
    so lifting the front actualy lifted the rear?
    can you also divide by zero?
  8. Aug 8, 2012 at 8:27 AM
    maxpower29
    Jordan
    Nova Scotia, Canada
    Ya I'm a little confused
  9. Aug 8, 2012 at 8:31 AM
    TRD6Speed
    TRD6Speed senior member
    Bill
    East Hartford, CT
    08 TRD Sport Access Cab
    885x with 5100s and top plate spacer for full 3", RCD extended 5100s in rear, dakars, flip kit, LR UCAs, tint, shorty antenna, in channel rain guards,BHLM, blacked out emblem, OEM side steps, weathertechs, debadged, rear diff breather
    ya this
  10. Aug 8, 2012 at 8:51 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    It's an unfortunate fact of Tacoma. Battery, driver, gas tank are all on the driver's side.
    If you don't want taco lean, you have to offset it. Move the battery to the bed on the passenger side, fuel cell center mounted in the bed and presto....no taco lean. Otherwise, it's just one of those things you deal with. Keep in mind that despite the lean-to swagger, the fucking truck will always get you home.
  11. Aug 8, 2012 at 9:07 AM
    maxpower29
    Jordan
    Nova Scotia, Canada
    Ya I'm not too worried, I just wasn't sure what else I should buy for the setup. I'm sure when I slap on the 1.5 AAL it will be better with the stiffer springs
  12. Aug 8, 2012 at 9:08 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    60% of the truck's weight is over the front wheels, so yes, lifting front left usually solves the Taco lean.
  13. Aug 8, 2012 at 10:17 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    derp.
  14. Aug 8, 2012 at 1:55 PM
    KenLyns
    Belly of the Beast
    Did not misread. Lifting front left will also give a small amount of lift to rear left. In fact, with the front swaybar in place, you can "over-lift" the front left and not have it visible in the front.
